Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 12-02-2011, 02:14 AM   #76
Captainfab
60-66 Nut
Re: Suburban rear seats and tracks, any info?
If I remember correctly, a standard 5/16" step bolt will work to anchor the seats, in a Suburban that has the fixed anchor plates.
Old 12-02-2011, 02:42 AM   #77
dugvera@gmail.com
dugvera@gmail.com's Avatar
I believe so. Ill check for sure.
dugvera@gmail.com is offline   Reply With Quote
Old 12-02-2011, 08:02 AM   #78
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Step Bolt. You can see the difference from a carriage bolt.
Thank you once again Captainfab
Old 12-03-2011, 12:46 AM   #79
Captainfab
60-66 Nut
No problem......
Old 01-10-2012, 12:56 PM   #80
JimmyFloyd
Originally Posted by dugvera@gmail.com View Post
Attachment 836150
Looks like my '66 gmc has the tracks.
Looks like yours is Vinyl-backed just like the one posted above (Which I still have)
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 05-23-2012, 05:01 PM   #81
padresag
Originally Posted by Corts60 View Post
Does anyone have a picture of a bare floor from a '62 or later 'burb?
Here is the 60-61 mounts:
here is one from a 66 . had a dozen latch inserts
By rondavid at 2012-05-23
ron
Last edited by padresag; 05-23-2012 at 05:02 PM. Reason: helps when you ad the picture
padresag is offline   Reply With Quote
Old 05-23-2012, 06:38 PM   #82
66 Burban
66 Burban's Avatar
May as well add my .02 cents worth!
I have the following:
62 GMC ----- 3 seat
65 GMC ----- 2 seat
65 Chev ----- 3 seat
66 Chev ----- 2 seat
All have "keyhole" fittings in floor for all rear seats. ;-)
Remember: "When seconds count, the Police are only minutes away".
Thx,
Billy B.
66 Burban is offline   Reply With Quote
Old 05-23-2012, 06:42 PM   #83
66 Burban
66 Burban's Avatar
Forgot something! Looked at a 63 GMC 3 seated last weekend. It also had "keyhole" fittings for all rear seats ---- none had tracks...
Thx,
Billy B.
Old 05-23-2012, 06:59 PM   #84
padresag
62 GMC ----- 3 seat
65 GMC ----- 2 seat
but some have more than others
ron
Old 05-23-2012, 11:43 PM   #85
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
My buddy here in town (prerunnerob - he hasnt been on in a long time) has a 66 GMC with tracks...
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 07-21-2012, 12:34 AM   #86
likaroc13
Rollin' Old Skool
hey guys, was looking at Tony's site for something else yesterday and noticed he carries some of the seat mounting stuff:
http://www.4-5-6chevytrucks.com/new-parts.html
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 07-21-2012, 01:28 AM   #87
MikeS.
MikeS.'s Avatar
Originally Posted by LT1 Burb View Post
I don't think these seats could ever be turned around.In fact you would not even want to sit in them for longer than 2 hours, every long trip I took almost had to have a chiropractor appointment set up at the end.
Exactly why I'm replacing the seats in my 63.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 07-21-2012, 08:23 AM   #88
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Originally Posted by oem4me View Post
Geesh, It's kinda hard to follow the conversation here, but I have a couple shots. One is of a '62 GMC (well used), and one of my '65 Chevy (well preserved). Both have the inserts for bolts, but if you look close you might notice the slightly different layout.
My 65 was always a two-seater, but has the inserts for a third seat none the less. take note of the four slider windows and short second seat on the '62. That means the third seat is missing. A full width second seat and fixed rearmost windows on the '65 means it never had a third seat.
Thats funny .... Well used, ha !
No my friend, my 62 GMC is WELL USED !!!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-22-2013, 03:05 PM   #89
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
OK, I found out something on my '62 GMC Burban ... not sure if this has been addressed or not.
My Burban uses the bolt in style into flanges, (not rails)
Although, the holes are different as compared to the 66 Chevy Burb seats I have ....
The following pictures are from the REAR (LARGE) SEAT FRAMES for comparison....
NOTE: The older fawn/rusty color is from my 62 GMC , and the lighter color is from the 66 Chevy:
As you can see, the lower portion of seat frame is constructed different, and the mounting points in different spots....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-22-2013, 03:18 PM   #90
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Now the MIDDLE SEAT is off a bit too, but not as bad.
Only TWO holes are off in this case, and the tubing runs from LEFT to RIGHT so it will be just a matter of drilling two new holes in the seat frame.
Passenger side holes line up:
Screwdriver marks the floor mount, and area where a hole needs to be drilled in seat frame...
Front of frame is the same...
I ended up swapping the cushions from the 66 Chevy onto the 62 GMC frame for the rear seat .... PERFECT !!
Drill tow holes in middle seat, and I am good !
Thats my story, and I'm sticking to it !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-22-2013, 10:13 PM   #91
Corts60
Just here to tinker
Corts60's Avatar
Hey John,
It seems there was no rhyme nor reason for these seat configurations.
Here are the middle and back seat to my '60 GMC. Different yet again.
Old 04-23-2013, 10:31 AM   #92
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
So does this mean 63 and up (like the chassis) is common ?
And we are the oddballs ?
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 10-29-2014, 09:00 PM   #93
Ratpin
Ratpin's Avatar
Courtesy of 6066gmcguy.com
The hardware for mounting the seats for 63-66 GMC Rear Seats.
I sure would like to know where I could find a set of those.
"It ain't as easy as Chip Foose makes it look"
Ratpin is offline   Reply With Quote
Old 10-30-2014, 12:49 AM   #94
Rickey-Lee
the tracks work the same as the cleats I.E. that they use a carriage bolt type mount but the benefit is you can slide the seat forwards and back reverse it ect. The tracks work like the tie downs in a toy hauler. I have a 64 GMC with the tracks, unfortunately my seat is out of Chevy and the rails don't line up with the tracks.
Rickey-Lee is offline   Reply With Quote
Old 11-06-2014, 04:07 PM   #95
NEWFISHER
NEWFISHER's Avatar
Pic of a 63 GMC with rear rails for adjustable positions
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 11-30-2014, 09:44 AM   #96
64chevycrewcab
Originally Posted by MusicMan70 View Post
Here is the bottom off my 61' GMC with cleats. Seat is pushed over and the seat bottom cushion is taken out. The 5 referenced rear supporting legs are on the top.
Now back to our/your survey
Music man if you still have this burb can you post some pics of the roof rack?
1961 Apache 10 with side trim
1964 4 door crew cab C20
1966 Chevy Suburban with custom trim
1961 K30 with a 4-53T Detroit diesel
1966 GMC 4X4 Suburban
64chevycrewcab is offline   Reply With Quote
Old 10-28-2015, 03:48 PM   #97
Coursey
Coursey's Avatar
Good Info
Coursey is offline   Reply With Quote
