12-08-2014, 02:38 AM | #76 |
Re: Project-GMC Slant Nose
Good to see ya getting back on it
12-08-2014, 05:15 PM | #77 |
Grand PooBaa Member
02-13-2015, 04:35 PM | #78 |
Grand PooBaa Member
Getting the frame, back of the cab and front of the bed ready for paint. Previously applyied POR-15 on parts of the rear frame, need something with UV portection.
Had to change the gear oil due to not knowing when it was last change. Preventive maintance. Rear brakes are next to check. |
02-14-2015, 12:04 PM | #79 |
Keep up the good work!!!
Have you done anything else to the engine??? or got it apart??? |
02-16-2015, 01:45 PM | #80 | |
Grand PooBaa Member
Actually the 350 engine has been tore down to the short block and is sitting on an engine stand. Now I have two. Thinking about taking the tune port out of my green truck and installing it in this one for the time being. Trying to have it running for Del Mar GoodGuys. |
04-03-2015, 01:06 PM | #81 |
Grand PooBaa Member
Had to back off the stepside to concentrate on the longbed. Since it is running I figure id finish it up. Heres where I am now along with my new cab.
04-25-2015, 11:29 PM | #82 |
Grand PooBaa Member
My replacement cab with bedliner sprayed inside and under the cab. The frontend striped down and ready for paint. The old cab and the reason for the change, rust.
04-26-2015, 11:19 PM | #83 |
TILT COLUMN GURU
nice Job Vince! Keep up the good work.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
04-27-2015, 12:02 PM | #84 |
Grand PooBaa Member
04-27-2015, 12:13 PM | #85 |
Vince,
I like your wooden stand for the cab. I've got my cab up on saw horses which works but it's a little high for working in the cab...good for the firewall and cab corners though. keep up the good work! Jeff in Long Beach. |
04-27-2015, 02:09 PM | #86 | |
Grand PooBaa Member
Thanks Jeff, the stand I made from looking at others on the board and copying from them. I should have raised the bottom horizontal 2x4 higher to get my engine hoist under there so I could lift the cab. Now I have to use human lift power times 4 to get it on my frame. |
05-09-2015, 01:03 AM | #87 |
Grand PooBaa Member
Front end of the frame is done. Time for assembly of suspension, cab and fenders.
05-21-2015, 11:19 AM | #88 |
Looking good Vince, you've done a lot of work in the time I have been away.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
05-25-2015, 11:34 PM | #89 |
Grand PooBaa Member
05-25-2015, 11:54 PM | #90 |
Grand PooBaa Member
Where im at now. Tomorrow I will finish the driver side then try to install the cab by Thursday.
Did not know I needed to shoot a coat of clear on CPP products so they don't rust. Duh!!!! |
05-26-2015, 12:18 PM | #91 |
vince,
If you need help getting the cab on I'm available in the evenings or on the weekend. jeff |
05-26-2015, 03:59 PM | #92 |
Grand PooBaa Member
06-16-2015, 01:58 PM | #93 |
Grand PooBaa Member
This is where im at now. Frontend is done, while I wait to prime my cab and paint my cab im going to detail my engine. 91 305 was a Tunned Port injection until I swaped a intake and carb. Going to add a cam to give it a little grunt but keep it dependable. Painted my brakelines red cause I was bored and wanted to see what they would look like.
Also want to install the Cal Custom Valve Covers but need some kind of adapter from center bolt to outside bolt. |
06-20-2015, 01:51 PM | #94 |
Great progress Vince,
Bummed I will not see it at the Brothers show.
06-23-2015, 02:45 PM | #95 |
Grand PooBaa Member
07-03-2015, 12:42 PM | #96 |
Grand PooBaa Member
Engine finished and bout to be mounted back on the frame.
10-25-2015, 03:33 AM | #97 |
Grand PooBaa Member
Engine and cab installed
01-15-2016, 04:51 AM | #98 |
Grand PooBaa Member
New rocker work I had to do. Still learning.
02-08-2016, 05:54 PM | #99 |
Grand PooBaa Member
Welded up button holes and stake pocket holes.
02-08-2016, 05:59 PM | #100 |
Grand PooBaa Member
more pics
