Old 02-11-2013, 11:28 PM   #76
K5 Addiction
K5 Addiction's Avatar
Re: The Old Duffer
Originally Posted by boucher racing View Post
dammit boy! looks great. I like the sneaky routing of the vacuum adv. hose.
Ha thanks man! Grant does excellent work.
K5 Addiction is offline   Reply With Quote
Old 02-12-2013, 06:52 PM   #77
paintman
Re: The Old Duffer
Originally Posted by K5 Addiction View Post
Hey Paintman, I'm using a 1961 Schlitz 15 & a half gallon keg. It's been fitted with a fuel sending unit that works with the stock gauge. The fuel pump is an electric one that comes with the F.A.S.T. fuel injection setup. It's controlled by the computer.
First off your motor looks amazing!!!!!!! I am also doing a 250 for my 46, and looking at a similar carb setup. I was under the impression that these TBI carbs needed anti slosh baffles within the fuel tank. I was also concerned about the electric fuel pumps. I have heard horror stories about them being unreliable and noisy. Hopefully you will keep us posted on your experiences. And in the meantime I have shot you a pm in regards to T. Lowe
paintman is offline   Reply With Quote
Old 02-13-2013, 12:15 PM   #78
K5 Addiction
Re: The Old Duffer
No notes about needing a baffled tank in the literature. Guess I'll find out soon. Firing it up today.
Old 02-13-2013, 12:20 PM   #79
K5 Addiction
Re: The Old Duffer
Here's some exhaust shots. Had to run under the axle for now till I raise my bed a couple inches. (strangely when I upload these pics there getting turned around but you get the idea)
Old 02-14-2013, 09:01 PM   #80
flips72
flips72's Avatar
Re: The Old Duffer
extremely nice work, cant wait to see the dyno sheet, let us know how the fast injection works out for you, i have been consdering it for mone as well.
flips72 is offline   Reply With Quote
Old 02-15-2013, 06:50 PM   #81
K5 Addiction
Re: The Old Duffer
Well had a setback today, Would been on the road tonight but my Pertronix distributor's cap took a **** on me & there is not a corresponding parts store cap that I can find anywhere. I'm dead in the water till Tuesday when I can get one delivered. Huge bummer! Was looking forward to burnin some petrol.
Old 03-04-2013, 06:56 PM   #82
paintman
Re: The Old Duffer
Any updates??????????????????????????? I'm curious as to how that 250 runs with the TBI carb!
Old 03-13-2013, 11:10 PM   #83
K5 Addiction
Re: The Old Duffer
Been awhile since I updated, It's been a frustrating couple weeks since the distributor cap mishap. Took awhile to get the new cap. Reinstalled & couldn't get the truck to fire at all & I've got a pro fuel injection tuner working on this. started checking everything Fuel pump, spark, computer I mean everything twice then got to checking to see if something bigger was wrong (internal engine issues) did a compression test & found 4 out of 6 cylinders had abnormally low PSI. We started wondering if the backfires caused by the cap problems hadn't caused some damage, Maybe blew a hole in a piston or something. so we pulled the head & found the head gasket blew between 2nd & 3rd & 4th & 5th cylinders. Ughh! sent the head to be checked for cracks or other issues & it's all good. Reinstalled everything truck fired right up. tuned & now touching up paint. It's running pretty good now. They say the computer will constantly be tuning & will run better all the time. Plan on driving it a bunch this weekend so I'll keep yall posted.
Old 03-14-2013, 03:48 PM   #84
CRGRS 66
CRGRS 66's Avatar
Re: The Old Duffer
pheeeew, could have been a lot worse...
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 03-14-2013, 07:22 PM   #85
paintman
Re: The Old Duffer
Man I have so many questions in regards to your carb setup, but that's not important right now. The biggest question is where did all the gasket pieces go from the front cylinder? Hopefully out the exhaust!
