#76 |
Re: 68 workhorse
Look like the valve for an old set of air shocks. Fairly popular in the 70's. Didn't dampen bumps much, but you could adjust ride height with them.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
#77 |
fat old dude
![]() Join Date: Feb 2010
Re: 68 workhorse
present from the former owner. he called me a week ago and i had time to pick it up today.
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
#78 |
VA72C10
![]() Join Date: Mar 2008
Re: 68 workhorse
cool! Those look nice!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#79 |
fat old dude
Re: 68 workhorse
ok, so i want to get 6 lug steels with hubcaps.
heres the one that came with the truck as a spare. i got these from a friend, they came on his 69. are these correct?
#80 |
Re: 68 workhorse
hurry up and put those head light bezel and the rims on!
#81 |
fat old dude
Re: 68 workhorse
Took the truck out on sunday to a job. Did well on carrying loads but i did run out of gas once. I had changed the sending unit in the tank and im not still not getting a gas reading. I was also able to drag a stump as big as the hood around the yard while it was loaded to the brim with logs. Really wanted a pix of it loaded but my lame phone turns off by itself and i need to plug it in to turn it on(iphonr with bustef sleep/wake button)
#82 |
fat old dude
Re: 68 workhorse
Oh, also i wasnt all to good with the old manual. Im used to new ones that are all smooth and little effort, so i turned it off a couple times. It seems like my alt isnt charging the battery. I had to get jumped a couple times.
#83 |
Re: 68 workhorse
yep those old manuals are a little sloppy lol
#84 |
fat old dude
Re: 68 workhorse
looks like tomorrow or soon the engine is getting pulled and the tranny for my goodwrench 350 with a TH400
#85 |
Re: 68 workhorse
we need pics!!!!!!
#86 |
fat old dude
Re: 68 workhorse
my neighbor will be buying the current engine in it and im robbing my 72's drive train. will i need a new driveline?
#87 |
Re: 68 workhorse
what tranny did they 68 have and what tranny are you putting in?
#88 |
fat old dude
Re: 68 workhorse
68 had a 4 speed manual and a 327/350.the SPID says 327 but im not sure if it was changed at one point.
the 72 has a 350 goodwrench crate engine with a TH400. basically guna move the 72 stuff onto the 68
#89 |
Re: 68 workhorse
yup you will need a new driv line... i would try and see if you can make it work if not then start huntin around...
#90 |
fat old dude
Re: 68 workhorse
hmm the longbed is two pieces though.
#91 |
Re: 68 workhorse
yes you might need a new carrier bearing
#92 |
fat old dude
Re: 68 workhorse
im tired. pulled the engine out of the 68. i thin the 68's engine is long water pump and the 72's is short water pump. was trying to swap pulleys to put all the accessories from the 68 engine onto the 72's. looks like in order for it to work i'll have to make the 72 engine a longwater pump for now?
![]() ![]() ![]() ![]() ![]() these is the bottom double belt pulley from the 68 onto the 72 and its not aligning ![]() ![]()
#93 |
![]() Join Date: Feb 2011
Re: 68 workhorse
nice
#94 |
Re: 68 workhorse
dayum im impressd buddy! you took the dog house and engine out by yourself? sweet!
#95 |
fat old dude
Re: 68 workhorse
whats the doghouse?
#96 |
Re: 68 workhorse
front clip
#97 |
fat old dude
Re: 68 workhorse
oh. yeah i do everything alone.
#98 |
Re: 68 workhorse
your pretty beast man!
#99 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: 68 workhorse
Looks like your making progess.. Btw that dirty water pump is the long one and the orange on is a short one..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#100 |
fat old dude
Re: 68 workhorse
im finally back home and got sometime to get to work. it is really really hard to remove and move the engines around the yard alone.
i removed the high hump and found a rag and some custom foam? ![]() ![]() the manual tranny crossmember didnt want to come out in one piece even after i took out the top of the rivets so it just came out in pieces. ![]() 4 speed is out. ![]() engine n tranny off the 72. really dusty. ![]() the 72 empty ![]()
