Old 04-05-2014, 08:40 PM   #76
RANDY COX
RANDY COX's Avatar
Re: Randy & Jakes 64 4x4 SLOW build
Yea I was thinking of doing some trading on a 292 but The gentlemen thinks one of the cam lobes is wore. But then I'd have to change out front cross member then try to find power steering brackets and mo money, I'm on a tight budget, so I think I'll just stick with what I got.... I'm going to my brothers tomorrow after church and pick up an engine crane(hoist), pull the engine paint it up real nice and hopefully work on the firewall and maybe paint it before I put the engine back in and that part will be done....
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 04-05-2014, 11:38 PM   #77
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
The 292's came stock as a forest green color..and if done right look really good. I personally am not a fan of green and am going illegal colors with my 292.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-06-2014, 01:56 PM   #78
enonz65c30
man you are making good progress. where abouts in Radford are you? I lived on howe street from 2005-2010, I miss it up there. that 4x4 is going to be nice in the snow too I building a C30 and I have a lot of the same rust issues you are having. gotta love Virginia.
enonz65c30 is offline   Reply With Quote
Old 04-06-2014, 02:32 PM   #79
RANDY COX
RANDY COX's Avatar
I live just across the Bridge in Fairlawn, So were you a Radford university student. Yea Virginia Rocks.. Do you have a build thread like to see some pictures of your truck...
1964 BBC 402 4x4
Old 04-06-2014, 05:53 PM   #80
enonz65c30
Talking Re: Randy & Jakes 64 4x4 SLOW build
Yep I was a highlander. Here is a link to my build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=608391
I know fairlawn well, y'all got a cook out not too long ago. I was passing through awhile ago and stopped in for lunch. Your rockers seem to fit very well much better than the ones I got from top banana parts in Lynchburg va.
Old 04-06-2014, 06:50 PM   #81
RANDY COX
RANDY COX's Avatar
I live from walking distance from Cook out, I forget what brand the rockers were but I had to cut the spot weld loose at the front and fold the rocker in more then rewelded..
1964 BBC 402 4x4
Old 04-06-2014, 06:57 PM   #82
enonz65c30
ah I got ya, it looks good. I am just getting tired of fixing rustits just slow going and I am trying not to loose my forward momentum. I look forward to following your build, hopefully all the snow and low temperatures are gone for this year
Old 04-06-2014, 07:14 PM   #83
RANDY COX
RANDY COX's Avatar
I know what ya mean about the rust. Yea I hope the cold is over now, I don't have a garage so I do everything outside, so the weather plays a big part on how much I get done... I will be checking on your build from time to time cause when I do then it makes me wanna work on mine, keeps me going.... there's lots of good builds on here, check out 61K10's build...
1964 BBC 402 4x4
Old 04-06-2014, 07:39 PM   #84
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
X2 on "Weather plays big role on how much gets done when you don't have a garage to park the trucks in" lol! I know the feeling.
Old 05-01-2014, 06:23 PM   #85
RANDY COX
RANDY COX's Avatar
well my engine's were delivered this evening, The clean one I heard run it has a cam lobe wore in the back, and the other one was a freebie and it's not stuck so it may run I have to get me a starter and gonna try and fire it up....
I'll prolly put a new cam and lifters in the clean one it came out of a 65 3/4 ton with 50,000 miles, you would think that the cam wouldn't be wore... anywho I have something else to play with He,He,He.....
1964 BBC 402 4x4
Old 05-02-2014, 11:05 AM   #86
argonaut
argonaut's Avatar
I always wanted a 292. Those seem like cool old motors. Sometimes you have to wonder about that mileage since the odometer only had 5 digits...could be 50k, 150k, 25th or more!
It is just my unsolicited advice but I would do a quick leak down test or compression test on both motors to see which long block is the tightest. Then you can swap in new cams and oil pumps and other "wear parts" so that you'll have a solid motor that you know will last you a while.
