08-25-2014, 11:12 AM | #76 |
Re: Project Coca-Rustola: '67 C20 Longstepper
Don't give up man keep at it.
Rust is better than rice. |
08-27-2014, 12:36 AM | #77 |
I saw you want to do a disk brake swap, try to find a 73-87. The cross member and everything nearly bolts right in. Only like 2 of the holes are off slightly and one needs to be drilled. And you wont have to change your motor mounts. Those trucks can be found sitting in peoples yards all over around here. I think theres 2 by my house sitting out on one of the farms. You could probably talk them out of the whole truck for 100 or maybe free, once they wont pass smog or the engine/trans goes out, people just park em
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
08-27-2014, 02:48 PM | #78 |
Yep, that's the plan eventually.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
08-28-2014, 10:00 PM | #79 |
Look what showed up in my garage today. Thanks wreckedchevy and Eric in Montana for hooking me up with a spare tire carrier. Now to clean it up, paint it, and get it on the truck.
10-04-2014, 10:57 PM | #80 |
Not much progress of late. Money has been tight and not much time to spare. But, today I did throw a sheet of 3/4 plywood into the bed just so that I actually put stuff in the bed without it falling underneath the truck. I also temporarily seeled up the rust holes in the roof, firewall, and cab corner to keep water and critters out this winter.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L Last edited by Saclandman; 10-04-2014 at 11:05 PM. |
10-06-2014, 12:02 PM | #81 |
Took the ol' boy out for a little drive just to make sure the brakes are working good. Seems to stop well. Glad it has power brakes. I think I'm having carb/float problems, it keeps flooding. But that's ok, the engine is going to get swapped anyway.
10-06-2014, 12:20 PM | #82 |
Lucky. I want to drive mine so bad. I think I might get to later this week!
10-06-2014, 01:48 PM | #83 |
I can't drive it on the road yet, still registered non-op. But the property I have it stored at has a long driveway. I'd probably risk it if the block wasn't full of holes. Hate to get stranded on the side of the road with a non-op vehicle waiting for the CHP to roll up.
10-06-2014, 02:10 PM | #84 |
Posing for the camera.
10-12-2014, 05:20 PM | #85 |
Started pulling things apart in preparation for the engine swap.
10-12-2014, 05:27 PM | #86 |
1967 C20 Longstepper: Ol' Rusty
Here's a good view of the crack in the block. Just below the head on the drivers side. This little 283 did it's best, but it time to go.
10-13-2014, 07:12 PM | #87 |
Yea no fixin that! Might be able to sell some of the used parts on the parts board to recoup some of the cost tho.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
10-13-2014, 07:33 PM | #88 |
Yep. Going to salvage everything usable and put it up on the parts board.
10-13-2014, 07:35 PM | #89 |
Proprietor of Dale's Corner
That's not a crack, that's a break. It pushed out quite a ways . Like Swamp says there may be some people interested in the internals and heads .
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
10-13-2014, 08:10 PM | #90 |
Have fun with the motor swap (I did)! Maybe I can stop and check it out next time I go through Sacramento.
IMO if you want to make it more retro, you should paint the block orange, even the timing cover (unless you add other chrome to the engine). It will look more stock with the retro Coca-Cola theme. Even with the Edelbrock top, mine looks very stock just orange and black. I also used my original valve covers for the look. |
10-13-2014, 11:25 PM | #91 | |
If I had time tomorrow, I'd swing by Chico and say hi. I'm heading to Redding for a meeting in the afternoon.
10-13-2014, 11:28 PM | #92 |
Stop on the way back?
10-13-2014, 11:42 PM | #93 |
11-02-2014, 12:44 PM | #94 |
Grill hoops. Before and after.
11-02-2014, 01:13 PM | #95 |
Good to see your finally , tatting to dig in... keep it up!
11-02-2014, 05:41 PM | #96 |
These grill hoops are tedious. Grill driving me a little nuts too. More progress coming.
11-02-2014, 06:25 PM | #97 |
Just take your time. It is tedious, but will be worth it.
11-02-2014, 08:58 PM | #98 |
What you guys think of Rudolf the Red Nosed Coke Truck.
11-02-2014, 09:07 PM | #99 |
Nice keep it up!
11-02-2014, 10:00 PM | #100 |
Lookin good! Will look pretty cool installed
Tags |
1967 c20 longbed stepside, 283, c20, longbed stepside, longstep |
