Old 02-25-2014, 11:49 AM   #76
48ChevBagged
48ChevBagged's Avatar
Re: You guessed it, 1950 s10 swap.
Looks awesome. Wait till you drive it then you will really be glad you made the swap. The LS throttle response is amazing and also feels like it has twice the power over a carbed 350. I just pulled an old wore out 350 carb setup from my suburban and swapped in a 5.3 with a 4l60e trans. What a huge difference. Not to mention the fuel economy should increase as well.
48ChevBagged is offline   Reply With Quote
Old 02-25-2014, 02:45 PM   #77
918733
what did you have to do to use a car intake with truck accesories?
918733 is offline   Reply With Quote
Old 02-25-2014, 07:24 PM   #78
Layedoutsonoma91
Layedoutsonoma91's Avatar
To use the car intake you gotta have the intake of course, need fuel injectors and rails from a car. Need an idler pulley relocator from dirty dingo. For driveby wire throttle you need a car water pump and dirty dingo water pump spacers. The plugs on the injectors from the harness are different. You can get adapters or buy the right connector and splice it on.
1954 Chevy 3100 5 window, bagged on s10 frame,
6.0 ls swap/4l80e
Past build thread
http://67-72chevytrucks.com/vboard/s...=531261&page=3
1949 3100 s10 swap 5.3.
Instagram -@thejcates
Layedoutsonoma91 is offline   Reply With Quote
Old 02-25-2014, 07:34 PM   #79
Layedoutsonoma91
Im really excited to find out! I plan to drive it alot and carb was not gonna be as practical anyway.
6.0 ls swap/4l80e
Past build thread
Old 02-28-2014, 02:27 PM   #80
Root2812
Root2812's Avatar
This is the exact set up I'm using except my parts are still in boxes on the garage floor. I'm looking forward to seeing your clearances.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 03-01-2014, 09:58 PM   #81
Layedoutsonoma91
So far so good. Only issue I had that was not for seen was the power steering pulley. It hit my steering box pretty bad. Had to order Dirtydingo.com smaller diameter pulley. I have sent them a lot of dough haha. I will post pictures of the pulleys once I get the brackets back from powder coating.
6.0 ls swap/4l80e
Past build thread
Old 03-07-2014, 10:10 PM   #82
Layedoutsonoma91
smaller pulley
Computer under dash
Wires feed thru nice and hidden.
Firewall was done in raptor liner. Looks nice in person
6.0 ls swap/4l80e
Past build thread
Old 03-07-2014, 10:39 PM   #83
youngrodder
youngrodder's Avatar
Looks great. I like how the firewall looks with rhino liner applied to it.
I also like how you took your time to hide wires and the computer.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 03-08-2014, 01:28 AM   #84
Layedoutsonoma91
Well it all pales in comparison to your awesome build. I read every page of it. Love your 48 and got the burb lookin good too! Just a little jealousy here hahaha.
6.0 ls swap/4l80e
Past build thread
Old 03-09-2014, 10:49 PM   #85
Root2812
Root2812's Avatar
That looks great. I'll have to order that pulley when I order my waterpump spacers from Dirty Dingo.
My 1950 Chevy build
Old 03-10-2014, 04:48 PM   #86
Layedoutsonoma91
If you are not on an s10 frame im not sure if you will need it or not.
6.0 ls swap/4l80e
Past build thread
Old 03-26-2014, 04:16 PM   #87
Layedoutsonoma91
Got the motor running!!
Will run a lot smoother when i get the exhaust on it and 02 sensors in. Just a heads up for anyone doing an ls swap with used injectors. Depending on how long the injectors have sat up. I had to boil mine on the stove for 2-3 minutes to get them to work. Seems to be a common problem. Anyhow. Video below of the motor and gauges
First start on my LS swapped 1950 Chevrolet: https://youtu.be/P-mUDeJ9RpI
Dakota digital VHX gauges for 47-54 Chevrolet.: https://youtu.be/arNWmdmaWjA
6.0 ls swap/4l80e
Past build thread
Old 03-26-2014, 09:17 PM   #88
99 to Life
99 to Life's Avatar
cool man, thanks for sharing. gonna be one bad ride.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 03-26-2014, 11:09 PM   #89
youngrodder
Nice work...
Marc
Old 03-26-2014, 11:44 PM   #90
oldman3
oldman3's Avatar
Nice job....Jim
oldman3 is offline   Reply With Quote
Old 03-29-2014, 12:31 AM   #91
tlorber
tlorber's Avatar
Layedout, looking sweet! Would you happen to have any pics of your tranny crossmember? I need to either fabricate or find one that will work on the LS/4l60.
tlorber is offline   Reply With Quote
Old 04-04-2014, 11:21 AM   #92
Layedoutsonoma91
6.0 ls swap/4l80e
Past build thread
Old 04-04-2014, 11:21 AM   #93
Layedoutsonoma91
I took a piece of 2x2 and welded tabs to the frame to bolt thru.
6.0 ls swap/4l80e
Past build thread
Old 04-04-2014, 12:25 PM   #94
tlorber
tlorber's Avatar
Beautiful, thanks. That's exactly what I was looking for. The cross member location is right at that point where the frame curves out and down so there are a few things going on in the same spot.
Old 04-24-2014, 10:21 PM   #95
Layedoutsonoma91
6.0 ls swap/4l80e
Past build thread
Old 04-24-2014, 10:23 PM   #96
Layedoutsonoma91
Seat is a little too high. Gonna redo the seat brackets. Seat is red because i planned to paint the truck, but the patina looks too cool to cover up! Red don't match the green but i got a green mexican blanket i might use to cover it. here is the blanket. Decisions.....
if i use the blanket i will have it pulled tight and clipped
6.0 ls swap/4l80e
Past build thread
Old 04-24-2014, 11:07 PM   #97
99 to Life
99 to Life's Avatar
looking badass man, can't go wrong with serape blanket and patina. Steering linkage looks top notch.
Old 04-24-2014, 11:46 PM   #98
Layedoutsonoma91
Thanks man, Those steering joints were a ton of money. Wasnt expecting to dump so much money on such a little part. Blanket will match the truck better. Red seat just looks so good!
6.0 ls swap/4l80e
Past build thread
Old 04-25-2014, 08:52 AM   #99
youngrodder
Looks great. I remember someone on this forum used the simular seat and they cut a section out of the seat mount and rewelded it. You could not even really tell after that it was sectioned.
Keep up the good work.
Marc
Old 04-26-2014, 10:01 AM   #100
99 to Life
99 to Life's Avatar
oh yeah, I was gonna ask you about the price. Those things are waaay overpriced, my friend just paid like $90 for one. I'v seen them much cheaper, still def those little nickel and dime parts you never expect. One of the LS swap down falls for sure, but its worth the little extra effort. The rack setups with IFS man that looks like a nightmare to do. I like your set up, pws on the s10 is def easier to get your steering linkage to.
