Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 06-02-2011, 07:59 AM   #76
mrein3
mrein3's Avatar
Re: Post your best budget mods! ($50 or less)
Originally Posted by ls1nova71 View Post
I'm going with the headlight relay mod. If you get relays and wiring at the junk yard, it van be done for about 10 bucks.
I agree with this one. The headlight relay mod is a must do for everybody. I bought two new relays and new wire and still got it done for under $20. Here is a link to a recent thread on this forum with a nice picture.
http://67-72chevytrucks.com/vboard/s...d.php?t=465003
Another cheap mod I like is putting a quartz clock in the dash in the open hole to the right of the steering column. I think I paid $5 for the clock out of an 80s Suburban. I grabbed the Sub's factory connector. The hole in the clear plastic is made with a heated nail. I learned the heated nail trick on this forum. That clock keeps really good time. I have less than $15 into it counting the plastic polish I used to remove the factory markings on the back of that spot in the bezel.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline
Old 06-02-2011, 11:27 PM   #77
richards72chevy
richards72chevy's Avatar
Some where in the forum i saw wire mesh put under the opening in front of the windshield to prevent debris collecting in there.I bet it cost less than 50 to do.Does any body know how the mesh was held in place?
richards72chevy is offline
Old 06-02-2011, 11:40 PM   #78
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I hot glued mine, epoxy would've worked better looking back
i just used old window screen. i'll try'n remember to get pics oneday
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 06-03-2011, 08:44 AM   #79
ubtripn
ubtripn's Avatar
I love the wrench trick, I have a small trurn buckle on my ps set-up I hooked to the back to adjust the angle.
So far my best mod is in progress, the Tahoe's in the late 90's have a platic box under the hood with a lid on hinges. It is labeled storage for anything I guess. Quart of oil, tools, whatever so I took one from the junk yard and just repainted it and am getting ready to mount it under the hood to put in an extra quart of oil, some ps fluid and brake fluid.
ubtripn is offline
Old 06-09-2011, 07:25 PM   #80
cjohnson6772
cjohnson6772's Avatar
bump to get some more great ideas and keep a great thread alive
cjohnson6772 is offline
Old 06-09-2011, 08:29 PM   #81
vectorit
What?
vectorit's Avatar
Not really anything special, but taking a piece of rubber hose and capping it off with a spent 38 special cartridge case makes good vacuum plugs.
This one was meant to be temporary, but after 10+ years it kind of became permanent.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 06-09-2011, 08:42 PM   #82
cjohnson6772
Lol. I like that. Might have to be 9 mm though
Old 06-09-2011, 11:54 PM   #83
VA72C10
VA72C10
VA72C10's Avatar
Adding eightbanger's cool glovebox mod!!!
http://67-72chevytrucks.com/vboard/s...45#post4727345
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline
Old 06-09-2011, 11:55 PM   #84
VA72C10
VA72C10
VA72C10's Avatar
That's cool....I've always used golf tees on the smaller vacuum lines
VA72C10 is offline
Old 06-10-2011, 12:19 AM   #85
CowboyProtectionUnit
CowboyProtectionUnit's Avatar
Subscribed
Eric "Target" Sherwood
Professional Bullfighter For Hire
God Bless and Gods Speed!
TheCowBoyProtectionUnit@yahoo.com
http://www.facebook.com/pages/Eric-T...59496227444241
CowboyProtectionUnit is offline
Old 06-10-2011, 02:18 AM   #86
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
I love these subtle touches, classy yet hot rod
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline
Old 06-10-2011, 02:57 AM   #87
BBrendal
Recalculating.....
BBrendal's Avatar
Originally Posted by Old Yeller 1970 View Post
Replacing the lights in my instrument bezel with LED's. After installing them I could clearly see all the gauges at night for the first time ever. I bought white 5 bulb LED's off eBay for way less than $50. I tried some single bulb LED's but they weren't any brighter than the standard bulbs. The 5 bulb LED's are just right, IMO.
