Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 12-01-2011, 03:33 AM   #76
67chevy1series
67chevy1series's Avatar
Re: Project "Daa BURB" - 1968 Chevy C10 4X4 Suburban
oh man i was checking this build daily for updates! glad it was good one! just subscribed to your channel. the burb is super nice very cool patina out side very nice redone interior on the inside! the rims tires... all of it you hit the nail on the head. are you going to get any hub caps for it??? maybe buy 68 1/2 on hub caps and cut the centers out of two, that have dented rusty messed up centers ,so its not a complete waste?
67chevy1series is offline   Reply With Quote
Old 12-01-2011, 03:28 PM   #77
Bigblueburban
Bigblueburban's Avatar
I love this truck, nice work your attention to detail is great it's like all these small things add up.
Bigblueburban is offline   Reply With Quote
Old 12-04-2011, 09:16 PM   #78
Mt Man Chad
Mt Man Chad's Avatar
Picked up a very nice restored correct 7028213 on evilbay for the cost of what most are asking for unrestored carbs.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 12-04-2011, 09:19 PM   #79
vectorit
What?
vectorit's Avatar
Dang! That looks nice.
Does the seller have more?
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 12-04-2011, 09:25 PM   #80
Mt Man Chad
I'm looking and will keep you posted if I see any, just sent him a message if he has any more.
I'll send you the sellers name if you want to contact him, he has 100% positive feedback from hundreds of carbs.
Old 12-04-2011, 09:28 PM   #81
vectorit
What?
vectorit's Avatar
Cool, yea let me know since I'd be interested in one for the burb and one for the 1970 PU.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 12-04-2011, 09:40 PM   #82
68panelman
68panelman's Avatar
Nice work man, first ride feels great right? keep up the great work!!!
68panelman is offline   Reply With Quote
Old 12-17-2011, 10:01 PM   #83
Mt Man Chad
Brake's almost complete, installed braided stainless front lines from Inline Tube but............ needed to do some machining to get the fittings to fit thru the frame with the clips on the back on both sides.
for now just need to bleed the bubbles out of the system.
New gas tank arrived and much needed for replacement of nasty original that leaked bad. Old gas would not burn so I drilled a hole in the corner of the tank to drain the nastys out. The two extra holes on the new tank that are used on 71/72 tanks vapor return I plugged with screwing a 1/4-20 x 1" bolts all the way in, 67-70 did not use them. Seat are going to SMS for new original seat cover templates for 67/68 burb's on Thursday.
Old 12-17-2011, 10:07 PM   #84
vectorit
What?
vectorit's Avatar
Glad to see you are using what looks like the right fuel fill hose.
Though, that bolt with silicone jammed into the vent? C'mon...
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 12-20-2011, 06:40 PM   #85
Mt Man Chad
Oooo I know Chris about the gas tank thingininggggg.
I live in a small town long drive to parts, I have to make do with what ever I have that work!
Old 03-22-2012, 08:55 AM   #86
Mt Man Chad
After a bit of derailment from working on the burb, the 4" lift has finally been installed.
Stock leafs have 2, aftermarket have 6 up front. Rear lift was accomplished with a shackle flip from http://www.sky-manufacturing.com/. One of the rear leaf mounts had a good size crack in it, so killed two birds with one stone with the shackle flip. In the process I needed to machined some spacers to fit the new leafs to the front outter shackle bolt holes - http://youtu.be/U89oQhx2i3s- to install 69-72 4" lift front leaf springs since nobody really makes the correct ones for 67-68 4X4 trucks. Purchased a set of 5125 Bilstein shocks, Theeee BEST shocks I have ever had hands down. As well needed to install 4" drop drag link to correct for steering as well new U bolt kit from Rancho. Time to install 33's or 35's now..... the used 31's I picked up look like pizza cutters on there! =0/
Old 03-22-2012, 10:09 AM   #87
jbclassix
Junk Yartist
jbclassix's Avatar
I am going to nominate your truck for Jeff's Calendar. It looks AWESOME
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-22-2012, 10:13 AM   #88
vectorit
What?
vectorit's Avatar
I totally agree with you on your shock absorber choice!
I have those in my 1970 K10, and I highly recommend them as well.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 08-02-2012, 10:23 PM   #89
Mt Man Chad
Tow hooks installed..... =)
Old 08-02-2012, 10:28 PM   #90
vectorit
What?
vectorit's Avatar
Sweet!
The OE hooks are like the cherry on the cake for a 4x4.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 08-02-2012, 10:56 PM   #91
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice! I almost went with those shocks, but they were out of stock when I was ready to order them. I love those drag links! It's getting harder to find those lately!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-03-2012, 09:01 AM   #92
Mt Man Chad
Chris I could not of put it better.
They make the truck complete and look sweet!
Old 08-14-2012, 11:31 PM   #93
justcuz
justcuz's Avatar
Nice work on the Suburban. I thought the correct mounting for the tow hooks was the open end of the hook faced backward.
We had a 1968 3/4 ton Suburban when I worked for the Forest Service and its hooks were mounted with the open end facing backward. I suspect the tow strap or chain will not slip off mounted the way the factory does it.
Was the Rockwell 221 married to the 3 speed trans or divorced?
Are you going to stick with the closed knuckle front axle and drum brakes or plan to upgrade later?
Keep up the great work, the truck looks terrific!
justcuz is offline   Reply With Quote
Old 11-09-2012, 09:24 AM   #94
Mt Man Chad
Just a nice fall photo
Justcuz,
Yes it was a rockwell 221 married to 3 speed.
Will be swapping out the closed knuckle for a pair of 78 axles I am rebuilding with 4.56 gears.
Old 11-09-2012, 12:04 PM   #95
vectorit
What?
vectorit's Avatar
Looks freakin awesome! It's come a long way.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 11-09-2012, 12:28 PM   #96
jbclassix
Junk Yartist
jbclassix's Avatar
Love it dude!
-Jeremy
Rebuilding an NP205
Old 01-07-2013, 12:08 PM   #97
dieselmec1993
nice burb
1977 k20 frame with 85 cab and hopefully 6.5 diesel.
1981 c20 long box 250 3 on the tree daily driver.
1982 k25 with 86 cab tired 350 4speed trans 37in military tires.(project Frankenstein). 8.
1984 c30 crew cab dually 6.2diesel next project
only 18 and finshed 5 projects started when i was
dieselmec1993 is offline   Reply With Quote
Old 01-24-2013, 01:44 PM   #98
67chevy1series
It gets better each time! Keep it up. Looks so cool
Old 03-20-2013, 10:51 PM   #99
goldenburb
goldenburb's Avatar
Nice going, keep posting,,, I wish my was a 4x4..
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 02-05-2014, 11:50 PM   #100
vectorit
What?
vectorit's Avatar
How are things going?
Haven't seen you around, hoping everything is OK.
Chris
1968 K20 Suburban
1972 K10 LWB PU
