Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 07-15-2013, 02:41 PM   #76
JJH Jimmy
JJH Jimmy's Avatar
Re: Project "It's a Jimmy Thing"
Originally Posted by youngrodder View Post
Mine is a 48 Chevy. I have a friend in Schoolcraft with a 50 5-window.
I'm ussually not in that neck of the woods but my wife and I took a truck ride over to South Haven for dinner. It turned out to be a great night for a drive.
Your welcome to check the truck out anytime.
Marc
Awesome! I'll take you up on that sometime.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 07-15-2013, 06:54 PM   #77
SONOSADSACK
SONOSADSACK's Avatar
Hey man, slow down! These things are supposed to take years.
SONOSADSACK is offline   Reply With Quote
Old 07-15-2013, 07:04 PM   #78
jaros44sr
jaros44sr's Avatar
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-29-2013, 10:13 AM   #79
JJH Jimmy
JJH Jimmy's Avatar
Sorry it has been so long since my last post, but it has been a real pain in the butt trying to upload pictures. I have actually gotten a bunch of small stuff done. I tore the heater box apart cleaned painted and installed a new heater core. I also rebuilt my heater control. I used a rebuild kit from Brothers that has the good levers. it turned out o.k. but i was not real impressed with the sticker. maybe i will get a new one if i can't live with this. Like many, the rivets in the back of the heater control were loose, so i drilled them out and tapped them to a 10-24 screw and then i cut the screws flush with the face and then installed the new sticker.
1985 Chevy K20
1994 GMC Yukon
Old 07-29-2013, 10:27 AM   #80
JJH Jimmy
JJH Jimmy's Avatar
I also got the Hydrobooster that i got from a 94 astro van painted up, installed and plumbed. I used hydraulic lines from a 95 1 ton pick up. They took some tweaking but i managed not to kink them. It kind of looks like a bag of snakes, but i think it turned out about as clean as possible using factory lines. I installed a new master cylinder and bled the brakes. The brake bleeding took forever but i think that i got them good for now and the best part of it is that i didn't have any leaks on the hydraulic lines or brake lines (knock on wood)!
1985 Chevy K20
1994 GMC Yukon
Old 07-29-2013, 10:53 AM   #81
JJH Jimmy
JJH Jimmy's Avatar
After i got the heater box in and hydraulic lines hooked up i filled up the power steering reservoir and the radiator. I wire nutted the electric fans in. I then test fired the engine to check for leaks and make sure the fans turn on. I don't have a scan tool and i got nervous because it was getting pretty hot and the fans had not turned on yet so i had to improvise. I robbed my kitchen for my girlfriends meat thermometer and taped it to the heater hose. It worked perfect. The fan kicked on at 180 degrees!
I also installed the glove box and glove box door. It is som much more fun installing part than taking them off!
1985 Chevy K20
1994 GMC Yukon
Old 07-31-2013, 07:48 PM   #82
JJH Jimmy
JJH Jimmy's Avatar
Well i had a problem with my shift lever pin not fitting my freshly rebuilt tilt column that i didn't figure out until it was already installed. Here is a link to how i fixed it. Hopefully it will help others with the same problem.
http://67-72chevytrucks.com/vboard/s...92#post6198792
1985 Chevy K20
1994 GMC Yukon
Old 08-04-2013, 08:59 PM   #83
JJH Jimmy
JJH Jimmy's Avatar
I got my exhaust 100% complete this weekend.
1985 Chevy K20
1994 GMC Yukon
Old 08-04-2013, 09:07 PM   #84
JJH Jimmy
JJH Jimmy's Avatar
A couple more pictures.
1985 Chevy K20
1994 GMC Yukon
Old 08-26-2013, 04:37 PM   #85
JJH Jimmy
JJH Jimmy's Avatar
Well, i took a little time off from work and working on the Jimmy to go on vacation to Glacier National park and Yellowstone to do some much needed Harley riding. The trip was awesome. We logged about 1400 miles on the Harley and 3800 on the truck in about 11 days. Now it is time to get back to work on the Jimmy. Hopefully i will get something done!
Awesome. I can upload normal size pictures again!!!!!!!!!!!!!!!!!!!!!!!!!!!
1985 Chevy K20
1994 GMC Yukon
Old 09-16-2013, 12:21 PM   #86
JJH Jimmy
JJH Jimmy's Avatar
I have been working on some body work lately. I had to repair both my front fenders. The passenger side needed the trim holes filled and a front lower patch panel. The drivers side was a little more work. It was obviously in a "fender bender" at some point. It had a about 3/4" of bondo covering up the dent. I got a fender out of the pick and pull and cut it up for the patch panels. I probably should have just bought a new fender but i think this will work.
1985 Chevy K20
1994 GMC Yukon
Old 09-16-2013, 12:28 PM   #87
JJH Jimmy
JJH Jimmy's Avatar
Drivers side fender.
