Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 05-20-2013, 10:05 AM   #76
wade_ab
wade_ab's Avatar
Re: 1969 k10 lwb to swb, 1 tons, 6.0/4l80e/np205
a few more
69 k10 - In pieces
wade_ab is offline   Reply With Quote
Old 07-05-2013, 09:29 AM   #77
72sbchevy
After hours of research I decided to go with the skyjacker 8 inch springs for my build. I have a set of 6 in tuff country springs that rode well also.
72 c10 frame off- put on hold
72 cheyenne 20 super -under construction
72 k10 short bed 6 inch lift- under construction
79 gmc 1 ton 4x4 plow truck
72sbchevy is offline   Reply With Quote
Old 07-05-2013, 10:04 AM   #78
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Good looking build hows the new business venture going?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-08-2013, 10:25 AM   #79
wade_ab
wade_ab's Avatar
Its getting there, its a slow process. I've got just about everything picked out and my shop location. I'm just waiting on the bank and financing. I haven't got to sand anything in a while i'm having withdrawals
69 k10 - In pieces
Old 07-08-2013, 10:27 AM   #80
wade_ab
wade_ab's Avatar
Do you have any pictures with of your truck with the 8" lift on it?
69 k10 - In pieces
Old 09-02-2013, 08:55 AM   #81
mx289
mx289's Avatar
Originally Posted by wade_ab View Post
Here is an update. I finished shortening the LWB bed to a SWB. So lots of cutting welding sanding going on.
awesome build you got here..Had some questions for you about how you decided where to cut the bedsides..I might try that on mine as well..I'am kinda unsure on where to cut mine..Did you cut 12" and 8",just like the frame..?..
mx289 is offline   Reply With Quote
Old 09-02-2013, 11:14 AM   #82
wade_ab
wade_ab's Avatar
Mx289, yeah I cut 12 from the front and 8 from the back. I tried to just find a place where the body lines were the straightest that way when I put it together it would be less body work and blending. The rear was easier than the front because the front top body line is at a sharper angle towards the cab. It took me longer to blend the body work and get that line straight. If I was to do it again I think I would cut the front section out as close to the cab as I could that way body work would be less. I also had trouble cutting the Interier bed walls on the same line as the outer. I tried several different methods but ultimately ended up with gaps I had to weld metal back into to cover.
69 k10 - In pieces
Old 09-03-2013, 08:02 PM   #83
mx289
mx289's Avatar
gotcha..thanks for the input..i think i'am gonna give it a go..what could go wrong..?.ha..
Old 05-16-2014, 12:36 PM   #84
wade_ab
wade_ab's Avatar
Its been a long time since ive been on here, alot has changed. I sold my house and shop, moved, quit my job, and started up a powder coating and hydro-dipping shop. My truck has just been sitting here in the shop staring at me everyday. Customers keep asking me when im goin to start working on it again. So I decided to start back up a little bit. Ive made a little progress in the past week.
69 k10 - In pieces
Old 05-16-2014, 12:39 PM   #85
wade_ab
wade_ab's Avatar
Got some 1 ton rear 56" leafs from the junk yard. Cleaned, blasted and painted them.
69 k10 - In pieces
Old 05-16-2014, 12:52 PM   #86
wade_ab
wade_ab's Avatar
Ordered the shackle flip kit from ORD, the parts to do a 52" front conversion from DIY4X, and front leaf springs from 4wheelparts.
69 k10 - In pieces
Old 05-16-2014, 12:55 PM   #87
wade_ab
wade_ab's Avatar
I finished painting my axle and put the wheels and tires on them and washed the dust off everything. I had already powder coated my diff covers, transfer case, and calipers in this silver artery powder. I plan on using it a lot more on different parts. By the end of the day today I should have everything to make this a rolling chassis.
69 k10 - In pieces
Old 05-16-2014, 01:23 PM   #88
MTCK
MTCK's Avatar
Welcome back!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 05-17-2014, 10:33 AM   #89
mx289
mx289's Avatar
Congrats on the new business venture Wade.
Good to see you back, making progress.
Tom
71 K2500
71 K5 Jimmy
Old 08-16-2014, 11:23 PM   #90
shopteacher
I was just admiring your build and I would like to say it looks GREAT !
On a side note how much did you cut off the front and back of your long bed to achieve short bed dimensions ?
Once again Nice job !
shopteacher is offline   Reply With Quote
Old 08-17-2014, 12:07 PM   #91
wade_ab
wade_ab's Avatar
12" are cut out from infront of the fender and 8" out of the back.
69 k10 - In pieces
