Old 12-05-2013, 09:35 PM   #76
arrover
arrover's Avatar
Re: Project "River Truck" - CCLB 4x4
Few more.
1982 GMC Crew Cab 4x4 - "River Truck" build thread
1973-1987(91) Chevy/GMC How-To Videos
arrover is offline   Reply With Quote
Old 12-06-2013, 09:17 AM   #77
Low Elco
You're a stronger soul than me- I'd have seen that roof paint while changing the gaskets and had to strip the roof paint. Then that wouldn'ta looked right, so I'd have to strip the rest of the truck, and it'd be unusable. See- you have the plan! I really dig this truck. Is that Table Rock or Beaver in the pics? Love me some Table Rock. Speakers look good! Are you happy with your new jams?
Low Elco is offline   Reply With Quote
Old 12-06-2013, 11:57 AM   #78
arrover
arrover's Avatar
Haha! Well I realize that I should have painted up there but it's true I don't want to do the whole truck right now. I'm planning on using some of this color matched, spray "touch-up paint": http://www.automotivetouchup.com/ at some point. The roof paint is not in good condition right now but you are correct. My intension is to be able to use this truck as much possible and not get into any huge down times. I felt like the old lights were letting in water and wanted to fix that ASAP.
I'm loving the truck. It makes me smile when I drive or look at it. The radio/speakers make it even more fun. I'm going to add a sub but probably not until after I do some other projects.
That is actually Beaver Lake. Beaver and Table Rock are pretty similar. Thats cool that you are in my area of the country.
Old 12-07-2013, 12:14 PM   #79
Low Elco
I love it down there, go to Big M/Eagle Rock on TR once a year. Used to go canoeing at Noel a lot. Totaled the hell out of a 99 Tahoe in front of the Walmart at Jane, the ER at Bentonville is great. Guess all that Wal-mart dough is good for somethin! If I Hit either lottery this weekend, I'll be your new neighbor. Hope you like Bud Light and ZZtop!
Old 12-22-2013, 09:19 PM   #80
arrover
arrover's Avatar
Been working on the truck more lately. I don't mind the look of the stock steering wheel but it just doesn't feel good in my hands compared to fatter, newer style steering wheels. I pulled these two GMC wheels at the U-Pull-It for $15 each. One went in my truck and one is a Christmas present for my brothers GMC 6000 flatbed. The diameters of the old and new wheels are basically the same but the new wheel has a much thicker grip.
Old 12-22-2013, 09:50 PM   #81
arrover
arrover's Avatar
I felt like I needed to check out the front axle bearings, seals, brakes, etc since I'm not sure when they were done last. The Dana 60 isn't terribly complex. I've never been inside one but it's going well. I decided to replace the inner bearings/races, seals, and spindle bearings/seals. I thought that the wheel bearings always came with races but that isn't the case I found out. I probably would be done by now but I'm waiting on the races... The spindle bearings are hard to get out of the spindles. A straight punch doesn't really work. I used a small pry bar that got bent a full 90 degrees before the bearings finally came out.
Old 12-22-2013, 09:52 PM   #82
arrover
arrover's Avatar
Few more...
Old 12-22-2013, 09:55 PM   #83
arrover
arrover's Avatar
The hubs were a little rusty and didn't look that good sticking out of the wheels. I primed and painted them semi-gloss black.
Old 12-22-2013, 09:58 PM   #84
arrover
arrover's Avatar
My old brake discs were in really bad shape. One of the discs was worn really unevenly. There were even holes and cracks in them so I ordered new discs and pads. I decided to paint the discs so they won't rust.
Old 12-22-2013, 10:00 PM   #85
arrover
arrover's Avatar
More...
Old 12-22-2013, 10:05 PM   #86
arrover
arrover's Avatar
Old 12-22-2013, 10:07 PM   #87
arrover
arrover's Avatar
Old 12-22-2013, 10:43 PM   #88
83GMCK2500
Holy crap, that was one badly stuck caliper... New hardware looks great.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 12-23-2013, 11:23 AM   #89
Low Elco
That ain't a stuck caliper. Replace the brake hoses ASAP. BTDT. They collapse on the inside, acting as a one-way check valve. 80's chevies are FAMOUS for it. Work looks good!
Old 12-23-2013, 01:15 PM   #90
arrover
arrover's Avatar
Thanks for the replies guys. Low Elco, how confident are you that it's a brake hose issue? Obviously I want to do this the right way but I was hoping not to get further into the brake system yet. I was hoping to replace the brake soft lines, hard lines, maybe calipers, etc all at once. What does "BTDT" stand for? Thanks for the help.
