Old 03-04-2016, 12:17 AM   #76
Billyburban
Re: Gauges used for LSx swaps
@andy4639 that looks nice real nice I almost bought the speedhut speedo an was going to retro fit it behind the original face.
@uxdesigner I bought that same one on eBay great price but I'm thinking of trying to use the 2002 escalade since it has speedo Rpm fuel oil pressure VoLts temperature trany temp
Billyburban is offline   Reply With Quote
Old 03-04-2016, 12:20 AM   #77
Operatorfailure
Originally Posted by uxdesigner View Post
I used a panel off EBay that was remarkably easy to install and had very accurate readings. Speedometer was adjustable based on tranny pulses, took a few tries to get it right but it worked. Tip: I used Waze to validate correct speed while driving.
That's nice! If you don't mind how much did it cost?
My 68 Stepper build
Operatorfailure is offline   Reply With Quote
Old 03-04-2016, 12:26 AM   #78
Billyburban
Here it is
Old 03-04-2016, 12:27 AM   #79
uxdesigner
Thanks, I got the panel for the same price the seller has them posted now. Search Intellitronix (no affiliation), you can find them in various colors.
uxdesigner is offline   Reply With Quote
Old 02-24-2017, 12:22 AM   #80
t300
Originally Posted by Hart_Rod View Post
Crash - I think I may have found the answer to this. I was talking to the guy building the harness for my son's truck and he told me you can go into the tune and turn this feature on. Here's a screenshot of where you go in HPTuners. Go to system, and select the options tab. Then add a 1 in the oil pressure column. Let me know if it works.
Anyone ever try this and can confirm if it works or not for oil pressure?
t300 is offline   Reply With Quote
Old 02-24-2017, 01:22 PM   #81
chevy72blu
chevy72blu's Avatar
Looks like speedhut came out with a Cable X competitor that also has the benefit of GPS (if you so choose, it can also connect to VSS).
http://www.speedhut.com/Speedbox.html
Blog reviews are very favorable. I think I'm gonna go this way rather than the S10 speedo swap. I was hesitant to go with Cable X because of the noise complaints (not that my truck is quiet in the cab lol).
Also, I've been running the stock mech. oil pressure gauge for nearly 2 years now. It reads high, of course (and pegs out at high RPM) but it seems to work well. At first I was concerned about the high pressure breaking the gauge (and dousing me in hot oil) but so far so good.
I completed the box body Voltimeter swap and I'm happy with it. To the untrained eye it looks stock and works great.
New fuel gauge from LMC is working but calibration is off. When full it reads 7/8th of a tank and about 1/2 tank reads empty. Im using a Boyd's rear tank and GM 0-90 ohm sender. Strange....
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 02-24-2017, 02:45 PM   #82
Wasted Income
Boosted Member
Wasted Income's Avatar
Holley touch screen running off my Dominator.
[IMG][/IMG]
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-24-2017, 03:29 PM   #83
Hart_Rod
Hart_Rod's Avatar
[IMG][/IMG]
That's sexy, !
Hart_Rod is offline   Reply With Quote
Old 02-25-2017, 12:58 PM   #84
Billyburban
Hello everyone I have an 2002 5.3 4l60e I bought an aftermarket gauges set up but I saw back in December a guy that had his factory rpm an speedo working he was using the black box for the speedo but said he used an adapter from the speedo to the rpm has anyone heard of this ?
Old 02-27-2017, 04:17 PM   #85
chevy72blu
chevy72blu's Avatar
Check out Cable X and Speedhut Speedbox. I believe thats what you are looking for if you want to run a stock speedo without modifying it. If you do want to modify it, you can do the S10 conversion or send it to Redline Gaugeworks and they'll do it for you.
RIP EastSideLowLife
Old 03-29-2017, 10:12 PM   #86
Sturvin
Definitely subscribed.
Thinking of getting the VHX system. HDX looks nice, but not another $500 nice...
Sturvin is offline   Reply With Quote
Old 03-30-2017, 11:38 AM   #87
CarterKraft
The VHX system is very nice, glad we went that way over individual gauges.
CarterKraft is offline   Reply With Quote
Old 12-19-2017, 03:13 AM   #88
Jrs01
Originally Posted by TchncnDen View Post
I used gauges out of a Silverado ($40) and later upgraded to Escalade gauges ($100). The Escalade gauges have a more vintage look to them and fit the look of the truck as well as the added trans temp gauge.
Has anybody tried this in the sixties body style I have a 65 and doing it LS swap from an Escalade was thinking the same thing but don't know if it would work for me thanks in advance
Jrs01 is offline   Reply With Quote
Old 12-20-2017, 09:55 PM   #89
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Originally Posted by Crash_OK View Post
Dakota Digital VHX with their PCM interface. The speed, RPM, Water Temp, etc are feed to the gauges via the PCM.
I used Dakota Didital also, works perfect
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 12-20-2017, 11:21 PM   #90
Steve Cole
Hey Crash,
Do you have any pictures showing how/where you mounted your PCM along with that other electronic stuff? It appears to be under the dash somewhere but I have no idea how you found room for all that. I've looked, and can't seem to find a spot for even my computer, let along all that other stuff. Thanks
Steve Cole is offline   Reply With Quote
Old 09-12-2019, 01:44 PM   #91
howell57
What engine are you using? I have a new 2018 L83 and had the harness wired to include two OB2 ports.
Would like to hear more on your setup!
howell57 is offline   Reply With Quote
