Old 01-12-2015, 09:26 PM   #76
ziplock
ziplock's Avatar
Re: 64 Build "The Titanic"
Originally Posted by Fleetsideboy64 View Post
Sent a PM, but wanted to check to see if you have plans for the BBW section of the extra cab (from post #65)?
I guess I should have just replied to your pm, I sent an e-mail to the address you listed in the msg. I had the cab listed on CL and it sold fairly quickly. My apologies.
ziplock is offline   Reply With Quote
Old 01-12-2015, 09:34 PM   #77
ziplock
ziplock's Avatar
More pictures of my progress.
Stripped the old frame. Swapped the crossmember over. Need to pull the lower control arms to cup them. Tomorrow I'm going cut the perches off the axle so I can move it over and get the frame out of the shop.
Here's how I left it today.
Old 01-12-2015, 11:33 PM   #78
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Dude you got game....nice thread...
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 01-13-2015, 12:52 AM   #79
NevEno
NevEno's Avatar
Sick! you got me thinking now. Ive got a extra 64 swb frame I might have to get my truck going then work on that frame!!
You can find me on Instagram @neveno_cten
NevEno is offline   Reply With Quote
Old 01-14-2015, 11:48 PM   #80
ziplock
ziplock's Avatar
Appreciate it!
Old 01-14-2015, 11:58 PM   #81
ziplock
ziplock's Avatar
Here's more. Swapped the axle over. Unfortunately I was off an half an inch when I mocked up the other axle. Going to have to put a half inch plate between the trailing arm an axle to allow the frame to sit on ground. The front is sitting on the bump stop perches. All an all is nice for now because it rolls.
Old 01-15-2015, 12:01 AM   #82
ziplock
ziplock's Avatar
Thanks man, having an spare frame is the way to go. I was working on this one for at least a month while still driving the other one. Best of both worlds. And when your finished, you still have a spare frame!
Old 01-15-2015, 09:40 AM   #83
Free Candy Inside
Really cool build
Free Candy Inside is offline   Reply With Quote
Old 01-26-2015, 11:35 AM   #84
ziplock
ziplock's Avatar
Making progress. Got my lowers cupped and installed. Bags finally installed on all 4 corners.
This is where I'm at now. Installed the engine to start building transmember and other crossmembers around the driveline.
Old 01-26-2015, 11:42 AM   #85
ziplock
ziplock's Avatar
Now I am no where near this stage in the build, But i had to see how it was going to look layed out. Looks sick!
As expected Ive got some clearance issues. I will need to build a tunnel the whole length of the cab to allow clearance for the drive line. I will also be looking for another set of tires. Even with the 1" forward on my Z the tires have about an inch between them and the firewall. Going to drop down from a 235/75/15 to a 205/75/15
Old 01-26-2015, 02:56 PM   #86
cheessee
Good looking build!!
cheessee is offline   Reply With Quote
Old 02-02-2015, 12:08 PM   #87
ziplock
ziplock's Avatar
I made a lot of progress this weekend. Frame is getting really close to being ready for powdercoat. I just need to fab up some rear shock mounts and my track bar. I will finish welding everything up when I disassemble the frame.
I have discovered a pretty big issue, witch I knew in the back of my mind would cause problems.
With my 3" Z and my Engine trans combo, My driveline now sits well above the frame frame rails.
I didn't take a picture but i set the cab on to test for clearance and the front cleared no problem. The rear hits the driveshaft about 2 inches before resting on its mounts. I guess i'm going to have to cut the back portion of the cab
Right below those spot welds is where i'm going to cut. I have a lot of thinking to do before hand. I will probably run an X brace from corner to corner inside the cab to keep it square. Then make the cut.
If this has been done and documented on the forum before please let me know. I'm open to anyone's opinion.
Old 02-02-2015, 08:11 PM   #88
cheessee
The doors any good on the 63? Needing a passenger side.. Lmk thanks
Old 02-08-2015, 07:54 PM   #89
ziplock
ziplock's Avatar
Cheessee, I sold the cab here locally on CL. The cab was shot, doors as we'll.
I was able to notch the cab fairly well. I am quite pleased with the turn out, unfortunately I forgot to smap a picture of the inside. Also knocked out my shocks this weekend. Here are some pictures.
Stuck the front fender on to see how it looked.
Also made an awesome deal on CL. Needed smaller tires. Traded my wheels and tires for a set of Powdercoated 15" smoothies and got a decent amount of cash along with um. Was out 100 bucks on a new set of 205/75s American Classics.
Pumped!
Old 02-08-2015, 07:55 PM   #90
ziplock
ziplock's Avatar
Old 02-08-2015, 07:56 PM   #91
Free Candy Inside
Love it. Things super cool
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Old 02-09-2015, 03:41 PM   #92
rickoner
Such a cool build!
How did you determine the angle to put the front lower control arms cups. I'm assuming that you'd want it parallel to the upper plate at full drop, right? How deep did you have to make yours?
Thanks, man. Keep up the great work.
rickoner is offline   Reply With Quote
Old 02-09-2015, 04:29 PM   #93
FrankyV8
Top notch frame work mister!! Gonna look wild when done. What's up with diesel engines I see lately?
FrankyV8 is offline   Reply With Quote
Old 02-12-2015, 10:42 PM   #94
ziplock
ziplock's Avatar
Thanks man, Your burb is awesome!
Originally Posted by rickoner View Post
Such a cool build!
Thanks a lot! I just studied pictures of what i thought others had done. I used two inch strap, Built the cups first. Layed them over the arms and traced. After i cut the arms I just layed the cups flush with the top of the arm. It worked out really well. Its square with the upper plate fully compressed.
Thanks a lot! I'm a big fan of the diesel engine, always wanted to put one in this truck. I was pumped when i found a decent one i could afford. The older mechanicel ones like this are also just so simple. There is really only one wire. 30mpg when i had the old 4 speed. Ive got an overdrive now. Theres not telling what it will get.
Old 02-12-2015, 10:56 PM   #95
ziplock
ziplock's Avatar
Here is the inside of the cab were I had to cut it. Its obviously way over built. I used what I had laying around and It will be hidden so whatever. Its stout! I built everything first and then cut the section out so nothing moved. Doors still open and close perfectly.
I knoked out my track bar this evening. Need to tackly steering tomorrow. I've got 3 of thoes little expensive U joints to play with.
Old 04-27-2015, 08:50 PM   #96
ziplock
ziplock's Avatar
Reassembly progress. Everything is going back together great.
Old 05-26-2015, 11:14 AM   #97
ziplock
ziplock's Avatar
Lots of progress. another engine overhaul. Installed a new Bosch VE injection pump and replaced all the gaskets, again. Hopefully I wont have any oil leaks this time. No inner finders yet so the hood is just sitting on the truck.
New turbo also.
Old 05-26-2015, 11:17 AM   #98
ziplock
ziplock's Avatar
Air system. Autopilot V2 is pretty sweet!