You can get a basic cheap leak down test kit from harbor freight and then just need a compressor.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 05-02-2014, 04:05 PM   #87
RANDY COX
RANDY COX's Avatar
Yea Jason I hear ya, I'm wondering though why it would have a heavy duty double pulley setup, Makes me wonder if it came out of a c-50, I've seem them with that same setup... I'll have to do a compression check on them and see..... You know a lot of people usually when they get an old truck they just swap em out for a V-8 even though the 6 is a good engine, some people like them and some don't, I for some reason like them...
1964 BBC 402 4x4
Old 05-02-2014, 04:22 PM   #88
argonaut
argonaut's Avatar
The reason for running a dual belt pulley setup would be due to high output accessories. Say a high amp alternator for instance. It takes more torque to turn these and a single v belt has a limited amount of friction with which to turn that pully. So for ambulances or tow trucks with these big alternators you'd need to run dual belts otherwise you get lots of belt slipping and squealing.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 05-02-2014, 04:23 PM   #89
argonaut
argonaut's Avatar
I'd run the dual belts and then you've got a backup if one should break!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 05-02-2014, 04:33 PM   #90
1963c-10
1963c-10's Avatar
Nice score on the new engines
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-02-2014, 07:50 PM   #91
RANDY COX
RANDY COX's Avatar
Thanks..
1964 BBC 402 4x4
Old 05-02-2014, 10:24 PM   #92
61K10
61K10's Avatar
should be enough there to build a good one Randy
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-02-2014, 10:46 PM   #93
McMurphy
McMurphy's Avatar
Nice score on the motors !!
I would be tempted to just get a couple rebuild kits, a new cam, and rebuild them both !!
Not like these are getting easier to find...
We watched a rebuilt Pontiac IL OHC6 203 sit at $400 on Ebay for 2 weeks, then in the last 5 minutes of the auction it shot up to $1200 before the bidding closed !!
You know, just food for thought.... LoL
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 05-03-2014, 03:51 PM   #94
RANDY COX
RANDY COX's Avatar
Yea a lot of people like to wait til the last minute to bid, I'm guilty of it too...
1964 BBC 402 4x4
Old 05-03-2014, 09:18 PM   #95
RANDY COX
RANDY COX's Avatar
Well I attempted to start the ole dirty engine, First I pulled a side cover to inspect and also the valve cover and it was actually very clean inside not dirty or gummed up. I put a starter on it and put the carb from the good engine and fuel pump and wires and cap. she was cranking slow I guess I would too if I hadn't been ran since who knows when...Gonna try it tomorrow with a good hot battery, gotta make sure I'm getting fire to...
Oh BTW I know no one ask but I paid $200.00 for both engines I think that was a good deal... I have to check and see where the best place to buy cam and lifters...
1964 BBC 402 4x4
Old 05-03-2014, 10:45 PM   #96
McMurphy
McMurphy's Avatar
If you have not seen http://www.stovebolt.com/ give them a look-see. Not just for parts info, but a lot of top end tech info too particularly on these IL6 engines.
Good Luck
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 05-05-2014, 08:36 PM   #97
RANDY COX
RANDY COX's Avatar
Well I have some good news I got that ole dirty engine fired up finally, she actually ran pretty smooth, I wanna hook it up to a radiator and run it some more with water and oil pressure gauge and see how it does, she got pretty warm this evening.....before I clean it...McMurphy I'll definitely check them out been a while since I visited...
1964 BBC 402 4x4
Old 05-18-2014, 06:30 PM   #98
RANDY COX
RANDY COX's Avatar
Not much done lately been working a lot, Did manage to get out there today and take some parts off and start cleaning to be painted..
This last pix is the engine that I put on a starter and fuel pump and carb and she fired up.
1964 BBC 402 4x4
Old 05-18-2014, 06:34 PM   #99
RANDY COX
RANDY COX's Avatar
As you can see the date on the pixs I'm 2 days ahead of schedule LOL.
1964 BBC 402 4x4
Old 05-19-2014, 09:26 AM   #100
McMurphy
McMurphy's Avatar
I am almost envious!!
Looks like you may have really scored with those engines
I bet you are going to have some real fun getting them detailed out !!
Not sure if you ever saw DLOE's build, but here is a link to it.
Definately one of my fave IL6 builds:
http://67-72chevytrucks.com/vboard/s...d.php?t=457465
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
