Old 02-02-2014, 02:30 PM   #76
mcbassin
Still Learning
mcbassin's Avatar
Re: My 69 Chevy stepper
Looking forward to the cab restoration.
mcbassin is offline   Reply With Quote
Old 02-02-2014, 02:54 PM   #77
JD'S 69
JD'S 69's Avatar
I'm not the cab is hardest part of the whole build. but it's got to be done and done right, I know there's a little rust.
When I stand before god at the at the end of my life, I would hope that I would not have a single bit of talent left, and I could say," I used everything you gave me"
My 69 stepper http://67-72chevytrucks.com/vboard/s...d.php?t=601095
JD'S 69 is offline   Reply With Quote
Old 02-10-2014, 03:14 AM   #78
JD'S 69
JD'S 69's Avatar
Got my gas tank mounted and the lines started. Just waiting on a order from summit. I ordered some billet hose clamps.
Old 02-10-2014, 03:25 AM   #79
JD'S 69
JD'S 69's Avatar
Got my filter mounted where I want it.
Old 02-11-2014, 11:26 AM   #80
JD'S 69
JD'S 69's Avatar
Fuel pump ready to go on.
Old 02-11-2014, 12:57 PM   #81
specks70
What all did you purchase for the gas tank? Tank Part #, Filter Part #, Gas Cap Part #, fuel line etc? Or did you purchase as a kit. I like what you have there and am preparing to do the same with mine.
specks70 is offline   Reply With Quote
Old 02-11-2014, 01:19 PM   #82
JD'S 69
JD'S 69's Avatar
The tank and cap are from LMC. I don't have a part# they have two different ones side fill and top fill, that's what I have. You can see in some of my other posts the fill hole lines perfect with the board. The lines and fittings are from summit racing, they are size 6AN you can get them in different colors I like the black. And the pump and filter are from jegs, I'm just waiting on my billet clamps so I can finish mounting the lines to the frame. I haven't made up my mind to go with braided or hard line from the pump to carb. I think stainless hard line would be the easiest and clean look..
Old 02-11-2014, 05:55 PM   #83
specks70
Thanks,
I agree the hard lines do give a nicer look vs. the braided. Just looks better and shows you are paying attention to detail.
I'll be watching your build, keep up the good work.
Old 02-12-2014, 10:52 AM   #84
aggie91
I'm just glad to be here!
aggie91's Avatar
Your work looks good on the chassis. how bad is the rust on the cab?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-12-2014, 11:28 AM   #85
faribran
Ok i am curious... what is an INDOOR SLACK LINE ?
faribran is offline   Reply With Quote
Old 02-12-2014, 11:45 AM   #86
JD'S 69
JD'S 69's Avatar
I don't think it's too bad, I hope. In my opinion the cab is probably the hardest part of the build, I have learned so much from this site. Every one makes it look so easy and I know it's not. I need to stop whining and strip it down and see what I have to work with.
Old 02-12-2014, 01:01 PM   #87
JD'S 69
JD'S 69's Avatar
It's a two inch strap, about 80 feet long. They tie it between two trees and use it to balance on. It's normally used out side, but when it snowed and got cold my son got the idea to bring the fun indoors. We had the scrap metal, and I just got a new mig welder so what better way to practice. I'm not sure if this thing is for exercise or fun or both, I have tried it it's a lot of work.
Old 02-12-2014, 01:23 PM   #88
JD'S 69
JD'S 69's Avatar
Got my fuel pump, water pump, harmonic balancer, and cool billet timming pointer from jegs on.
Old 02-14-2014, 11:48 AM   #89
JD'S 69
JD'S 69's Avatar
Fuel line all done up to the pump, got to order some different fittings.
Old 02-17-2014, 04:23 AM   #90
JD'S 69
JD'S 69's Avatar
I started on the cab, the rocker panels are needing replaced and the lower corner where the fender bolts to the cab. But so far that's it. I also got my bed cross members all sanded and will get paint on them tomorrow.
Old 02-17-2014, 12:32 PM   #91
Chevrolaine
Chevrolaine's Avatar
Lovin the progress!
Make sure you post a lot of pics of the rust repair on the cab please!
live love DRIVE!
My 72 Camaro rebuild thread -http://www.nastyz28.com/forum/showthread.php?t=113094
My 69 Stepside thread -
http://6772chevytrucks.com/vboard/sh...d.php?t=597755
Chevrolaine is offline   Reply With Quote
Old 02-20-2014, 11:41 AM   #92
JD'S 69
JD'S 69's Avatar
Got my intake manifold bolted on last night.
Old 02-20-2014, 12:00 PM   #93
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress JD!
Old 02-23-2014, 05:06 AM   #94
JD'S 69
JD'S 69's Avatar
Started putting my oak bed together, got to make some modification's to the edge so the rail will fit better. I might router it even more so there is no gap in the rail and wood.
Old 02-23-2014, 05:08 AM   #95
JD'S 69
JD'S 69's Avatar
The little dermal router works real good.
Old 02-23-2014, 05:11 AM   #96
JD'S 69
JD'S 69's Avatar
Old 02-23-2014, 05:22 AM   #97
JD'S 69
JD'S 69's Avatar
I also put leather under the rails of the bed.
Old 02-24-2014, 02:57 AM   #98
JD'S 69
JD'S 69's Avatar
Done some more routing and got the rails to fit snug against the wood. Now I have to slot the cross rails for bolt alignment, it's going to narrow the bed about 3/8 on each side. Has anyone done this to make the rails nice and clean and snug fit. The picture shows the first pass with router the second I just went deeper.
Old 02-26-2014, 03:36 AM   #99
JD'S 69
JD'S 69's Avatar
I routered the bottom edge so it would butt up to the end rail better, I'm very pleased the way it turned out.
Old 02-26-2014, 10:09 AM   #100
mcbassin
Still Learning
mcbassin's Avatar
Very nice work with the router and wood. I love the wood floors. Maybe on my next build..
