Old 07-29-2013, 10:50 AM   #76
VWNate1
VWNate1's Avatar
Post Re : 'C' Notching
Welders are cheap , go to the local Police Impond yard , they'll sell them separately from the impounded trucks .
Back to your mock up : isn't it stronger to radius the joints ? .
In the field I always see frames broken where there are 90° corners , welded or not .
Just thinking here , I'm a Mechanic , not a Welder .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 07-29-2013, 11:04 AM   #77
BigDaddyV
BigDaddyV's Avatar
Re: Project "Nether~Storm" 72 swb
/im gonna do alot more support bracing once I begin the install. It will have gussets and support plates welded at each joint. I wont half arz anything. I do understand what you mean. Ive been welding for 15 yrs and always over think and do everything. My mock up is very minimal, But the finished product will be much heavier duty... Im still not sold on my Notches. I made them and still want to redesign them.... lol. Hince the lengthy build process. I over think and annylize everything. Some times to much.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 07-31-2013, 11:27 AM   #78
TazmanB
TazmanB's Avatar
Looking good man. I just finished the rear portion of my frame this weekend. Sanded painted and put all new rear suspension in. Im not doing an extreme drop on mine like you but I understand the pride of doing it all yourself. Keep up the good work and pushing forward.
If you ask the question. Make sure you are ready for the answer.
69 C-10 Longbed (In Progress) Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=568171
TazmanB is offline   Reply With Quote
Old 07-31-2013, 01:58 PM   #79
BigDaddyV
BigDaddyV's Avatar
Thankz Tazman. I was not happy with the 2nd set of notches I made so I redesigned them again..... lol. I know. Make up your mind already. This time I built them with inner gussets plug welded in place. And the outside is braced also. Made from 2in. x 5in. x 3/8 thick tube. I believe that these are much stronger and will hold up to any abuse I will dish out. Ill post some pics tonight when I get home.
Old 07-31-2013, 02:10 PM   #80
BigDaddyV
BigDaddyV's Avatar
A much more Sturdy Deep notch
Old 08-01-2013, 03:09 PM   #81
BigDaddyV
BigDaddyV's Avatar
Ok I finished the bolt in/weld, Deep notches. Wasnt sure how tall they needed to be so I gave my self 11 in... Shoud be more than enough. I'll be putting them in this weekend, but till then here is the pics of my finished notches minus the bag mounts.
Old 08-04-2013, 10:16 AM   #82
BigDaddyV
BigDaddyV's Avatar
Update from yesterday, before the rain set in.... Grr....
Anyway, I got my cab off the frame and found that it is pretty solid with the exception of the floor pans next to the doors (which I forgot to get a picture of.) And the frame looks in great shape. I removed a few unused brackets and got a real good look at the PO's handy work on the Motor stands, which were wrong in the first place. But I have the correct ones to replace them.
I also got the hook up on some freebie Air tanks! Woot, one 8 gal. and a 5 gal.
Not sure where or which one I'll use but I got them.
Old 08-04-2013, 11:45 AM   #83
Bomp
Bomp's Avatar
Wow, I'd say that motor mount gotta hack'd on!
Free tanks.
Bomp is offline   Reply With Quote
Old 08-04-2013, 12:33 PM   #84
BigDaddyV
BigDaddyV's Avatar
Free tanks.
Ya it got the hack job done to it fo sho.
Im all about free stuffs. It really helps the pockets.
Old 08-04-2013, 10:56 PM   #85
VWNate1
VWNate1's Avatar
Question Re: Project "Nether~Storm" 72 swb
Is that a big block engine ? .
I was looking at one just like it last week for $200 but I don't like V-8's , it sure looks BIG .
-Nate
Geezer
Old 08-04-2013, 11:29 PM   #86
BigDaddyV
BigDaddyV's Avatar
454 BBC yes sir it is. Not sure what she will dyno yet but look forward to finding out.
Old 08-05-2013, 12:28 AM   #87
VWNate1
VWNate1's Avatar
Thumbs up Re: Project "Nether~Storm" 72 swb
Thanx ;
That's what I thought but wasn't really certain ..
So many local Hot Rodders tell me they'd kill for one of these and I see them all the time in the local Pick-A-Part junkyards for $200 fan to flywheel , including the carbys ~ as they're usually late 1970's vintage ' Square Bodies ' I assume they have wretched smog cams that need replacing to get the real power I remember from BBC's back in the 1960's .
Sadly , I've tried telling folks exactly where they are and no one has ever ponied up yet .
I'm off looking in junked trucks for a 292 I6 right now .
Easier to find good running 454's , that's amazing .
-Nate
Geezer
Old 08-05-2013, 06:37 AM   #88
BigDaddyV
BigDaddyV's Avatar
They are hard to find here. And expensive if you find one to rebuild. But WELL worth it. I love mine.
Old 08-09-2013, 05:23 PM   #89
BigDaddyV
BigDaddyV's Avatar
Woot got my carpet in today! it looks Great! I cant wait to get the frame ready for Phase 1 of this build. I've decided to split my build up into 2 parts. Static Drop (Phase 1) Air (phase 2) but ill be doing all my floor repair in phase 1.
Heres a shot of my carpet just set in the cab.
Old 08-09-2013, 05:45 PM   #90
BigDaddyV
BigDaddyV's Avatar
Also Have the notch and new rear frame rails almost buttoned up. Gotta go see a buddy and get it all welded up
Here is a mock up, hopefully sunday Ill have an installed pic to share.
Old 08-09-2013, 10:04 PM   #91
TazmanB
TazmanB's Avatar
looking good and moving right along
Old 08-11-2013, 02:44 PM   #92
BigDaddyV
BigDaddyV's Avatar
Well I took the dive and cut the frame for my notches. a little unconventional but my way none the less. The rear frame is a little crocked untill I can get it on flat ground and weld it together. its only bolted up right now, So I can do some adjusting.
Let me know what ya think and be honest...
as you can see I have springs just set in above the axle as a simulation of the bag ride height.
Old 08-14-2013, 09:54 AM   #93
BigDaddyV
BigDaddyV's Avatar
here is a better pic. its been raining on and off so I havent been able to get much more done. Hopefully this weekend I can get back rocking on it.
Old 08-15-2013, 10:51 AM   #94
americanthunder
Looking real good and moving right along..Following!
__________________________________________
AmericanThunder
Project Booger Build Thread
americanthunder is offline   Reply With Quote
Old 08-15-2013, 11:14 AM   #95
mcbassin
Still Learning
mcbassin's Avatar
Very good progress.
mcbassin is offline   Reply With Quote
Old 08-15-2013, 11:51 AM   #96
BigDaddyV
BigDaddyV's Avatar
Thanks, Im trying to get it right.
Originally Posted by mcbassin View Post
Very good progress.
Thank you, Its slow but Hopefully the final product is what I have in my head. A sweet Ride.
Old 08-15-2013, 08:00 PM   #97
builtbyKane
builtbyKane's Avatar
Great job. Moving right along!
builtbyKane is offline   Reply With Quote
Old 08-16-2013, 07:37 AM   #98
BigDaddyV
BigDaddyV's Avatar
ThANKS kANE! I just went threw your thread, WOW! Love it!
Old 08-18-2013, 01:41 PM   #99
BigDaddyV
BigDaddyV's Avatar
Its been raining about everyday and haven't been able to do really anything, So I painted my new motor stands and motor mounts so when its dry I can get them put on.
Old 08-18-2013, 03:02 PM   #100
BigDaddyV
BigDaddyV's Avatar
Before:
After:
Couldn't afford a new one so I refurbished my old one the way I wanted it.
