Old 10-22-2016, 06:56 PM   #76
Winmon
Winmon's Avatar
Re: Black wood beds!!!! Pics Please
Originally Posted by theastronaut View Post
Thanks! It's Valspar latex enamel, #60073 Satin Black. I thinned it with Floetrol to make it sprayable. One quart was enough to do top and bottom. The boards came pre-sanded, we only spent 15 minutes with 180 grit on a DA sander before shooting a couple coats of paint.
What ratio Floetrol did you mix with?
Winmon is offline   Reply With Quote
Old 10-23-2016, 09:02 AM   #77
northern 85
northern 85's Avatar
Size:  112.8 KBi started out wanting the oak to be completely black but stoped at 3 coats of ebony stain because i liked the contrast against the black body panels
northern 85 is offline   Reply With Quote
Old 10-23-2016, 10:56 AM   #78
jbgroby
jbgroby's Avatar
My '60
jbgroby is offline   Reply With Quote
Old 10-25-2016, 08:43 PM   #79
theastronaut
theastronaut's Avatar
1 part paint and "enough" parts Floetrol... I just eyballed it and kept mixing it in until I felt it was thin enough to spray.
theastronaut is offline   Reply With Quote
Old 10-25-2016, 09:51 PM   #80
Winmon
Winmon's Avatar
Lol, thanks!
Old 10-26-2016, 08:32 AM   #81
60-66
60-66's Avatar
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 10-26-2016, 10:59 AM   #82
oem4me
Originally Posted by 60-66 View Post
[/URL]
Whoa! NICE! Hey Jon, regarding the black paint on the top of the rear cross sill - Is this a standard GMC detail? On the original Chevy's I've seen, the whole sill (and some overspray on the edges of the bed wood) is body color.
Old 10-26-2016, 11:03 AM   #83
contagious102
contagious102's Avatar
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
Old 10-26-2016, 11:29 AM   #84
60-66
60-66's Avatar
On the GMCs with the black rear inner wheel tubs , yes. These are the GMCs that each body panel for the bed were painted separate THEN bolted together.(My red 66 was done this way) On these trucks all the bed bolts will still show their plating EXCEPT the bolts holding the wood bed strips. Most of the perimeter bolts will also show the plating. Should also note on these same GMCs the rear sill is NOT welded to the bedsides like a Chevy is. Chevrolet the beds were assembled complete with the already painted bedwood in place and covered with paper , then final paint color applied to the sheet metal , = reason for over spray. I think its been said that the paper was stapled to the wood in that rear area on Chevy.
Old 10-28-2016, 05:23 AM   #85
northern 85
I love that step side it looks fast sitting still!!! Perfect color too!!!
Old 10-28-2016, 11:56 AM   #86
Brad54
Brad54's Avatar
Originally Posted by contagious102 View Post
Can you give us any information on the tailgate hardware?
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 10-28-2016, 04:22 PM   #87
contagious102
They are from Mark K , spring loaded pins that fit in the round top part of the tailgate. I liked them because they fit so clean , and I used a set of the later model fold up inside hinges. You have to do a little bit of trimming to get the hide away hinges to fit . makes a nice clean tailgate when finished. I think Mark K sells the inside hinge kit also.
Old 10-28-2016, 04:30 PM   #88
contagious102
She is pretty quick with the 540 ci motor in place. It's making close to 700hp,and had to work hard to get it under the stock hood.!!! Thanks for the kind comments.!!
Old 10-29-2016, 07:34 AM   #89
northern 85
Holyfreakin hell batman!!!!! WOW!!!
Old 10-15-2020, 11:07 AM   #90
Mike McD
nice!!
Mike McD is offline   Reply With Quote