Old 03-14-2013, 07:54 PM   #86
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: The Old Duffer
Very nice truck. What a big differance between the red and blue. Great choice.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 03-14-2013, 08:05 PM   #87
hemifalcon
Re: The Old Duffer
Wow... Seeing as I'm not some huge engine junkie.. What caused that to occur to the head gasket??
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline   Reply With Quote
Old 03-15-2013, 11:48 AM   #88
K5 Addiction
Re: The Old Duffer
& found one more reason its been hard to get the motor timed right. A brand new harmonic balancer was slipping on the rubber.
Old 03-15-2013, 08:24 PM   #89
K5 Addiction
Re: The Old Duffer
Got the new Balancer on got it pretty close to timed. Still need to fine tune the distributor, it's got a small catch around 2500 RPM's. I've been driving it for the last couple hours. It's fun! The computer is still learning exactly what the motor wants & adjusting the advance curve will cure the small hiccup but overall it's running pretty well. Laid a bout 45 yards of scratch.......It was a one tire fire but it was something. The new motor highlights the fact that my suspension need updating. Here's a video of it running.
Old 03-15-2013, 08:25 PM   #90
K5 Addiction
Re: The Old Duffer
Well I guess not. I'll have to figure out how to post the video.
Old 03-15-2013, 09:12 PM   #91
Bomp
Bomp's Avatar
Re: The Old Duffer
Glad you got things worked out.
Bomp is offline   Reply With Quote
Old 03-15-2013, 10:34 PM   #92
edub981
Re: The Old Duffer
Your Old Duffer is quite a ride. Its nice to be able to continue the work your granpa started. You have turned the corner with that color combo. Whities with blue wheels makes it look real classy. I like your like your idea with the hidden ipod connector. It's nice to keep that stock dash look. Nice work.
edub981 is offline   Reply With Quote
Old 03-16-2013, 11:26 AM   #93
K5 Addiction
Re: The Old Duffer
Here's a link to a video of the truck running. http://youtu.be/5SducP4Ky8I Check that exhaust note.
Old 03-16-2013, 04:27 PM   #94
boucher racing
boucher racing's Avatar
Re: The Old Duffer
Damn Boy! If you would filmed that video from the back to front, I woulda swore that you were packing a V8!!
Sounds great.
Boucher'
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 03-18-2013, 05:23 PM   #95
flips72
flips72's Avatar
Re: The Old Duffer
i agree, it does sound like a v8, and man it looks great. are you happy with the fast set-up? i am wanting one bad for mine, just aint got the funds.
Old 03-23-2013, 11:12 PM   #96
K5 Addiction
Re: The Old Duffer
Thanks guys. Had another setback. Finally got out to put some miles on & the second day out lost most of my oil pressure. Shut it down right away. Investigating the cause. Think it's the oil pump or maybe the oil pump pickup came off. I hope that's it. Been pretty frustrating. On an up note My truck is gonna be on "My Classic Car" with Dennis Gage tomorrow on Speed Channel. Pre new motor install. Let's just say this episode is smokin.
Old 03-24-2013, 12:47 AM   #97
Bomp
Bomp's Avatar
Re: The Old Duffer
Congrats on the tv spot.
Thats totally.
Sorry to hear of the frustrating oil delema.
Old 04-06-2013, 11:09 PM   #98
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: The Old Duffer
I would love ta see ya do a burn out onto the highway with that thing! I wish mine was just like it. And not knowing that your motor was a 250 I told you I had the same motor, but I actually have a 292. Not much different. What horse and torque you think your makin out a that motor? Probably a lot! Thanks, T.J.
TJ's Chevy is offline   Reply With Quote
Old 05-07-2013, 11:03 AM   #99
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: The Old Duffer
Hey k5,
Hows your motor coming? Hope you were able to find out what was wrong with your oil pump. thanks. T.J.
Old 05-07-2013, 10:12 PM   #100
McMurphy
McMurphy's Avatar
Re: The Old Duffer
Any chance your TV Spot made it on to YouTube?
Would sure like to see it !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
