Old 04-23-2012, 04:03 AM   #76
Square_78
Square_78's Avatar
Re: Daughter's 1st Square
Originally Posted by my4by2 View Post
So the Daughter tells me today she "really wants power windows" in her truck down the road. I think I've found her the perfect kit!!!!
HAHAHHAHA!! awesome! Might be a little annoying on the drivers side though....
Square_78 is offline   Reply With Quote
Old 04-24-2012, 06:02 AM   #77
my4by2
my4by2's Avatar
Man I really despise the internet at times... Just when ya think you've got it all planned out, something comes along to make you say, "Hmm, that looks good".....
This is exactly what happened to me today - strolling along on the net & came across a shot of a truck somewhat similar to my Daughter's with a set of 20" Dodge Ram spare tire wheels on it.
I personally think they'd look really good on there (better than the 15" stock style would) - not so much in that factory color per say, just the overall appearance & fact that they're 20" wheels. It's also something that isn't on everyone else's truck out there!
If I went with something like that it'd require running adapters since they are the 5x5.5 bolt pattern rather than my stock 5x5 set-up. Kind of would like to do this anyhow as I have the issue with the different thread rear studs & also dislike the way the factory rear track width is narrower than the front is in these trucks - I could get thicker spacers for the rear.
She still wants "red" wheels, so I could easily have these powder coated to match the "GMC" trim we've got & then maybe get a flat black pin strip along the lip or something to set-it off a little since it's so much larger.
Also would most likely end up running some stock type GMC center caps - the chrome ones that are held in place by the lug covers.
Guess I'd like any opinions from the group on which they think would look the best.
my4by2 is offline   Reply With Quote
Old 04-24-2012, 08:38 AM   #78
JPalmer81
JPalmer81's Avatar
if you could incorporate the gmc dog dishes on them i dont think it would look bad at all, and your daughter would be the only one im pretty sure with that set up. the only thing i am wondering about is how the round holes would look instead of the GM factory slits with the hub caps?
1988 Chevy Crew Cab 1ton 4x4 SRW LWB
1977 Dodge 1 ton 4x4
My Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=516872
"The price of Freedom is Eternal Vigilance"
JPalmer81 is offline   Reply With Quote
Old 04-24-2012, 06:04 PM   #79
Conundrum
Conundrum's Avatar
My truck, (pictured above) has redrilled front rotors and 1-1/4" spacer/adapters on the rear. While it had the truck rearend under it, it put the rear track even with the front or at least very close to it. Now with the narrower Caprice rear it's closer to how a stock truck is, even with the spacer/adapters. I also ground some out of the lug holes on some factory rally center caps to fit the 5.5-1/2" bolt circle.
Nice to now my truck is inspiring people
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 04-24-2012, 07:39 PM   #80
BabyBlue
The Peacemaker
BabyBlue's Avatar
I've always been partial to the wheel vintiques large diameter rally's. The link is for a website that shows retail pricing, I am sure you could get them for a little less from wheel vintiques, but you could choose any 7" center and they make them in 5x5 and up to 18" diameters.
http://www.davidsrallywheels.com/id105.html
http://www.wheelvintiques.com/index.php/products/
Also, stockton wheel offers a few options as well
http://www.stocktonwheel.com/
1978 Chevy 2wd Stepside
aka "Audrey"
Cordova brown with mandarin guts
79k original miles & being restored
1979 Chevy 2wd Short Wide
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
-2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB.
BabyBlue is offline   Reply With Quote
Old 04-24-2012, 09:16 PM   #81
my4by2
my4by2's Avatar
Sorry to "steal" your pic man, saw it on FB actually - but just really like the look & even commented on there about it too! Hadn't even thought of just re-drilling the front rotors - going with a set from SSBC along with their pads - maybe the even sell a 5x5.5 set that would work - hmmm....
Noticed that you had ground out the holes from a stock center cap in another pic. Was thinking of maybe modifying a stock Dodge truck center cap by machining out the center & installing a factory GMC center cap insert too.
Old 04-24-2012, 10:07 PM   #82
Conundrum
Conundrum's Avatar
No worries, it's cool I don't mind at all. Actually think it's pretty cool.
Yeah, I thought it was you on FB. One of my friends said something about maybe using a dodge cap, and the more looking I did after getting the caprice rear I noticed that with the rally caps these wheels look like the 9C1 cop car wheels just bigger.
Old 04-25-2012, 02:28 AM   #83
my4by2
my4by2's Avatar
Been researching more into using these wheels. Contacted a company I found online about maybe getting a set of front rotors made with the correct bolt pattern so I won't need to drill them or use a spacer.
Also found a set of factory Dodge black center caps that I like. Gotta find out if I can machine out the center to fit in a chrome GMC Acadia insert. Will keep at it & hope it all works out right!
