Old 06-06-2014, 10:01 AM   #76
mikentosh
mikentosh's Avatar
Re: Project Cannonball C10
Originally Posted by pwradder View Post
love it! it would be awesome seeing this blue brick passing new m3's on the track!
You are sharing my vision! . I'm starting to think that I need to get another 100 horses out of this LS3 to really make a good show.
mikentosh is offline   Reply With Quote
Old 06-06-2014, 10:06 AM   #77
mikentosh
mikentosh's Avatar
Some updates to the rendering. Can't get the '74 grill in Digital Paint Booth so I have to imagine that, and the wheels aren't exactly what I'm going with. I'm really liking the backed out grille so I might spray or plasti-dip a reproduction one when I put it back together.
Old 06-06-2014, 10:10 AM   #78
mikentosh
mikentosh's Avatar
Dakota Digital VHX gauges. I need to find a way to get the vintage air controls backlighting to match the red backlighting of the gauges. For a radio I've got a Retrosound Model Two which has customizable backlighting to match.
Old 06-06-2014, 12:09 PM   #79
Russ_the_truck79
those gauges are sweet! and so is the rest of the truck... sub
could of had an air conditioned honda but,
I'm hard headed and have standards
Russ_the_truck79 is offline   Reply With Quote
Old 06-06-2014, 02:24 PM   #80
Jonboy
Slots go on anything!
Mike, your truck is a '74, right? You are going to have to move the wiper switch down a little bit to fit in the bezel. If you can, you might want to find a 75-up switch that is backlit as well, since the '73-74 switch was lit with a fiber optic cable that is most likely thrashed.
1974 Jimmy- 5.3/4L80e/NP241
Old 06-06-2014, 03:12 PM   #81
mikentosh
mikentosh's Avatar
The cab actually appears to be late 70's vintage as it had the newer style wiper switch and wiper motor in it. I've got both a 74 and a later 70s switch and wiper motor that I can use. With the new harness I have I think I'll go with the '74 setup and we will move the wiper switch to accommodate the bezel. Only downside is I'll lose the backlighting and intermittent delay wipers, but I don't plan to drive this thing in the rain too much anyway. The tire widths won't help the hydroplaning situation
Old 06-07-2014, 12:06 AM   #82
mikentosh
mikentosh's Avatar
Found a few more photos of the color we are going with. Unfortunately the iPhone doesn't do a great job of color reproduction here but you get some idea.
Old 06-07-2014, 09:26 AM   #83
motornut
78K & 79C Jimmys
motornut's Avatar
I like it,lots happening,gotta watch this
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-17-2014, 12:47 AM   #84
mikentosh
mikentosh's Avatar
Work has begun on the roll cage. We are trying to keep it hidden as much as possible inside the B pillars and between the inner and outer roof skins. It should be a pretty unique and cool cage setup.
While waiting some more parts have shown up, like the fuel tank:
Custom 20 gallon tank from Rick's Tanks.
Old 07-17-2014, 01:19 AM   #85
mikentosh
mikentosh's Avatar
Tony at Valencia Upholstery finished up the bench seat. I wanted to keep things original looking but also really want some bolstering for the corners. I think it turned out pretty awesome!
Old 07-17-2014, 08:38 AM   #86
Low Elco
B!tchin' is the only word that comes to mind. Those gauges are tight!!
Low Elco is offline   Reply With Quote
Old 07-17-2014, 10:26 AM   #87
82ZZZR
Do you have a pic of he back of the gauge cluster? Looks nice in here.
82ZZZR is offline   Reply With Quote
Old 07-17-2014, 01:18 PM   #88
franky69c10
chevy runs deep
franky69c10's Avatar
This is gonna turn out sick
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 07-17-2014, 06:12 PM   #89
pwradder
pwradder's Avatar
the black and hounds tooth looks killer! what are you doing about a harness with the bench?
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 07-18-2014, 12:23 AM   #90
mikentosh
mikentosh's Avatar
Snapped a couple of pics for you. The gauges are super nice and very well made. They also have cool options like using the turn signals in the factory location or using ones built into the gauge faces. I got an accessory module so I'll have oil and trans fluid temps as well as water temp. The e-stopp parking brake will also be wired right to the gauges so the "Brake" light will work when the parking brake is applied.
Old 07-18-2014, 12:32 AM   #91
mikentosh
mikentosh's Avatar
I've just got a rough idea about harnesses right now...I was thinking wide belts (3") in red, but now leaning towards black. Probably a 4 point setup. We are going to build a harness bar off of the cage crossbar above the seat to correctly position the tops of the harnesses. Nothing too fancy for the harness bar as I want to avoid it looking like headrests when peeking through the back window.
Guess I should start browsing for harnesses now...
Old 07-25-2014, 11:04 PM   #92
mikentosh
mikentosh's Avatar
Something exciting showed up yesterday. Here's a little teaser for you...
Hoping to have some photos of this roller by next week!
Old 07-26-2014, 05:37 PM   #93
y5mgisi
Second Chance Program
y5mgisi's Avatar
Oh damn!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 07-26-2014, 09:14 PM   #94
mikentosh
mikentosh's Avatar
Old 07-26-2014, 11:16 PM   #95
Jonboy
You are officially my new hero, Mike.
Old 07-27-2014, 11:22 AM   #96
pwradder
pwradder's Avatar
loving the look! i'd be tempted to drive it just the way it is!
Old 07-27-2014, 02:38 PM   #97
mikentosh
mikentosh's Avatar
Thanks! Clifford was a big inspiration for me to start this whole project. Many years of browsing and planning...
Old 07-27-2014, 02:41 PM   #98
mikentosh
mikentosh's Avatar
Funny, we were saying the same thing yesterday after slapping those wheels on the one side. They make it look good even in primer. I'm pretty excited to see it sitting back down on the ground again. Gotta get the fuel tank mocked up then it can come off the frame table.
Old 07-28-2014, 12:22 PM   #99
82ZZZR
THAT is going to look killer!
Old 07-28-2014, 03:02 PM   #100
aggie91
I'm just glad to be here!
aggie91's Avatar
Just found this thread. WOW is all I can say for now. Looks killer. Those 345's on all corners is impressive. What are your wheel specs to get them to fit and turn?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
