Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 01-12-2012, 06:34 PM   #76
Nobby
Nobby's Avatar
Re: 66 suburban build
Originally Posted by McMurphy View Post
I took my hood apart last weekend too, and it turned out to be more of a task than I had anticipated. Would have gone better if I had just bit the bullet and took it apart in reverse from how it was assembled.... Oh well, got it done, now to modify it, wait for the replacement rubber pads to arrive, and then put it back together!
How is yours?
I gotta blast,prime and paint the inner hood support(frame) before I start mocking the hood back up.I took a little break on the burb this week Should hit it hard this weekend.
Nobby is offline   Reply With Quote
Old 01-15-2012, 05:56 PM   #77
Nobby
Nobby's Avatar
Alright we spent two long days on the burb. Changed out a rusted panel on drivers side and finish the skinning on the pass door.That 1/8'' gap around the door didn't happen by accident neither. There was alot of welding,grinding pushing,pulling and cussing but I'm very happy with the end result.
Old 01-15-2012, 06:04 PM   #78
Nobby
Nobby's Avatar
One more cause everybody likes pics...
Old 01-16-2012, 01:19 AM   #79
Captainfab
60-66 Nut
So you used panel bond to install the door skins?
That gap looks awesome.....there's just something about nice even gaps all around.
Old 01-17-2012, 06:33 PM   #80
Nobby
Nobby's Avatar
Yea Captain, 3M door skinning adhesive around the edges and welded across the top. It came out great and real solid. I'm seriously considering skinning the drivers door now.
Old 01-20-2012, 11:25 PM   #81
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Happy birthday buddy!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-21-2012, 08:36 PM   #82
Nobby
Nobby's Avatar
Thanks Nate.... I spent my Bday seeing the USA in a Chevrolet! 25 hr trip to Mount Vernon Il. to pick up and haul back a 34 ford for my uncle. Beautiful country we have here!!!!
Old 01-22-2012, 12:57 AM   #83
2dwn4u
Where did you get the door skin from and what do you think of the quality of it? Looks really nice.
2dwn4u is offline   Reply With Quote
Old 01-22-2012, 01:48 AM   #84
67swb72klb
67swb72klb's Avatar
That gap looks awesome.....there's just something about nice even gaps all around.[/QUOTE]
they sure didnt come off the asy line with those kinda gaps
good job on the build going prety fast !
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 01-22-2012, 12:25 PM   #85
Nobby
Nobby's Avatar
I got it from Top Banana,it's a keyparts pc.I think it's a well pressed piece.I sprayed 3 layers of undercoat before I installed it and it is very solid.
Thanks,
Nobby
good job on the build going prety fast ![/QUOTE]
Thanks, I'm shooting for perfect but will accept a little less
Old 01-24-2012, 07:10 PM   #86
Nobby
Nobby's Avatar
Quick question guys, when i got my burb the front cap wasn't on so I'm not sure on something. Since the burb has a rubber mount on the core support bracket and the truck don't. Does the core bolt directly to the bracket or is there a bushing that goes between?
Old 01-24-2012, 08:08 PM   #87
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
I dont know if mine was stock but mine had a large washer and then a thin rubber washer about1/4"thick hope this helps!
gostranger is offline   Reply With Quote
Old 01-24-2012, 10:13 PM   #88
Nobby
Nobby's Avatar
Thanks man that makes since now. I'm mocking up the front end and was having a little trouble...
Old 01-24-2012, 10:20 PM   #89
protrash64
Resistance is Futile
protrash64's Avatar
It definitely gets a bushing of some sort; it's in the body bushing kits.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-24-2012, 11:45 PM   #90
allaboutchevelles
allaboutchevelles's Avatar
Nice work. door gaps look perfect. keep up the good work. I started stripping the inside of my roof like you did and man its alot of work like you said.
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 01-27-2012, 12:25 AM   #91
mMad Dawg
Nobby could you take a picture of where the pinch weld ends at the front of the rear wheelwell? Im rebuilding a 66 panel that was missing the bottom 3 inches of the body. I got a wheel well repair panel for a pickup but I have to fabricate the rest. Also if you could include a picture of how the 1/4 panel ends by the rear doors. Thanks. Iwsh I was making progress as fast as you. Your burb is looking good. Gord
mMad Dawg is offline   Reply With Quote
Old 01-31-2012, 12:13 AM   #92
hemifalcon
..great looking project.. I'll be referring to yours.. I know that I'm going to be cutting a lot of spot welds now after seeing this.. It's the only way.. Great job--
hemifalcon is offline   Reply With Quote
Old 02-02-2012, 05:49 PM   #93
Nobby
Nobby's Avatar
Thanks for all the encouragement guys! It slowed down a little bit lately but it's about to pick up again. I'll take pics as requested soon. Bodys coming off this weekend so I can start on frame and start smoothing firewall and repair windshield overhang. Heres a couple pics, repaired upper drivers jam, floor work and skinning drivers door.
Later,
Nobby
Old 02-02-2012, 06:09 PM   #94
allaboutchevelles
Looking Good. Keep up the good work. Im glad I didnt have to do any panel repair around the top of my cab around the roof. Looks like your a pro at door skinning now.
Old 02-07-2012, 05:14 PM   #95
Nobby
Nobby's Avatar
No turning back now....Gotta blow the frame apart and send to blaster. Prime, paint then install all this suspension I've been collecting
Old 02-07-2012, 05:18 PM   #96
Nobby
Nobby's Avatar
O yea does anyone have a cab their cutting up? I need this spot around the wiper motor with the bracket too.
Old 02-07-2012, 11:52 PM   #97
hemifalcon
I might be able to help you out with that cab piece.. PM ME if interested.. I have a solid 65 truck cab I'm cutting up for sub
Old 02-08-2012, 02:12 AM   #98
Captainfab
60-66 Nut
I have that piece also. Let me know if you end up needing it.
Old 02-09-2012, 10:36 PM   #99
doubleb's69
doubleb's69's Avatar
Sweet Burb. I would love to have one some day. I've kinda slowed down on 67-72's and would like to get into 60-66 trucks, etc, plus I can't haul the whole family around at the car shows unless they are in the bed.
Bud
doubleb's69 is offline   Reply With Quote
Old 02-09-2012, 11:50 PM   #100
hemifalcon
Nobby==what are you doing for the suspension on the 'burb?
