11-13-2014, 05:23 PM | #76 |
Re: 1970 C10 LWB "Blu"
Very nice
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
11-13-2014, 05:41 PM | #77 |
I'm always interested in builds and I usually chime in time to time. Thanks for updating on your truck. Some threads go stale and you wonder what happened, then once and awhile somebody will post an update or ask an question so yeah we still listening.!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
11-14-2014, 11:02 AM | #78 |
Mitchell72 asked for a pic with a better side profile so here it is...
The wheels are 15x6's up front with (I think) 215/75/15's and 15X8's on the rear with 235/75/15. I'm going to upgrade to 18's or 20's when the suspension/front end will need better rubber.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
04-05-2015, 12:06 AM | #79 |
Just found this thread. There's a bunch of great info in here. A lot of which I need to apply to my truck. Any updates to the current state of the truck?
04-05-2015, 08:05 AM | #80 | |
Its frustrating. Every time I get this truck "completed" and out on the road, I find something else to do and it gets all torn apart again. I am thinking I might get stupid and do a short bed conversion before I get the new driveshaft and exhaust done (again). If the bed is coming off, I'll c-notch the rear as well I guess. All the steering and shifter/clutch components are out: All set underneath to bolt up the newly built tremec:
04-06-2015, 08:44 PM | #81 |
If you didn't have something to mess with what else would you do? Lol.
04-06-2015, 09:42 PM | #82 |
Hey John, how did you get the engine compartment so clean without removing the factory grease pencil marks? I don't want to lose mine when I clean up in there. I saw that you used a high pressure sprayer and degreaser. That wouldn't remove them?
04-06-2015, 09:49 PM | #83 |
Ride my harley and still have money I guess.
04-06-2015, 09:51 PM | #84 |
I just kept the degreaser and the pressure washer away from the grease pencil marks. They are pretty durable.
04-06-2015, 09:53 PM | #85 |
Thanks. Can they be wiped over with a soapy sponge like you would was the exterior of the truck with?
04-06-2015, 10:18 PM | #86 |
I don't even do that. I just wiped around them by hand.
02-26-2016, 11:03 PM | #87 |
Found your build thread from the 6 speed tremec thread that you posted on. Checked your build out - wondering if you have some install pics on the transmission? How was it to install? Any problems? Any words of wisdom to someone going into an install like this?
Thanks, Ryan |
02-27-2016, 08:40 AM | #88 | ||
02-27-2016, 08:46 AM | #89 | ||
09-03-2016, 09:20 AM | #90 |
. Just found this thread - great job maintaining the original/patina look and freshening up the mechanics. Any updated pics and/or details would be greatly appreciated! . .
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
09-03-2016, 08:16 PM | #91 |
Thank you. There is a ton of new stuff on the truck so if I get a chance I may update the thread.
09-06-2016, 07:08 AM | #92 |
Great looking build.
What size tires are those?
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
10-21-2016, 12:54 PM | #93 |
High quality work, Subscribed!
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
10-29-2016, 07:30 AM | #94 |
Thanks. Fronts are 245/40R20 and rears are 275/40R20
12-03-2016, 11:44 PM | #95 |
Great thread. Maybe I missed it are there pics of your clutch pedal setup?
12-04-2016, 09:37 AM | #96 | |
I just drilled a hole in the clutch pedal arm (used a 90 degree air drill) and used a clevis, some threaded rod and adapters to attach to the wilwood master. The most difficult part was mounting the clutch master to the firewall. The firewall looks nice and flat on the engine side but it is a mess on the interior with all sorts of stuff going on the way it was formed. When using the F-body clutch slave you also have to put a stop in the pedal- if you push too far it will overextend the throwout arm and it will make contact with the pressure plate. I'm switching the to the newer LS throwout bearing that mounts on the transmission and don't know if there will be any issues yet. When I did my wilwood brake master cylinder I paid the extra money for their linkage kit. Expensive but a lot easier and looks a lot better. The truck is blown apart right now (again) for the install of a built 6.0, vintage air and a power steering setup. The past year it also got new wheels, a new front end (everything except steering), wilwood brakes, hotchkis suspension parts, drop spindles, etc.... I drove it four times before I tore it apart again for this next project. Old engine out, new engine beside... Early test-fit...
12-04-2016, 01:43 PM | #97 |
Here is how she sits today. Quietly waiting for something to happen while I accumulate all my parts.
12-04-2016, 08:40 PM | #98 |
sweet build!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
12-07-2016, 08:36 AM | #99 |
Thanks! Another $750 or so in engine build parts are trickling in this week. I am determined to get the engine and transmission back in place before the end of January (at the latest). I need to clear up some garage floor space.
12-07-2016, 08:52 AM | #100 |
I don't think I ever posted a pic of the truck with the new wheels/tires and latest stage of suspension work.
