Old 12-01-2012, 07:09 PM   #76
jhrusk
Re: SANFORD build thread
Its been a while since I posted, but I have made a little progress.I recieved my new axles from Moser,also took some pics of my headers and h-pipe after I cleaned and painted them. I used rustoleum high heat paint so I have my fingers crossed that they will hold up. My last pick is a swap meet score from today, I wasnt looking for another grill but sometimes you cant pass them up, it is not perfect but it is in very good shape.Name:  12-1-12 (7).jpg
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 12-01-2012, 08:06 PM   #77
gimmy 64
that is very smart to put the header flanges on the pipes incase you have to remove your tranny .where did you get the flanges?
gimmy 64 is offline   Reply With Quote
Old 12-01-2012, 09:00 PM   #78
Jmorales3181
Jmorales3181's Avatar
Truck is coming out beautiful! Really nice work
Jmorales3181 is offline   Reply With Quote
Old 12-02-2012, 01:22 AM   #79
Dinos63
chevy only
Dinos63's Avatar
nice score on the grille! glad your back
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 12-02-2012, 09:58 AM   #80
jhrusk
I finally finished the frame and got it painted, I didnt realize I would have this much time into this frame but it turned out well. I hope to start assembly soon. Thanks for lookind guys.Name:  12-1-12 (4).jpg
Old 12-02-2012, 12:08 PM   #81
Dinos63
chevy only
Dinos63's Avatar
very nice!!
Old 12-03-2012, 11:55 AM   #82
Desert.Chevy
Desert.Chevy's Avatar
Cool pictures, Nice build.
Desert.Chevy is offline   Reply With Quote
Old 12-08-2012, 05:09 PM   #83
jhrusk
Small update from this week,got most of the front suspension cleaned and painted. Installed for the last time. Also got the engine and transmission installed.hope to continue to make progress.Name:  12-8-12.jpg
Old 12-08-2012, 05:35 PM   #84
mark 66
very clean. liking that rack.how bout some pics of that.ooops saw them on earlier post
mark 66 is offline   Reply With Quote
Old 12-14-2012, 06:39 PM   #85
jhrusk
A few updates from this weekName:  12-14-12.jpg
Old 12-14-2012, 09:29 PM   #86
Dinos63
chevy only
Dinos63's Avatar
very nice!! nailed it on the wheels
Old 01-03-2013, 08:40 PM   #87
jhrusk
I wanted to post an update on my progress,I have been steadily making progress.Just about have the chassis finished just getting all the brake lines ran along with fuel lines.Really trying to make it in time for the power tour.Thanks for looking.Name:  1-2-13.jpg
Old 01-03-2013, 09:02 PM   #88
jhrusk
I decided to run a flex line at the front of the trailing arm in order to ease the trouble of removing tires,I have to unbolt the air bags and drive shaft to drop the rear enough but I should not have to take the brake lines loose.Name:  1-3-13 (3).jpg
Old 01-04-2013, 02:01 AM   #89
hemifalcon
I like how you ran your brake line down the trailing arm rather than along the frame all the way rearward.. Or, was your truck originally plumbed this way? My Suburban had the hardline go all the way back to just over top of the rearend with the flex hose running downward to the "T" on the axle housing..
Looks very nice.
hemifalcon is offline   Reply With Quote
Old 01-04-2013, 08:27 AM   #90
jhrusk
hemifalcon it originally ran to the back and down with a flex line,I changed it to help with removing rear wheels
Old 01-04-2013, 01:45 PM   #91
Dinos63
chevy only
Dinos63's Avatar
always such nice work very clean!
Old 01-04-2013, 02:00 PM   #92
McMurphy
McMurphy's Avatar
Oh yeah, I like that flex line mounting point for the rear brakes a lot better than the standard spot at the trailing end!!
Though I must admit I had to look at your photo a few times to realize what I was looking at and why it was important !!
Nice mod I would consider doing for any build.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 01-05-2013, 02:19 AM   #93
hemifalcon
check--- make sense since you're going to be so low with your body over the wheels.. I forget that airbags can't open up or "stretch" that far.. Good idea..
Old 01-13-2013, 10:31 AM   #94
jhrusk
got most of the chassis assembled,the exhaust is completed and installed.a little bit at a time.Name:  1-12-13.jpg
Old 01-13-2013, 10:48 AM   #95
williamsboys
williamsboys's Avatar
Wow. Great work looks awesome
williamsboys is offline   Reply With Quote
Old 01-13-2013, 11:22 AM   #96
Desert.Chevy
Nice progress. Looking good.
Old 01-13-2013, 12:00 PM   #97
Dinos63
chevy only
Dinos63's Avatar
outstanding work! so clean and the exhaust is killer
Old 01-13-2013, 01:55 PM   #98
jhrusk
Thanks guys for the comments,I was having excessive camber change when I get the truck low,It always bothered me so I decided to make some new upper a-arm mounts.I moved the upper mounting point up around 2 inches and it really made a world of difference. I had mybe a 1/2 degree of camber change through the range of suspension travel that the truck will spend its time in.Anyone looking to lower a truck a lot I think would be best to get a Porterbuilt crossmember but if you have more time than money you can build something similar to this.I dont have a lot of money in it but I have a huge amount of time in it.Name:  1-12-13 6.jpg
Old 01-13-2013, 02:01 PM   #99
jhrusk
with the exception of the front sway bar I will call the chassis finished.I have moved on to the cab so I will post pics of it as I make progress.Name:  1-12-13 11.jpg
Old 01-13-2013, 05:15 PM   #100
Corts60
Just here to tinker
Corts60's Avatar
That is some gorgeous work right there. Well done!
