Old 09-20-2011, 05:33 PM   #76
Coupeguy2001
Coupeguy2001's Avatar
Re: My 58 Fleetside
Lee, I have a perfect virgin dash if you get tired of beating your head against the wall on this one, and the tubular corvette manifolds will clear the factory steering column and they are 2 1/2 inch outlets........just a reminder.
Coupeguy2001 is offline   Reply With Quote
Old 09-22-2011, 12:48 AM   #77
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
I'm getting the front clip ready to paint and was wondering how I should do it. Should I put the front together and paint it or paint the parts and them put them on. How hard is it to put the fender emblems on after everything is together?
I pity the fool with only 2 headlights!
Green 1959 is offline   Reply With Quote
Old 09-22-2011, 02:26 AM   #78
Coupeguy2001
Re: My 58 Fleetside
paint the parts separate then install the emblems, then assemble the fenders on the inner fenders after they are on the truck..... Just tape everything off really well prior to assembly to eliminate scratching.... try to visualize yourself on the assembly line in 1959. What is the fastest yet easiest way to do what you are about to do? Probably the whole front clip went together prior to installing.
I put my emblems on my 57 fenders with the fenders installed. I ruined a good T shirt doing it, but it can be done. (thank you armor-all) It definitely wasn't the fastest way. You have to use a box wrench so your wrench stays on the last nut. One of those new style ratchet wrenches would do fantastic.
Old 09-22-2011, 10:16 AM   #79
Russell Ashley
Russell Ashley's Avatar
Re: My 58 Fleetside
What Coupeguy said.
I would just add that it will be a lot easier if you have a helper. I just re-installed my fenders and having someone to hold up the front of the fender while you get it into place and get the rubber gasket under the inner fender lip will make it go better. Also will make it less likely to scratch the paint at the cab and front of the door.
Russell Ashley is offline   Reply With Quote
Old 09-22-2011, 01:45 PM   #80
OrrieG
OrrieG's Avatar
Re: My 58 Fleetside
I got a set of Craftsman with the swivel head. Spendy but worth it to get into all the nooks and crannies. I sold a 68 Camaro that had a 7/16" wrench wedged up in a place I could not get too after it spun when tightening from the other side with a ratchet.
OrrieG is offline   Reply With Quote
Old 09-22-2011, 01:53 PM   #81
A.T. RockDriller
A.T. RockDriller's Avatar
Re: My 58 Fleetside
I love your truck, Orrie....
Those dogs of yours are quite the duo, too.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 09-22-2011, 07:37 PM   #82
OrrieG
OrrieG's Avatar
Re: My 58 Fleetside
Only Murph is mine (red one). The other was my karate instructors.
Old 09-25-2011, 10:15 PM   #83
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
The patch for the left side. The right side on. The left side welded. The inside of the lft side with bedliner brushed in.
Old 09-25-2011, 10:21 PM   #84
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
The front together and the grille!
Old 09-26-2011, 12:44 AM   #85
longbike
longbike's Avatar
Re: My 58 Fleetside
Hey Green looking good!
Where did you get that fender patch panel from and could you please measure it from bottom to the top? The ones I got didnt have that wheel opening lip that wraps around to the inside!
Jeff
longbike is offline   Reply With Quote
Old 09-26-2011, 08:32 AM   #86
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
Grumpy's in Phoenix, its about 18 inches tall
Old 09-26-2011, 09:26 AM   #87
longbike
longbike's Avatar
Re: My 58 Fleetside
Thanks buddy!
Old 09-26-2011, 09:43 PM   #88
zellway
zellway's Avatar
Re: My 58 Fleetside
Looking good! Cant wait to see it in green!
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 10-31-2011, 11:06 PM   #89
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
The new driver's door, new rear end 3.38, the dash is coming together.....
Old 10-31-2011, 11:11 PM   #90
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
This is the door with the holes that need to be welded and then da-da its done.
Old 11-01-2011, 12:11 PM   #91
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
Hey guys a question, can I get some ideas on how to sound deaden and heat block the doors? I took them apart this weekend and found that there is not a good way to get in there.
Old 11-01-2011, 07:59 PM   #92
Daze57
Daze57's Avatar
Re: My 58 Fleetside
try the self adhesive sound deading stuff - hushmat;dynamat etc. you dont need a big piece - jam a piece in there make a rough cut to fit then heat gun it to stick - that does make a difference
Daze57 is offline   Reply With Quote
Old 11-06-2011, 12:25 AM   #93
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
It was the best of times it was the worst of times...... Truly the worst of times, my new door has a badly bent window frame..... Going to try something crazy.. Also the dash is now painted.
Old 11-06-2011, 11:17 AM   #94
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
Also if anyone has any cool tips on aligning doors that would be cool, I took the hindges off and now nether side will line up right. I'm sure I just need to spend more time tweaking it and I'll have to cut the window frame off the left side to finish.. But any wise words are greatly appreaciated.
Old 11-06-2011, 11:35 AM   #95
Kim57
Kim57's Avatar
Re: My 58 Fleetside
One thing to keep in mind is that these doors didn't fit that well from the factory. Gaps of an 1/8" or more are common. it takes a lot of work to get them nice.
Just be patient and you'll get there.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 11-06-2011, 02:48 PM   #96
OrrieG
OrrieG's Avatar
Re: My 58 Fleetside
Based on what others have done you like Kim said you usually have to add and subtract metal to get even gaps. Earlier serial numbers are usually better, later as the dies started to wear out things got worse. They also designed these with lots of wiggle room so as they flexed and got beat being used things would not bind up. Remember these were designed and used when most of the rural areas still had dirt roads and they were driven over irrigation ditches, plowed fields, etc.
If you are going to start cutting up window frames make sure you have glass handy to make sure you are not making any problems with gasket or glass fitment down the line.
Old 11-06-2011, 06:40 PM   #97
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
The problem I've having now is that the doors are too close to the body on the front side and the fenders stick out 1/4 inch. Ill post pictures so you can see, I'm giving up for this weekend, too tired and frusterated to try to continue.
Old 11-06-2011, 07:09 PM   #98
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
Here are the problem areas folks.... The drivers side door and fender, the second picture is just at a diffferent angle and the third is the passanger side. How can I get the fronts of the doors away from the body? I moved them as much as a I could. I'm I just missing something???!!! urg
Also I chopped the top of the driver's door.....
Old 11-06-2011, 10:51 PM   #99
longbike
longbike's Avatar
Re: My 58 Fleetside
You know what Green I now got that same problem, tonight I just replaced the lower front fender extension like you just did and the patch panel bows out farther than the door now, "what the heck do you do now"?
Old 11-06-2011, 11:11 PM   #100
Green 1959
Green 1959's Avatar
Re: My 58 Fleetside
As soon as you tell me, I'll tell you.