Old 12-23-2013, 01:35 PM   #91
83GMCK2500
Whenever I have seen that excessive wear one one side of a rotor surface and far less on the other surface the caliper was stuck or sticking in the bracket/slide. Also, incorrectly installed or incorrect pads in a caliper can bind and cause that. Not disagreeing with your statement about brake lines, Low Elco, just clarifying my observations. Hoses/lines are a too often overlooked part of the brake system.
Devin
New Daily, the '96
Old 12-23-2013, 01:54 PM   #92
garmar
garmar's Avatar
My '84 GMC did the same thing and it was the brake hose. The metal bracket/brace rusts around its interior surface and slowly builds up to the point where it closes up the hose. Brake pressure can go through but not return - one way valve. I also had a 92 Bonneville do this and a 94 Lesabre, so when I do calipers I always just do the lines since they are cheap insurance.
And cool truck! I used to work for a guy that had a 2 WD 85 CC and we put a 403 Olds engine in it. It freakin' screamed.
garmar is offline   Reply With Quote
Old 12-23-2013, 02:04 PM   #93
Low Elco
83- I totally agree, but calipers are easily checked and in 25 yrs of playing with cars/hotrods I've seen exactly one stuck caliper. A BUNCH of stuck slides/brackets, though. Once again, easily checked/cleaned/greased. I've seen several bad lines, and they're so cheap/easy to do.
BTDT= Been There, Done That. Took a full show '85 stepper backwards off of I435 at about 85 mph due to a collapsed hose. No leaks, looked fine, but the new pads were half gone, and the rotor was blue. Please check/swap your hoses.
Old 12-23-2013, 02:18 PM   #94
bnoon
I've had several brake issues over the years but I've never ever heard of the "famous" hose issue until this site. I've only ever replaced hoses if they had leaks or if I was upgrading to braided lines for track use. I found several videos showing it online, but have never experienced it once myself. I've had at least half a dozen bad calipers (usually the seals go bad and get filled with sand/dirt) and many many bad pins. I grew up with a wrench in my hand as the son of a mechanic and I'm 41 now... asked dad and he had heard of it but never experienced it either. Luck of the draw I guess.
EDIT: One way I would suggest to test the lines vs. caliper theory is to reverse bleed the lines. Pop the bleeder lose, fill a finger pump style oil can, attach a small piece of hose from the oil can output to the bleeder and pump a few squirts of brake fluid in through the bleeder. I've bled my brakes this way my whole life. Don't need anyone pumping the brake for you and don't need no expensive store bought pressure bleeder.
EDIT 2: Nice build by the way!!! LOVE LOVE LOVE the H2 wheels on that truck!
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 12-23-2013, 02:18 PM   #95
arrover
arrover's Avatar
Thanks guys! I'll move hoses to the top of the To-Do list. I appreciate the help!
Old 12-23-2013, 02:45 PM   #96
Low Elco
You got it- go forth and stop smoothly and evenly, Grasshopper. I gotta try the bleeder setup. That's always a PITA.
You're a better man than me- All them 4X4 parts skeer me! I'm a 2x guy!
Old 12-23-2013, 02:45 PM   #97
arrover
arrover's Avatar
Thanks again for the compliments! I think I'm just going to replace the hoses soon because I'm sure they need it either way. The calipers came off easily and I didn't see anything that indicated that they weren't sliding. I cleaned the caliper mounts and I will lube them when I put them back on (should I use grease or anti-seize?). With that and new hoses, I think everything will be operating correctly.
Old 12-23-2013, 02:56 PM   #98
monte0185
monte0185's Avatar
Great lookin truck and love the hummer wheels as well. My dually that im working on now had a stuck caliper when i got it. I always change the lines when i change the calipers just as a precaution. Working on cars all my life ive seen a few of each. Cheap insurance is the main reason I change them though. I always gravity bleed all my brakes though. Done it all my life and never had an issue.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 12-23-2013, 04:52 PM   #99
bnoon
Yup, one of these type of oil cans and some 4mm hose and you can pressure bleed the whole truck in just a few minutes with no helpers. Just remember to suck out the reservoir first so that it doesn't overflow. I still keep learning that one the hard way LOL!
Old 12-23-2013, 05:08 PM   #100
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
I can't view your videos to diagnose, but my 78 1 ton did the same, new brake hoses fixed it.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
