Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 01-29-2013, 01:01 PM   #76
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Re: 66 suburban aka the sub
awesome progress! if you dont mind if i ask where did you have the custom trim redone and how much was it thanks!!
gostranger is offline   Reply With Quote
Old 01-31-2013, 12:29 AM   #77
69 chevy 1
69 chevy 1's Avatar
hi gostranger my friend out in california owns a tri five and impala restoration shop in elmonte ca called the chevy shop we have been friend for a really long time to have the mouldings straightened and anodized was pricey it was 300.00, but i traded some impala parts for them to be redone,ill try and find out the shop he uses.the mouldings were pricey as well 180.00 but ive seen them much higher
69 chevy 1 is offline   Reply With Quote
Old 01-31-2013, 01:20 AM   #78
Crx150zc
Looks great so far, I did have a quick question, the jeep tank seems to be a good fit and size I want to use in my 66 c10 build, did you use the chevy fuel pump assembly or the jeeps, I am trying to build on a budget and want to find a small tank that fits in the frame and will use the chevy pump and sending unit I all ready have.
Crx150zc is offline   Reply With Quote
Old 01-31-2013, 04:03 PM   #79
gostranger
gostranger's Avatar
You bought the custom trim for 180? if so I think that is cheap mine wasn't bad price wise when I got it but it was in rough shape so I am in the process of sanding and buffing it. Thanks for the info!
Old 02-01-2013, 12:11 AM   #80
69 chevy 1
69 chevy 1's Avatar
hi crx150zc the tank and pump and tank are both jeep, but im sure some chevy fuel injection pumps are the same size,but the stock chevy sender will not work.the pump size is 3-1/2 i dont know the pressure output on the jeep pump,but im not that concerned about it i work for ford and we have plenty of pump motors that will push enough pressure to run the chevy engine,if you need more pictures or have any questions just yell thanks,by the way the jeep tanks are cheap and ebay has them
Old 03-24-2013, 11:23 PM   #81
69 chevy 1
69 chevy 1's Avatar
body guy is still plugging away on the body both side and roof bodywork done and sealed blocking will start soon, all the inside body work and trim are done and sealed up
Old 03-24-2013, 11:30 PM   #82
69 chevy 1
69 chevy 1's Avatar
body guy welded up most of the firewall carnage do to excessive holes in the past also started installing the high floor hump.He has been pretty busy he only has nights and Sundays to work on my burb but he is getting it done.
Old 03-24-2013, 11:32 PM   #83
69 chevy 1
69 chevy 1's Avatar
more pictures
Old 03-24-2013, 11:34 PM   #84
69 chevy 1
69 chevy 1's Avatar
more pictures floor hump
Old 03-24-2013, 11:47 PM   #85
69 chevy 1
69 chevy 1's Avatar
been working at work along with a tone of other projects got my seats out gonna take them and have them bead blasted and pound out some dents so they can be painted also.my interior will be done in a 64 chevy impala patern will post a picture soon
Old 03-24-2013, 11:51 PM   #86
69 chevy 1
69 chevy 1's Avatar
well my yard is my newest project started monday with grass by sunday this is how it looked,so another project,still heading out to cali next friday to check in on my burb
Old 04-13-2013, 11:59 PM   #87
69 chevy 1
69 chevy 1's Avatar
Well my body guy has been getting ready for a block sanding party,he is still welding up mounting holes previous owners used to mount gas cans and other holding devices haven't worked on the frame much to many other projects going,seats have been blasted and should be powder coated soon,seats are at upholstery shop,they will be black and silver gray stock 64 chevy impala pattern, the suburban will be black and really light charcoal have not decided witch will go where yet the inside will have full headliner and full carpet
Old 04-14-2013, 12:01 AM   #88
69 chevy 1
69 chevy 1's Avatar
more pictures of body work in progress
Old 04-14-2013, 12:02 AM   #89
69 chevy 1
69 chevy 1's Avatar
more body pics and holes in tail gate so many holes on these old work trucks
Old 04-14-2013, 12:04 AM   #90
69 chevy 1
69 chevy 1's Avatar
more body shots before blocking
Old 04-14-2013, 12:08 AM   #91
69 chevy 1
69 chevy 1's Avatar
upper and lower gate sections,NOTE ANYONE HAVE A LATCH FOR ONE OF THESE BURBS WITH CLAM SHELL DOORS, I MIGHT HAVE TO DRILL OUT THE PIN AND REPLACE PIN AND SPRING
Old 04-14-2013, 12:14 AM   #92
69 chevy 1
69 chevy 1's Avatar
Got the floor high floor hump installed looks great still have to cover the old manual trans shift hole
Old 05-25-2013, 07:04 PM   #93
69 chevy 1
69 chevy 1's Avatar
been a while got some projects that jumped ahead of the burb closer to being finished at least on the hot 100 plus days in las vegas we can hit the pool lol
Old 05-25-2013, 07:08 PM   #94
69 chevy 1
69 chevy 1's Avatar
all work has not been forgotten i decided while things were still some what apart i would install a c-notch in case i get the airbag craze down the line.im probably gonna run a 20 in the front and 22 outback.
Old 05-25-2013, 07:18 PM   #95
69 chevy 1
69 chevy 1's Avatar
also my body guy is still plugging away in his spare time, he is getting very close all body work is done he has just been blocking multiple times and priming. the color we have decided on will be really light gray with a black two tone on the top area below the windows or the reverse of the colors black bottom gray top have not decided yet, he has been blocking the fire wall and all insides,all seat frames have been bead blasted and seats are at upholster will post a pic of the fabric i had it in my 61 impala wagon i converted from a parkwood it was a beauty.
Old 05-25-2013, 07:37 PM   #96
69 chevy 1
69 chevy 1's Avatar
picture of my old 61 wagon painted by my same guy down in cal back in 2001 it was sold and sent to japan back in 2006 i bought a nice roller wagon in case i get the urge again lol,this car has the patern on the seats and the star pattern headliner i will be using in the burb same upholstery guy also
Old 05-25-2013, 07:49 PM   #97
69 chevy 1
69 chevy 1's Avatar
also been rebuilding my slider windows im only on the first one i think its the rt front,i purchased the window kit for two slider windows from truck shop, all was good had to weld a channel in the bottom of a coupler frames, i did not like the corners where it is square i was gonna pull it into the corners tite, but after 209.00 bucks later i purchased the seals only from precision where the corners are square i think the 209.00 covers all four windows took a look this morning looks like all four corners pieces are there, it does not come with felt or runs so i will have to pick up two more long pieces of run channel and couple pieces of felt to go along with the two from the car shop, i have total of 8 sliders so im using the super rusty set as a how to thats why my new frame is resting on a dirty set lol front and back are different
Old 07-21-2013, 04:52 PM   #98
69 chevy 1
69 chevy 1's Avatar
been very busy,projects and work sub bodywork almost done and wet sanding has started,body is super straight,inside paint work will began it will be satin black on the inside
Old 07-21-2013, 05:17 PM   #99
69 chevy 1
69 chevy 1's Avatar
wet wet and then wet sand some more finals stages of body work,its looking good,paint should be soon
Old 07-21-2013, 05:19 PM   #100
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Lookin really nice.
Alan's Classic is offline   Reply With Quote
