09-28-2013, 06:01 PM | #76 |
Re: FNG 72 K5 CST Project
Heres another one, little closer....the reason the spring is mounted to the forward position (on your ford picture), is to have the wear more uniform...throttle cable pulls the shaft to the rear, and with the spring in the rear mounted position, all the wear is on the back of the throttle shaft. But, if you put the spring forward of the throttle shaft, it equalizes the pressure, supposedly
Pay no attention to the outside cable, thats for cruise control FishinTrip157 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-28-2013 at 06:06 PM. |
09-28-2013, 10:20 PM | #77 | |
Now how do I know how much spring tension to use? I noticed the one pictures here has a spring inside a spring. I was just planning on using the stock spring because it seems totally fine. Thanks again. Posted via Mobile Device
72 CST Blazer 4x4 (Revival in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=430968 |
09-28-2013, 11:08 PM | #78 |
Depends on how hard you want your pedal, how fast you want your throttle shaft to return to idle, and what kinda condition your carb is in.....all varibles, decisions, decisions, all yours
I like two, if you want them lmk. Im not using them anymore. I have this to keep my engine running right 20130121_211610 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
09-28-2013, 11:19 PM | #79 |
Sweet! I will see how it goes I've been crazy busy at work. That there looks all kinds of fancy...
Posted via Mobile Device Posted via Mobile Device
10-02-2013, 02:32 AM | #80 |
What are these and can I get rid of them? Lots and lots of vacuum lines here... Some seem to go to these little doohickeys and are connected to nothing else? Pardon my lack of proper nomenclature.
This one looks like it opens up a side vent of some sort... Posted via Mobile Device
10-02-2013, 08:35 AM | #81 |
Theyre part of the ac system, put them on the classifieds and make some bucks.....if that is a glass fuel filter i see, get rid of it, if its plastic get rid of the worm drive clamps, and put spring clamps on it.....
10-02-2013, 01:17 PM | #82 | |
Thanks! Posted via Mobile Device
10-02-2013, 01:51 PM | #83 | |
Fuel filter may already be deformed, sooo, but a new one of those ascwell
10-02-2013, 07:34 PM | #84 |
Does it really matter what fuel filter I get? Would be nice to have a aluminum one.
10-02-2013, 08:38 PM | #85 | |
Glass breaks = fire Plastic leaks with worm drive clamps = fire
10-03-2013, 03:18 AM | #86 |
10-03-2013, 01:48 PM | #87 |
Just a nother gear head
yes all those parts go with the factory air. dont need them if your not running air or going aftermarket.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 |
10-05-2013, 02:23 PM | #88 |
So after I get back to this and just want a heater, does anybody have any pics of what it looks like when it's done? Does the box need to go back in? Or maybe I pick up a factory one that just had heat? Thanks
10-09-2013, 12:26 AM | #89 |
Got some things done with the fuel lines..
