Old 07-22-2012, 04:09 PM   #76
63split
63split's Avatar
Re: Dutch 1955 build
last week added the brake rotors and calipers
and this weekend made some progress on the fuel tank
welded it up and made a filler hole and another one for the fuel sender
made some brackets
to attach it to the chassis
63split is offline   Reply With Quote
Old 07-22-2012, 07:04 PM   #77
oldman3
oldman3's Avatar
Very nice....Jim
oldman3 is offline   Reply With Quote
Old 07-23-2012, 02:25 AM   #78
Kim57
Kim57's Avatar
Looking real sharp.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-23-2012, 02:25 PM   #79
El Campo
El Campo's Avatar
The fuel tank is hiding that beautiful 9 inch! Haha jk, it looks great all the same
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 07-28-2012, 10:38 AM   #80
poncho_villa
poncho_villa's Avatar
Any further progress and fresh pictures?
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 07-28-2012, 12:31 PM   #81
Lextech
Lextech's Avatar
Could you post up some pics of how you cut the holes in the frame. I know you pressed the bevel in them---But, what made the hole?
Jeff
Lextech is offline   Reply With Quote
Old 07-28-2012, 01:06 PM   #82
63split
63split's Avatar
Jeff
i have cut the holes with a plasma cutter this machine make's live so much easier
Old 07-28-2012, 01:13 PM   #83
63split
63split's Avatar
not much progress made this week, only made a fitting in fuel tank for the fuel line
Old 07-30-2012, 12:05 PM   #84
63split
63split's Avatar
put on the boddy, bed and rear fenders for further measurements
Old 07-30-2012, 12:31 PM   #85
OrrieG
OrrieG's Avatar
Looking good, in my mind I had the gas tank oriented 90 degrees from where you have it installed; rolled ends front and back for aerodynamics and to transition up into the bed when viewed from behind.
If you google metal hole dimple a bunch of links come up for punchs and dimplers, manual and for hydralic presses.
OrrieG is offline   Reply With Quote
Old 07-30-2012, 01:33 PM   #86
oldman3
oldman3's Avatar
Mock up looks good....Jim
Old 07-30-2012, 03:33 PM   #87
Kim57
Kim57's Avatar
Yeah that looks like a truck now.
Kim
My build thread
Old 07-30-2012, 05:42 PM   #88
63split
63split's Avatar
yes your right it would have been better
but i was limited on the width of my slip roll (25 inch)
now i ended up with a larger volume tank
the truck will get stock chrome bumpers and to hide the tank i will probably make a roll pan
Old 07-30-2012, 08:27 PM   #89
hotrod1
56 - autocross
hotrod1's Avatar
I am curious about the roll pan. Many of them out there look like an after thought to the truck.
hotrod1 is offline   Reply With Quote
Old 08-01-2012, 05:40 PM   #90
63split
63split's Avatar
i will try to make a nice roll pan....
but first put on the front fenders to figure out what size wheels to go with
figured 18x8 4'' backspace at the front and a 18x12 6.75 or 7'' back space in the rear
Old 08-01-2012, 07:27 PM   #91
poncho_villa
Good progress. Nice with that open air roof. What are you going to do when it rains? Just kidding!! I see lots of other Chevy products in the background of your pictures. You should tell us about them in a separate thread and post the link to it here. That Chevy panel and the suburban look interesting.
Old 08-04-2012, 11:07 AM   #92
63split
63split's Avatar
today did some more mockup stuff
lokar shifter and steering column, and figured out in need 3 u joint for the steering shaft
cut a piece out of the firewall to clear the head
test fitting the radiator its pretty close
Old 08-04-2012, 11:19 AM   #93
Kim57
Kim57's Avatar
Looking good.
That is pretty close.
Kim
My build thread
Old 08-04-2012, 11:35 AM   #94
63split
63split's Avatar
yep but i will mill off the button a bit to give it more clearance
here on request of poncho_villa
this is the 55 panel from my dad
we are going to a us car saturday night cruise in a few minutes
here a 50 truck from my uncle
Old 08-04-2012, 02:09 PM   #95
poncho_villa
Very Nice.
I also had to put an electric pusher fan on the front and a small puller fan at the top corner of the inside.
Old 08-04-2012, 02:20 PM   #96
oldman3
oldman3's Avatar
Nice rides....Jim
Old 08-11-2012, 11:38 AM   #97
63split
63split's Avatar
i have been playing around with the bake booster and master cilinder set up
and made a underdash setup
i had a complete set for the original location under the floor,
instead of buying an universal under dash bracket (that you need to adjust) i figured i could build one myself,
Old 08-11-2012, 01:12 PM   #98
Kim57
Kim57's Avatar
Nice work on the brake booster. I thought about putting mine under the dash but didn't want to deal with the reservoir.
Kim
My build thread
Old 08-11-2012, 01:21 PM   #99
63split
63split's Avatar
Kim
i know it will be a pain to fill or check the fluid but its almost the same
as an under floor setup .
Old 08-11-2012, 03:21 PM   #100
coulter
coulter's Avatar
awesome build so far man!!! you do amazing work!!!
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
