Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 09-19-2012, 12:30 AM   #76
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: SiX-fo SuBuRbAn
been busy with another project this week, but have the rear pretty much set, next is mounting the engine mount, then I get the body out of the way, mount the engine and trans/transfer case, then I will use the driveshaft out of a 87 swb pickup, that should set the wheelbase at 116-118, I will make up for the difference in length with a set of longer lwb wheel wells off a 60-66 fleet.
Old 10-14-2012, 12:49 AM   #77
Captainfab
60-66 Nut
Re: SiX-fo SuBuRbAn
Any new progress Jon?
Old 10-14-2012, 07:44 AM   #78
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
hmmmm..... no, got lots of excuses, but it looks the same as that last pic for right now....
Old 10-20-2012, 06:11 PM   #79
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
little more progress, just about ready to start putting the new floor in...
just a little lower rust to fix on the body before the floor goes in.
"secret" vin # location on top of the lh frame rail.
Old 10-20-2012, 06:13 PM   #80
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
here are some shots of the sub/panel specific body mounts, and the rear frame rail difference where the bumper mounts.
Old 10-21-2012, 10:40 AM   #81
piratexpress1369a
piratexpress1369a's Avatar
Re: SiX-fo SuBuRbAn
are you going to sand blast the frame
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 10-21-2012, 01:24 PM   #82
lucifer
lucifer's Avatar
Re: SiX-fo SuBuRbAn
Yea I found the serial number on the left side of the frame as well as having a serial number on the right side frame?
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 10-21-2012, 10:12 PM   #83
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
no it's not in that bad of shape, just gonna clean it up, and maybe put some por 15 on it
Old 10-22-2012, 05:41 PM   #84
piratexpress1369a
Re: SiX-fo SuBuRbAn
por 15 good stuff for your neck of the woods
63
Old 10-23-2012, 07:46 AM   #85
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
yeah, if I was in a "rust belt" area, I would have to do alot more preventive mantinence!
Old 11-02-2012, 10:53 AM   #86
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
well, got the engine out and ready for a test fit, it is a 396 (66) that we picked up in a diesel 84 blazer.
It had a wierd knocking noise when we bought it, and we suspected that it was a broken flywheel since we have experience in that area, and after listening all over the engine we were pretty sure it wasn't internal.. check out the crack in the second photo! this is our 3rd with pretty much the exact same crack...
engine codes were this: back of the block: 3855961, with a sideways "P" under the 55, also behind the flywheel on the back of the block it says HI PERFORMANCE/TRUCK/CAR (maybe PASS-I forget now)
the block code on the front is: T III3IVR the vin is 6L138792
as far as I can figure it is a 66 396 325 hp with a rochester/auto, although it does have a pilot bushing in the crank-who knows what it was in before the blazer though...
any help on the decoding would be great.
my plan is to bolt the engine/trans-transfercase combo together, and set it in the frame, that should show me where the trans. crossmember needs to be bolted in, and then after that I will use the swb 73-87 4X4 driveshaft I have to determine where to bolt the rear springs to the frame.
*** with the 4 inch lift how much of the driveshaft yoke should I have showing out of the rear of the transfer case??-
Old 11-03-2012, 12:12 AM   #87
Captainfab
60-66 Nut
Re: SiX-fo SuBuRbAn
Wow, it wouldn't have been long before the center of that flexplate just let loose of the rest.
Pretty much every passenger/light truck big block I have seen has the Hi-Perf/Pass cast into the block. It doesn't mean it is anything special.
I haven't found an IVR code yet. I did find the IV code which says '66-'68 325 HP 396 with auto trans, just like you said.
Old 11-03-2012, 07:44 AM   #88
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
I read on a chevelle website that the R, or an H would sometimes be stamped if it was going to have either a rochester, or a holley carb.
Old 11-06-2012, 10:02 PM   #89
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
pics maybe tomorrow, got the engine in, motor mounts sectioned, trans crossmember located and in, mocked the old cowl up to see about fitment issues with the bbc.
so this came up: I located the front axle centered in the wheelwells. I located the motor mounts exactly where my 63 4X4 sbc is.
there is a 4 inch lift.
the front driveshaft comes up short by about 3-4 inches....
this is the same shaft that was in the truck that had the 4 inch lift.
so were the motor to axle locations different 60-66, as compared to 73-87?
since everything seems to be in the right spot I guess I will have to have a longer driveshaft made...
Old 11-07-2012, 10:44 PM   #90
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
engine fit shots
Old 11-07-2012, 11:03 PM   #91
padresag
Re: SiX-fo SuBuRbAn
looks good
ron
padresag is offline   Reply With Quote
Old 11-08-2012, 02:13 AM   #92
Captainfab
60-66 Nut
Re: SiX-fo SuBuRbAn
If you aren't past the point of no return, you could change to a short water pump, and slide the engine, trans and TC forward a little. That's what I did on my Suburban. I used the short water pump, and moved the engine forward 2".
