Old 02-28-2014, 06:45 PM   #76
smbrouss70
smbrouss70's Avatar
Re: '68 COPO Concept - Vulgar Display of Power
Look for post by "billneumiller", he is the truck's owner.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-28-2014, 08:46 PM   #77
darkhorse970
darkhorse970's Avatar
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 02-28-2014, 09:26 PM   #78
Tinkermc
Had 2 check back in and admire the progress, which there has been a boat load. Seeing the inside of the wheels above would be nice.
Tinkermc is offline   Reply With Quote
Old 02-28-2014, 09:54 PM   #79
darkhorse970
Smile Re: '68 COPO Concept - Vulgar Display of Power
Originally Posted by darkhorse970 View Post
I'm still working on engine/trans accessories and connection in preparation for mounting and mocking up the cab. More on that later.
I am also trying to make decisions on initial wheel and tire setup and would like opinions on this idea. As mentioned earlier I have a nice set of factory '68 dogdish hubcaps that I'd like to run on this concept initially, i will probably have a set of 18/20 billets on here down the road.
My original plan was to mini-tub the bed(~5" tub) and run 15x7/15x10 steelies painted body color with a fairly wide and sticky rear tire on the rear (325/50/15 Mickey Thompson ET Street Drag Radials?) but these have my proverbial wheels turning.
Circle Racing 108 Series in 18x8 and either 18x11 or 20x9.5 with some wider tire in the 29" tall range. I think I would either paint the centers or the entire wheel. I should add that none of these options will have a really deep look, as I'm running a stock width '68 rearend converted to 5 lug. I will order wheels with appropriate backspace to fit the tires under the fenders.
Thoughts?
This is the best pic I've found of this wheel. I would paint yhem either white or silver, depending on my paint color.
Keith
350/700R4
4/6 drop
1980 Silverado
Original paint
49k Original miles
4/6 drop
Old 07-17-2014, 07:16 AM   #80
darkhorse970
Not alot of progress lately, but I did stumble across a Doug Nash Overdrive unit at Petit Jean Swap Meet. It bolts in place of the T400 tail shaft housing, has .80 OD gear ratio, can be controlled electrically through a switch, and is rated up to 35,000 GVW vehicles. I think it will be a nice addition that will allow me to run 3.73 axle gears and still cruise comfortably on the highway.
Keith
350/700R4
4/6 drop
1980 Silverado
Original paint
49k Original miles
4/6 drop
Old 07-17-2014, 10:09 AM   #81
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I guess there was a time when Gear Vendors didn't completely own the add on overdrive market. What a great find. Vintage parts are good parts.
Old 07-17-2014, 11:11 AM   #82
jlsanborn
jlsanborn's Avatar
How cool is that!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 07-17-2014, 12:30 PM   #83
darkhorse970
Another thing about that unit that you'll appreciate is that when it is cleaned, sealed back up, all new switches, harness, etc...I will be into it for less that the core charge on a 4L80. Not bad in my opinion!
Keith
350/700R4
4/6 drop
1980 Silverado
Original paint
49k Original miles
4/6 drop
Old 07-17-2014, 02:14 PM   #84
67chevy1series
67chevy1series's Avatar
Man this truck keeps getting more and more badass I always love to see this thread up again!
67chevy1series is offline   Reply With Quote
Old 11-03-2014, 09:20 PM   #85
darkhorse970
Finished up all of the metal work on the cab and got it sealed up with epoxy primer.
Keith
350/700R4
4/6 drop
1980 Silverado
Original paint
49k Original miles
4/6 drop
Old 11-03-2014, 09:27 PM   #86
darkhorse970
Another angle, now the real fun begins with bodywork!
Keith
350/700R4
4/6 drop
1980 Silverado
Original paint
49k Original miles
4/6 drop
Old 11-03-2014, 10:19 PM   #87
67chevy1series
Looks great! Keep it up, love what your plans are
Old 11-10-2014, 07:16 PM   #88
darkhorse970
I got the Lizard Skin Heat and Sound Control sprayed on my cab floor pan. We sprayed it inside and out.
Keith
350/700R4
4/6 drop
1980 Silverado
Original paint
49k Original miles
4/6 drop
Old 11-10-2014, 07:31 PM   #89
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Nice work, I'll be in this to the end.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 11-11-2014, 09:00 AM   #90
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on the cab!
mcbassin is offline   Reply With Quote
Old 11-11-2014, 10:17 AM   #91
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks really good!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 11-11-2014, 12:30 PM   #92
darkhorse970
Originally Posted by aggie91 View Post
Looks really good!
Thanks for the encouragement guys! We are making progress again, so I am motivated to keep it going and get this thing on the road.
Keith
350/700R4
4/6 drop
1980 Silverado
Original paint
49k Original miles
4/6 drop
Old 02-15-2015, 07:01 PM   #93
darkhorse970
Making some progress, it actually looks like a truck again.
Keith
350/700R4
4/6 drop
1980 Silverado
Original paint
49k Original miles
4/6 drop
Old 02-15-2015, 08:46 PM   #94
GSFMECH
On the road
GSFMECH's Avatar
Looks good Keith!!
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 02-16-2015, 02:07 AM   #95
gdavis
gdavis's Avatar
coming along real sweet
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 02-17-2015, 09:31 AM   #96
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress!
Old 02-18-2015, 09:05 PM   #97
Low68
Low68's Avatar
Cab looks great. Do you have any advise on spraying the lizard skin? I have it sitting on the shelf waiting to spray on my cab.
Build Thread
Low68 is offline   Reply With Quote
Old 02-18-2015, 10:51 PM   #98
darkhorse970
The Lizard Skin sprayed out really easy. I used the gun that comes with the kit. After a little adjustment to get the texture like we wanted, there was nothing to it.
Keith
350/700R4
4/6 drop
1980 Silverado
Original paint
49k Original miles
4/6 drop
Old 02-19-2015, 12:16 AM   #99
jlsanborn
jlsanborn's Avatar
Man that thing looks great! Is that a resto'd air filter housing or aftermarket? Exactly what I'm looking for.
Old 02-19-2015, 06:55 AM   #100
darkhorse970
It's an OEM air cleaner that has been repainted.
Keith
350/700R4
4/6 drop
1980 Silverado
Original paint
49k Original miles
4/6 drop
