Old 06-23-2014, 04:46 PM   #76
7dee2
7dee2's Avatar
Thumbs up Re: '72 C3500 GMC flatbed project
You are flying through this, great job, very impressive! A ton of work but all worth it in my book!
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 06-27-2014, 10:52 PM   #77
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Photos should be up tomorrow, but I've got the cab back on and she'll be ready to fire in the morning!
Let me tell you something, this truck looks MEAN with the lift
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 06-28-2014, 07:21 PM   #78
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Can't wait to see this Beast all together.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 06-28-2014, 10:04 PM   #79
JJorgensen52
As is often the case with these sorts of projects, what should have been easy...
Anyway, I have run into a few issues today:
1. Body alignment - the core support is slightly higher and slightly further forward than it used to be, so I'm having to add some shims here and there, and monkeying with the cab takes time, to get the fenders to hang straight
2. Brakes. My driver's side caliper (which is a new Delco Durastop unit, premium part...) decided to start leaking everywhere. I'm going out to R&R it here in a minute to see if I can't fix it; if not, NAPA trip in the AM
3. P/S - it took me FOREVER to bleed the brakes, getting to the bleed screws on a narrow 14FF is very difficult. The hydroboost unit is working great, but I may have run into a capacity issue with my reservoir - that is to say, when the truck is running I don't quite have enough fluid, and when I shut it off it's filled to the absolute top of the reservoir. I guess this is why the later pumps have a larger capacity reservoir. D'oh!
However, I cranked it over briefly to prime the oil and when I hooked up the coil, it fired on the first turn . I did have to R&R the clutch dust shield, it was bent just enough to touch the flywheel and making a bunch of racket.
That said, it's almost a truck again!
CURRENT
SOLD
Old 06-29-2014, 01:53 AM   #80
whitels1
whitels1's Avatar
Looks bad ass man!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 06-30-2014, 09:15 PM   #81
JJorgensen52
So, my C3500 is now officially a K3500!
Been driving it around on errands today, worked out most of the bugs in the alignment - let me tell you, it's like driving a new truck! I've had a cheesy grin on my face all afternoon.
Unfortunately, I'm moving right now so in the shuffle my camera has gotten misplaced somewhere, I should have better pics later in week:
CURRENT
SOLD
Old 06-30-2014, 09:31 PM   #82
whitels1
whitels1's Avatar
Good stuff man!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 06-30-2014, 09:58 PM   #83
rs74
rs74's Avatar
You definately don't waste any time.
What all did you have to do to shim the fenders and core support. Any pics of that stuff.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 06-30-2014, 11:46 PM   #84
67chevy1series
67chevy1series's Avatar
Wow you hauled azz! That was fast man. Truck looks cool!
67chevy1series is offline   Reply With Quote
Old 06-30-2014, 11:53 PM   #85
JJorgensen52
Thanks for the kudos, guys!
It turned out I had two separate problems. When I installed the later truck's core support mounts, they ended up at a slight angle. I was able to compensate for that by adjusting the mounts a bit and not tightening it down until it was attached via the fenders (and thus in alignment).
The second was the height - I used what Lowes calls "bearing plates" - they're a 3" square galvanized washer, which is normally used to attach sill plates to a foundation. They're about 3/32" thick, and I ended up adding three on each side of the cab at the front to get everything aligned.
CURRENT
SOLD
Old 06-30-2014, 11:56 PM   #86
rs74
rs74's Avatar
Makes me want to sell my 85 K30 and pull out the 67 GMC C30 and do this so bad.
Roy
1987 R10 shortie
Old 07-05-2014, 10:32 PM   #87
rs74
rs74's Avatar
Looking forward to pics and how the truck is doing since the conversion.
Roy
1987 R10 shortie
Old 07-09-2014, 03:13 PM   #88
JJorgensen52
So a little back story - The green dump truck which I parted out last year in this thread came from a friend of mine who owns a farm; the way it worked out is I took the truck as a commission to build them a new farm truck; hence this project.
The truck has gone to its new home, now, but the new owner I believe is joining the forum and hopefully will be chiming in with pictures soon! I can tell you that Big Red is already getting put to work.
CURRENT
SOLD
Old 07-09-2014, 10:20 PM   #89
rs74
rs74's Avatar
I guess for some reason I thought that you was painting it too. It looks like a beast from what I have seen of it. Definately a pretty cool truck. Nice job on the build.
Roy
1987 R10 shortie
Old 07-10-2014, 01:22 AM   #90
JJorgensen52
Originally that was part of the plan, but despite my best efforts , I ran out of time. I'm military and I had a hard date to transfer, so unfortunately I didn't get to it. The truck will be getting paint, as well as rocker shells and cab corners.
CURRENT
SOLD
Old 07-12-2014, 01:19 AM   #91
JJorgensen52
Red is getting pampered at his new home. New taillights and new flooring:
CURRENT
SOLD
Old 07-14-2014, 12:28 AM   #92
redryder
I should stop texting you pics so I can update this thread myself. Some more exciting updates for red soon. Sold my FORD turbo diesel today the went shopping for more truck parts. I also need to get around to addressing the little bit of metal work that needs to be done on the cab.
Any suggestions on a dash pad? Mine is looking sad. I'm okay with a plastic cap but read acouple thread about poor quality (lump noodle) replacement pads.
redryder is offline   Reply With Quote
Old 07-15-2014, 12:58 AM   #93
JJorgensen52
Good to see you finally stopped lurking
As far as the dash pads go, the best units I've heard of are the ones from Classic Parts. I'm still in favor of just pulling the OE pad and having it re-wrapped, it's all there. Talk to the upholstery guy and see what he thinks.
CURRENT
SOLD
Old 07-24-2014, 10:42 PM   #94
redryder
Small update:
Seat reupholstered in heavy duty vinyl. New tail lights, new floor vinyl, and new PTO controls. Also added a tach to the stock cluster.
Been driving this thing everywhere!
Old 07-24-2014, 11:08 PM   #95
redryder
Old 07-24-2014, 11:10 PM   #96
redryder
More
Old 07-24-2014, 11:12 PM   #97
redryder
Dumper in action...does that sound weird?
Old 07-25-2014, 12:10 AM   #98
whitels1
whitels1's Avatar
Diggin this truck man!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 07-28-2014, 10:50 AM   #99
7dee2
7dee2's Avatar
X2!
Brett
Old 07-29-2014, 09:31 PM   #100
redryder
Thanks guys. The truck will be a driver for the next couple weeks to get some work done around here. I hope to get some more work done soon though.
Rockers and cab corners
Headlight upgrade
Mount and plumb remote reservoir for hydrolics
Rebuild seals on hydrolic pump
Find and mount a plow