Old 11-08-2012, 08:34 AM   #93
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
I had thought about that, especially since there seems to be enough room betwen the rad and fan. , it was re-measuring and re-drilling 16 holes that slowed me down,
since I am doing a bunch of body work to the cowl and floor anyway, I decided to just relieve the firewall, like rocktonka did on thier sub.
here is a pic of what they did:
Old 11-08-2012, 10:23 AM   #94
duallyjams
duallyjams's Avatar
Re: SiX-fo SuBuRbAn
What length front & rear springs did you use also could you share some pics of the rear spring hangers.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-08-2012, 11:11 AM   #95
1963c-10
1963c-10's Avatar
Re: SiX-fo SuBuRbAn
My BBC book says that the casting # 3855961 was for 1966. Is a 396 and could have been either 325 or 360HP. According to chevy blueprints, it shows it to be a 2bolt block and is identical to casting #3855977 (366 truck) except for the passenger car deck heights, cylinder wall revisions and minor casting and machining. Does not have dowel pins for locating timing chain cover. Casting date on the right lower side near the freeze plug in front of the starter. Has the tall tower distributor casting boss. The code TIII3IVR is for the T=Tonawanda plant, III3=Nov 13 and the IVR is for the 396 w/TH400 pass car engine w/Rochester. Chevy often used the letter I in place of the #1. Serial # shows 6L138792 which is 6= 1966 L=Van Nuys, CA assembly plant and 138792 is the VIN
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-08-2012, 11:50 AM   #96
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
I haven't mounted the back rear hangers yet, but did get the front mounted, and have a pic of that for the next post, I will have to measure the lengths for you, the rear are stock 88 3/4 ton 4X4 'burb, and the front are a 4 inch lift spring that (aftermarket) that I got off of the front of an 87 1/2 ton 4X4.
Originally Posted by 1963c-10 View Post
My BBC book says that the casting # 3855961 was for 1966. Is a 396 and could have been either 325 or 360HP. According to chevy blueprints, it shows it to be a 2bolt block and is identical to casting #3855977 (366 truck) except for the passenger car deck heights, cylinder wall revisions and minor casting and machining. Does not have dowel pins for locating timing chain cover. Casting date on the right lower side near the freeze plug in front of the starter. Has the tall tower distributor casting boss. The code TIII3IVR is for the Tonawanda plant, Nov 13 and the IVR is for the 396 w/TH400 pass car w/Rochester. Chevy often used the letter I in place of the #1. Still working on the serial #
thanks for this, that tIII3 was confusing me, I am thinking that the serial # will turn out to be an impala... if it turns out to be a chevelle the motor will probably be worth more than the whole project!
Old 11-08-2012, 12:09 PM   #97
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
got the rear springs mounted (started -lots more holes to drill-) wheelbase is going to be 117.5 which should work out because I plan on using the longer long fleet rear wheelwells.
the slip yoke has 1.5 inches showing, and 4.5 inserted, which I hope is not too much???
pic # 3 shows the rear shock, how do I figure out where the shock should be mounted?
these are the longer shocks that came with the 4 inch lifted truck, right now they are extended all the way, and the frame has no weight on it, I will be able to set them at a 25 degree angle, they were 30 degrees on the 88 sub...
do I just place them and punch a hole where they fit, or do I need to collapse them a bit , and then punch the mount hole?
Old 11-08-2012, 12:25 PM   #98
1963c-10
1963c-10's Avatar
Re: SiX-fo SuBuRbAn
No problem. Im pretty versed on the BBC and straight 6 (230, 250,292). Sounds funny, but I have never owned a SB. Always been big blocks or straight 6. Although did have a 48 roadmaster w/straight 8 when I was a kid. The nice thing about that casting #, is that it is one of the few 396 blocks that can be bored to a 427. So it is a desireable block either way. As far as I know, there is no way to tell by block alone if its corvette/impala/chevelle. If you know the heads are original(casting #'s), that may lend some help. Im no help on the suspension stuff though...sorry, but looking could.
Old 11-09-2012, 12:31 AM   #99
Captainfab
60-66 Nut
Re: SiX-fo SuBuRbAn
On the shocks, you will want to mount them so that you have more compression than extension. It is a little bit of a guessing game when you don't have the total weight on the suspension. I would shoot for maybe 70/30 at ride height.
Old 11-09-2012, 09:54 AM   #100
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
thanks!, I can probably wait until the body is back on before I mount the rear shocks.
so did I read this right? compress the shock so that only30% of the arm showing, then locate the hole?
..or did I get it backwards?