1985 Chevy K20
1994 GMC Yukon
Old 09-16-2013, 12:35 PM   #88
JJH Jimmy
JJH Jimmy's Avatar
I bought the Lokar ACA-1800 shift linkage and installed it. The rod that came with it was not long enough and i didn't like the coupling with the set screws that allows you not to have to put a thread on the end. So, i bought a piece of 5/16" stainless steel rod, bent it up and threaded both ends. It was a pain in the butt to get the indicator on the column to point where i wanted it to for each gear.
1985 Chevy K20
1994 GMC Yukon
Old 09-16-2013, 12:41 PM   #89
JJH Jimmy
JJH Jimmy's Avatar
Instead of repairing my rusty inner fenders i bought a set from Auto Parts Warehouse for $120.00 shipped to my door. The quality looks to be good and i just have them mocked up but they appear to fit really well. Here is the link if anyone else needs to get a set.
http://www.autopartswarehouse.com/se...al&N=0&submit=
1985 Chevy K20
1994 GMC Yukon
Old 09-16-2013, 01:46 PM   #90
jaros44sr
jaros44sr's Avatar
Well done, but, do you come back and fill in all the spots that are not hit with the first pass on your welding. Looks like a butt weld, i flanged mine, and was curious if they are just as strong.....
SAFETY FIRST
AS usual, off topic
Jim
Old 09-16-2013, 02:47 PM   #91
JJH Jimmy
JJH Jimmy's Avatar
Yea. That picture was just the first series of tacks i put on it. I kept tacking it and cooling each tack with compressed air until all of the tacks were all connected. I then ground it all smooth and filled in any low spots or spots that i missed. It is a full penetration weld for the most part by looking at the back side. I know butt welds are plenty strong. I have never flanged body panels before so i'm not sure on the strength of those.
1985 Chevy K20
1994 GMC Yukon
Old 09-16-2013, 04:43 PM   #92
tjsblazer
tjsblazer's Avatar
Really like the look of your exhaust. Especially the tips. Was that a kit you purchased ? Steel or stainless ?
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 09-16-2013, 07:05 PM   #93
JJH Jimmy
JJH Jimmy's Avatar
Thanks, It is stainless steel tubing and fittings. I pieced it together from a few chunks of tube and a dozen 90 degree elbows. I cut and mitered the fittings to the angles I needed and welded it all together. The main exhaust tube is 2 1/2" and I used a couple butt weld 2 1/2" x 3" reducers at the outlets. For the tips I just cut the 3" tube on a 60 degree angle and welded it to the reducers.
1985 Chevy K20
1994 GMC Yukon
Old 09-17-2013, 11:28 AM   #94
Slinger60
Slinger60's Avatar
Just read your build thread. Very nice work . Going to be a very nice ride when your done with it.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=529970
Shawn
Slinger60 is offline   Reply With Quote
Old 09-17-2013, 01:52 PM   #95
youngrodder
youngrodder's Avatar
Very nice project. I look forward to seeing it on the road.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 09-17-2013, 04:17 PM   #96
JJH Jimmy
JJH Jimmy's Avatar
Thank you!
Marc
Thanks Marc! I saw your ride at the street rod show on Friday. I looked for you but you must have been out walking around. Yours was one of my favorites from the whole show.
1985 Chevy K20
1994 GMC Yukon
Old 09-18-2013, 09:35 AM   #97
youngrodder
Originally Posted by JJH Jimmy View Post
Thank you!
Thanks for the kind words. I was around most of the day Friday. On Sat my truck was there all day but I was not. I had a full slate of kids sporting events. I'm sure that we will meet sooner or later.
Marc
Old 11-07-2013, 09:54 PM   #98
jaros44sr
jaros44sr's Avatar
Com'on, i know youve been doing something in your shop.....post up
SAFETY FIRST
AS usual, off topic
Jim
Old 11-11-2013, 09:39 PM   #99
JJH Jimmy
JJH Jimmy's Avatar
I have not been as busy on the Jimmy as i like, but it is time for a little update.
My plan is to get the doors repaired and then put everything together and make sure all of the body panels fit and the gaps are how i like them.
I have been working on the doors. I thought that i would just replace the lower door skin of both doors, but after doing the drivers side i am not that satisfied of my work. I will have my painter/body guy look at them, but i may just order new door skins and have him install them. I love trying to do everything myself but sometimes you need to know when enough is enough and let the professionals take over. Haha.
1985 Chevy K20
1994 GMC Yukon
Old 11-11-2013, 09:51 PM   #100
JJH Jimmy
JJH Jimmy's Avatar
I have also been taking care of some smaller items like mounting the air box assembly. I had to cut a chunk out of the fender/core support bracket to get everything to fit like i wanted. One of the next things on the list is to order the American Autowire Classic update Kit and start the wiring process. Does anyone know if i have to buy their crimpers or are there universal crimpers that i can get that will work?
1985 Chevy K20
1994 GMC Yukon
