Old 01-03-2014, 05:11 PM   #76
mcbassin
Still Learning
mcbassin's Avatar
Re: 81 K5 "Arctic Blaze" H.O. 5.3 / SM465 swap
Awesome blazer and engine swap. Thanks for sharing.
Did you use the 5.3/4.8 accessories or the LS1 ? thanks
mcbassin is offline   Reply With Quote
Old 01-03-2014, 07:28 PM   #77
whitels1
whitels1's Avatar
Thanks. I ended up using the truck accessories.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 01-04-2014, 02:22 AM   #78
mcbassin
Still Learning
mcbassin's Avatar
So all you had to do was remove some material from the water pump? Are there any other modification?
Old 01-04-2014, 09:29 AM   #79
whitels1
whitels1's Avatar
I also had to trim the truck bracket, and relocate the idler pulley to clear the car intake. I used the dirty dingo kit.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 01-04-2014, 10:58 AM   #80
Eric15chevys
Eric15chevys's Avatar
Nice thread you have some really great pictures. I have been thinking about swapping my blown big block in my 84 4x4 one ton for a 5.3 or 6.0. It is nice to see the mounting with the trans since mine is a 465. I have a 5.3 4L60e but is is slated for my 62 2wd. So I might just have to get a 6.0 that a friend of mine has.
84 GMC One ton 4x4 454 4 speed
62 Chevy C10 short fleet
plus about 13 previous gm trucks
from 1960 to 2000
Eric15chevys is offline   Reply With Quote
Old 01-04-2014, 11:19 AM   #81
whitels1
whitels1's Avatar
Thanks! You won't regret it!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 01-13-2014, 01:18 AM   #82
whitels1
whitels1's Avatar
Well all I can say is that I love my LS swapped truck!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 01-13-2014, 12:18 PM   #83
mcbassin
Still Learning
mcbassin's Avatar
www.youtube.com/watch?v=xZoSv9WD2zA
Dang that looks like fun!
Old 01-28-2014, 09:53 PM   #84
Stepped71
How did the vss situation go? Was you able to tune it out? Im fixing to do a swap very similar to yours except its a 465/208 combo. An im having trouble finding out if a vss is a must. I know dakota digital makes a adapter but if i can save some cash itd be nice. Thanks.
Stepped71 is offline   Reply With Quote
Old 01-29-2014, 01:17 AM   #85
whitels1
whitels1's Avatar
I had my tuner tune it out and hooked my speedo cable to the 205, works good.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 02-18-2014, 04:00 AM   #86
whitels1
whitels1's Avatar
Rock crawling video!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 02-18-2014, 10:33 AM   #87
MTCK
MTCK's Avatar
Nice freak'n driving!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 02-18-2014, 10:48 AM   #88
mattcrp1
mattcrp1's Avatar
Great build, did I miss it or did you ever hook up the EVAP system?
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-18-2014, 05:06 PM   #89
whitels1
whitels1's Avatar
I did the same as a 99 fbody, evap canister, vent valve and purge solenoid, seems to be working good.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 02-21-2014, 05:31 PM   #90
lytemup454
lytemup454's Avatar
why did you go with an evap system?
lytemup454 is offline   Reply With Quote
Old 02-22-2014, 12:27 AM   #91
whitels1
whitels1's Avatar
So the tank would vent properly and not stink up my garage.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 06-09-2014, 01:19 AM   #92
whitels1
whitels1's Avatar
Video update... Removing the drive train to start a new project!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 06-09-2014, 08:51 AM   #93
MTCK
MTCK's Avatar
Cool, looking forward to the k10 project.
-Marcus
Project Plow Truck
Old 06-14-2014, 02:04 PM   #94
whitels1
whitels1's Avatar
The K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=631930
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 06-16-2014, 01:50 AM   #95
woodwright
Enjoying left field
woodwright's Avatar
Is there some more info on the evap system? I modified my tank for the same type of module, and I'm not sure what to do with that part.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 06-17-2014, 10:01 PM   #96
whitels1
whitels1's Avatar
I have mine set up like a 99 f-body. You need to have an evap tank, vent valve and purge solenoid.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 08-17-2014, 07:00 PM   #97
whitels1
whitels1's Avatar
One last video to close things out with The Arctic Blaze...
Enjoy the video!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