Does the LEDs still dim?
Brian - (BBrendal)
1969 Chevy Camaro Z28
1972 Chevy Blazer CST
2004 GMC Yukon (The truck that pulls the car trailer)
1972 Chevy Blazer CST #2 (Finished and sold!)
Blazer build link...
http://s1213.photobucket.com/albums/...rendal/Blazer/
BBrendal is offline
Old 06-10-2011, 11:04 AM   #88
bguild
bguild's Avatar
Originally Posted by mrhino View Post
replaced the straps with cables less then $20 at the parts store and 2 bolts from a dodge dakota in the salvage yard.
I DIG... I will be doing this.. Great idea.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline
Old 06-10-2011, 11:14 AM   #89
bguild
bguild's Avatar
Question on the tailgate mod.. What cables did you buy? are they all the same or did you buy a certain years cables? I might do that mod soon.
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline
Old 06-10-2011, 11:39 AM   #90
Primered_69
Primered_69's Avatar
http://67-72chevytrucks.com/vboard/s...talgate+cables
says to use cables for the Dakota 1987-2004
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline
Old 06-10-2011, 12:00 PM   #91
bguild
bguild's Avatar
Thanks.. I actually read the post wrong.. I was thinking the two bolts only were from the dakota.. I am little slow this am.
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline
Old 06-10-2011, 04:00 PM   #92
yuccales
yuccales's Avatar
One of the best things I did to the old truck was make the plate thats above my radiator. I dropped a wrench one time and it went between the radiator and the radiator support and poked a hole into one of the tubes. The piece of aluminum was free, can of paint was a couple of bucks. It makes a great shelf to put qts. of oil and a filter on. I did snag the under hood light for free from my buddies wrecked mid 90s chevy truck.
yuccales is offline
Old 06-10-2011, 04:23 PM   #93
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Also subscribed.
Great tips guys!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline
Old 06-12-2011, 06:37 PM   #94
68handmedown
Went to a local swap meet scored a factory am stereo with the deluxe knobs and 90's center caps to go on my 72 6-lug rallye wheels for 50 bucks. The radio is mint and it works. Best 50 bucks spent so far.
68handmedown is offline
Old 06-12-2011, 07:19 PM   #95
Andy4639
Old member
Andy4639's Avatar
I picked these up while in a yard along with electric jug. Less than $50.00 in all of it and I get a complete windshield wash now.
The jug is on the drivers side fender now.
Had to put the shooters in a boiling pot of water with vise grips to make them soft enough to confirm to the wiper arm.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 06-12-2011, 08:03 PM   #96
oldblue1968chevy
Coool!! It attaches to the wiper arm?..
John
Old 06-12-2011, 09:43 PM   #97
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Post your best budget mods! ($50 or less)
The plastic clips to them if the right amount of heat is applied. I used vise grips to hold them over night while it cooled off.
Andy4639 is offline
Old 06-21-2011, 11:12 PM   #98
Heavy Evy
born to lose
Heavy Evy's Avatar
Originally Posted by KMACD71 View Post
Can of white paint, bottle of orange model paint and brushes for the needles and you can brighten up your bezels and I believe with the LED bulb swap you can still be under $50.00.
Wow that looks great amigo!
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline
Old 06-21-2011, 11:39 PM   #99
BMERDOC
BMERDOC's Avatar
Headlight relays, ebrake "brake" light, dome light door pins, painting inside of cluster and adding LEDs are all on the top of my "mod" list.
My own? Add a ground circuit to the rear lights, paint the rear lamp buckets with rattle can chrome and replace the 1157's with 2057's. Adds alot of brightness and will make me feel better when the kids are criusin with me !
BMERDOC is offline
Old 06-22-2011, 12:03 AM   #100
oldblue1968chevy
headlight relays are definitely up there if you EVER drive at night
John
