Old 07-23-2014, 08:31 AM   #76
mcbassin
Still Learning
mcbassin's Avatar
Re: Project "Financial Burden": 1968 SWB C10
Excellent job on the radio fix.
mcbassin is offline   Reply With Quote
Old 08-25-2014, 08:36 PM   #77
Old_Truck_Fan
Thanks again for all the encouragement. I had some nasty dents in both of my doors that created a lot of distortion throughout the panels. I decided to re-skin them and this also gave me a chance to do a good repair on the door bottoms and near the lower hinge. As always more pictures...
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675
2011 Dodge Ram 1500
2012 Camaro ZL1
Old_Truck_Fan is offline   Reply With Quote
Old 08-25-2014, 08:41 PM   #78
Old_Truck_Fan
More pictures...
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 08-25-2014, 08:56 PM   #79
Xeen
Xeen's Avatar
Wow man you have some serious metal working skills.
I hope I am that good one day.
P.S. It just occurred to me that I say the same things over and over every time I comment on this build but I can't help it because I'm just damn impressed with the craftsmanship.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-26-2014, 03:44 PM   #80
BigDaddyV
BigDaddyV's Avatar
Just foud your build and Wow, killer skills!
I'm along for the ride.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 08-26-2014, 06:10 PM   #81
knomadd
knomadd's Avatar
I'm joining in now too. Great work so far.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-26-2014, 07:00 PM   #82
tommys72
tommys72's Avatar
Nice work man. .. looking good
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 08-28-2014, 08:40 AM   #83
mcbassin
Still Learning
mcbassin's Avatar
Excellent work on the door repairs. Looks great!
Old 08-28-2014, 10:22 AM   #84
HSRACER
HSRACER's Avatar
I have never wanted to do any type of bodywork in the past, but with your pictures and detailed technique that may change in the future! Thanks
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 10-14-2014, 07:42 PM   #85
Old_Truck_Fan
Thanks again for the comments. I can almost see the finish line for the cab metal work. Here are some pictures of how I smoothed out the firewall with parts from Porterbuilt and Infanti Machine.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 10-14-2014, 08:00 PM   #86
Xeen
Xeen's Avatar
Nice work it looks great.
Old 10-15-2014, 12:19 PM   #87
mcbassin
Still Learning
mcbassin's Avatar
Firewall looks great!
Old 10-15-2014, 12:21 PM   #88
BigDaddyV
BigDaddyV's Avatar
Nice work!
Old 01-02-2015, 08:19 PM   #89
Old_Truck_Fan
I finally have some new updates to pass along. I bought a stud welder for fixing some of the random dents located on the cab that I could not back up with a dolly. I experimented on a few pieces of sheet metal and found that the best results are when you pull and release the trigger as fast as possible. The stud has adequate connection and it makes removal much easier. Holding the trigger down any longer than mentioned only makes it more difficult to remove the stud and increases the heat you put into the panel.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 01-02-2015, 09:00 PM   #90
KMC3420
KMC3420's Avatar
What stud welder did you buy?
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 01-02-2015, 09:04 PM   #91
Old_Truck_Fan
I also found some rust lurking underneath the dash that was quite a challenge to repair. I had to make a few custom panels with the most difficult one taking the shape of a potato chip. I was able to form it by hand with some patient work with the hammer, dolly, shrinker, stretcher and using one of the cylinders on my slip roller. Hopefully I can test fit the cab on the frame soon.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 01-02-2015, 09:07 PM   #92
Old_Truck_Fan
H & S Auto Shot 4550.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 01-02-2015, 09:27 PM   #93
KMC3420
KMC3420's Avatar
Also what grit roloc disc do you use to knock your welds down? Nice job on the repairs.
Keagan
Old 01-02-2015, 09:37 PM   #94
ckcp
grate build so far. awesome and very clean metal work keep it up
ckcp is offline   Reply With Quote
Old 01-02-2015, 11:17 PM   #95
mooseknuckles
mooseknuckles's Avatar
Nice work!
mooseknuckles is offline   Reply With Quote
Old 01-02-2015, 11:35 PM   #96
68Gold/white
Look'n Good Billy Ray!!!
Have you found and engine yet???
Any pictures of the door skin job???
68Gold/white is offline   Reply With Quote
Old 01-03-2015, 10:30 AM   #97
Old_Truck_Fan
I use 3M Green Corps Roloc Disc, 36 grade, 2 inch, PN 01397 to knock down most of the weld and then follow up with 50 grade, PN 01396 to finish sanding. However, recently I have started to use 3M Cubitron II Fibre (purple color) Roloc Disc, 2 inch, 36+ grade, PN 33377 and 60+ grade, PN 33379. They are more expensive but last a lot longer.
I also use Scotch-Brite Roloc Surface Conditioning Disc, 2 inch, Medium, PN 07481 to prep the surrounding metal and to give everything a common texture once I have completed a repair.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 01-03-2015, 10:36 AM   #98
Old_Truck_Fan
I’m still thinking on the direction I want to go on the engine. I have a 5.3L truck engine I am going to use for mock up until I get things finalized.
I’m waiting to have the door shells media blasted and primed before I hammer on my new door skins. Hopefully sometime in early spring I’ll have the doors back together.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 01-03-2015, 11:12 AM   #99
KMC3420
KMC3420's Avatar
I am going to try the purple 60 you suggested. I use the 50 grit now, it's a bit rough at times. Thanks for the part #'s. I am seriously considering the spot welder also. The price on it seems pretty good.
Keagan
Old 01-04-2015, 08:01 PM   #100
RodnRudy
RodnRudy's Avatar
I've got rust under the passenger side of the fire wall as well. After seeing your patch panel work, It shouldn't be as hard to do as I thought. Your workmanship is excellent. Glad I came across this build thread, subscribed.
RodnRudy is offline   Reply With Quote