Old 04-25-2012, 04:05 AM   #84
my4by2
my4by2's Avatar
That's a horrible pic of the center cap insert I want - this one does it a bit more justice. The lettering is also the same color I want the wheels to be.
Old 04-25-2012, 04:54 PM   #85
Conundrum
Conundrum's Avatar
That would look good
Old 04-26-2012, 11:25 AM   #86
monte0185
monte0185's Avatar
Originally Posted by roadrunner-europe View Post
Hi,
this rocks.
could you be my daddy?
My son (14) already asked me too, if he could have my truck, when he is 18.
Nice project. hold us up to date.
greeting
chris
My 12 year old had the same conversation with me only he want mine when her gets his license.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-26-2012, 07:55 PM   #87
Pyrotechnic
Pyrotechnic's Avatar
If these Dodge wheels go with the modern train of design on backspacing, I imagine they will be pretty sucked in to the wheel wells or even rubbing if you have the rotors and axles redrilled. The truck in the pic has adapters I believe, and the wheels are still pretty sucked in. I think adapters may actually be your friend here, and will leave you open to options other than Dodge/Ford wheels in the future if she wants a different look.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 04-26-2012, 08:31 PM   #88
my4by2
my4by2's Avatar
Yeah, may have a good point there... Definitely would like to fill the wheel wells as much as possible! Spacers would be the easiest way to go - just don't particularly like using them on the fronts if I can avoid it.
Old 04-26-2012, 09:24 PM   #89
my4by2
my4by2's Avatar
Lest we never forget that children must be spoiled equally - even though my Son does not have the interest in the kinds of vehicles I do, nor the desire to know how to work on them - he still gets his own perks...
Picking this up for him while I am home this time before he heads off to college (he graduates high school on the 25th of May) - got the new Motegi wheels on it, the windows tinted & a Magnaflow exhaust installed. Still waiting for the dual offest stripes to get installed before delivery on May 18th.
Once I get home we'll be installing a Steeda strut tower bar, a Boesch Built intake & an engine cover to dress it up a bit. At least that way he'll have his hands on it a little bit - who knows, maybe that'll spark something...
Old 04-26-2012, 09:25 PM   #90
my4by2
my4by2's Avatar
Those weren't supposed to be sideways.......
Old 04-26-2012, 09:41 PM   #91
ghettoluxury
ghettoluxury's Avatar
I too love the look of Conundrum's truck with the Dodge Steelies. A set powder coated red would look awsome on this truck.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 04-26-2012, 09:46 PM   #92
my4by2
my4by2's Avatar
Yep, that's my plan! Probably going to try to get a flat black stripe near the lip though just to break it up a bit - they are kind of large & that's a lot of "reddish-orange"...
Found a company that makes the spacers I need & have them in 1.3" I can use in the front & 2.0" for the rear!!!
http://www.ezaccessory.com/Wheel_Ada...000-5000-2.htm
Old 04-27-2012, 12:13 AM   #93
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Nice little pickup! Shes going to have an awesome first vehicle when ya'll get done with it.
1 vote for the steelies and NOS caps!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 05-02-2012, 10:06 PM   #94
my4by2
my4by2's Avatar
Talk about warming a Father's heart!!! Opened up Facebook this morning to find this little post by my Daughter:
"There's somethin bout' a truck...on a farmers feild(:"
The apple truly doesn't fall far from the tree! Thank you God for the gifts in my life!!!
Old 05-02-2012, 10:15 PM   #95
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I like that song.
Tony
Old 05-16-2012, 05:09 PM   #96
Conundrum
Conundrum's Avatar
The wheels have 5-3/8" of backspacing. If you go with a 4/6 drop or lower it's a good thing, if it's going to be higher than that I would go with the spacers/adapters. I don't have any issues with rubbing or contact on the backside of the wheels either.
Old 05-23-2012, 10:44 PM   #97
my4by2
my4by2's Avatar
And so it began!!!
My Daughter was sure itching to get started on all of this!!!
Old 05-23-2012, 10:47 PM   #98
my4by2
my4by2's Avatar
Got the bed off really easily luckily!
Put her to work cleaning off the frame right away & once I got the axle out she started grinding away!!!
Hoping we'll get the cleaning done tomorrow & start painting the frame & installing the lowering parts.
Leaf springs are going to the machine shop tomorrow for the bushing replacement & then some fresh paint for them as well.
Old 05-24-2012, 12:07 AM   #99
my4by2
my4by2's Avatar
Here's what her wheels look like right now - still gotta get the wheel powder coated to match the "GMC" color.
Old 05-24-2012, 08:53 AM   #100
J Knight
J Knight's Avatar
Those wheels are going to be sweet, but those shoes are questionable. LOL
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
