Old 01-08-2014, 11:29 AM   #76
TheBlueBomber
TheBlueBomber's Avatar
Re: Carolina K10, 1979 Reg cab short bed.
I wasnt intentionally trying to go through that hole but my front tire slid in and I figured I would go all the way... If I had reverse gear, and a higher rpm motor I might have been able to back up when I first slid in.
Drove the truck home and parked it for the night. Two days later I drove to the carwash and when I stopped smoke started pouring out of the engine bay. Popped the hood and found oil all over my passenger valve cover, head, and pan towards the rear of the vehicle. Only happens when I stop...
The game plan is, limp it to the shop next week so they can install the new rims, limp it back to the house, pull the transmission, pull the motor. Rebuild the transmission, and go through the motor resealing it and reinstalling it if its good. Hopefully, time and money permitting, it will be done in a month in a half.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 01-08-2014, 01:01 PM   #77
Old School Low
Old School Low's Avatar
I love your thread. Real people with real situations. Keep on truckin.
OLD SCHOOL LOW: 78 Short Wide Heavy Half-Ratty Rod at moment. Old 4blt stroked to 383
Vortecs, Weiand, Scat, Hedman 1 5/8, Howards Roller, .495/500, Scorpion.
Leaf flip, cut coils. Make do tires and wheels for now. Slip ahead a year? Sold GMC, bought Harley, got all obsessed doing the biker thing, now starting again w 65 SWB, 283,2bbl, 3 on tree.
Old School Low is offline   Reply With Quote
Old 01-08-2014, 02:26 PM   #78
KatFish
hey man that picture at Sheetz is that at the corner of 401/Ten Ten Rd? I have a friend that has an 85 he's getting ready to pull the current lift and all off if youre interested.
I go to Wake Tech.
KatFish is offline   Reply With Quote
Old 01-08-2014, 02:29 PM   #79
KatFish
He also have 2 350's for sale. He's doing and LS2 in his.
Old 01-09-2014, 10:30 AM   #80
TheBlueBomber
I go to Wake Tech.
That's the one. Depending on what size lift and if the 350's are solid and run good I'll definitely be interested. I'll shoot you a pm with my number. I'm about 15 minutes away from wake tech.
Austin
Old 01-10-2014, 11:25 PM   #81
TheBlueBomber
So thanks to a good friend of mine I was able to aquire a set of Mickey Thompson valve covers. They are straight with no dents or dings. He told me the PO sprayed paint thinner on the covers and never wiped it off. Stamped number is 3276000
I'll be going a little bit of a different route with these. I'll be out of town this weekend so any progress will most likely start Monday.
Austin
Old 01-10-2014, 11:33 PM   #82
TheBlueBomber
Here's an ad I found for the M/T covers.
Austin
Old 01-13-2014, 11:05 PM   #83
Hankster
Hankster's Avatar
I'm really digging this build! your making me wish mine was a 4wd instead of a 2wd ... dangit!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 01-14-2014, 05:22 PM   #84
TheBlueBomber
Thanks. Just remember... You break less things on pavement then you do off pavement! haha.
Austin
Old 01-14-2014, 05:38 PM   #85
Jonboy
Slots go on anything!
Not me.
1974 Jimmy- 5.3/4L80e/NP241
Old 01-15-2014, 11:11 PM   #86
TheBlueBomber
I started working on the valve covers yesterday. Sprayed them with paint remover, scrubbed them with a scotch bright pad, sprayed down with a pressure washer, repeated about 3 or 4 times. After stripping all of the paint and gunk off there are a few nicks but I'm not too concerned about them. Being that they are cast late '58 through '68 I'm surprised that they aren't torn up. Definitely worth the $40 I payed for them.
Spent about 2 hours on the first with 120 grit. It's a little rough but there are still some spots in the metal and scratches I need to get out. I haven't started on the valley's and hard to get areas yet because I am lacking in the sanding tool department. This weekend I'll pick up some attachments and start on all the nooks and crannies but for now I'm focusing on spots and scratches.
Austin
Old 01-15-2014, 11:16 PM   #87
TheBlueBomber
That's about all I could do in one straight session without losing my marbles
Austin
Old 01-17-2014, 05:14 PM   #88
TheBlueBomber
Still looking for a th350 or a SM465 setup. My never used farm truck plate came in today and I mounted the last 2 rims on the truck.
Austin
Old 01-17-2014, 05:29 PM   #89
rusty76
rusty76's Avatar
Cool valve covers. I'm sure a trans will turn up just got to keep digging.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-17-2014, 07:03 PM   #90
TheBlueBomber
Thanks. There aren't as many squares in this area compared to yours so parts are kind of scarce.
Austin
Old 01-18-2014, 01:21 AM   #91
Old School Low
Nice work
Old 01-18-2014, 02:46 AM   #92
TheBlueBomber
Originally Posted by Old School Low View Post
Nice work
Thanks. I see your motor is coming along nicely.
Austin
Old 01-18-2014, 08:06 AM   #93
rusty76
rusty76's Avatar
They're around here but you don't see as many round eyes on the road as you do the '81-87s. Some and about most of the junkyards around here don't keep them either. Kinda sad really. But they can be found.
My build thread
Crossmembers CC
Old 01-19-2014, 06:23 PM   #94
Hankster
Hankster's Avatar
Looks good! I love them rims!
Current Build
Old 01-22-2014, 05:52 PM   #95
TheBlueBomber
Thanks. How's your truck coming?
Austin
Old 02-03-2014, 12:23 PM   #96
1963c-10
1963c-10's Avatar
Hows the build going?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-03-2014, 01:18 PM   #97
TheBlueBomber
I've taken a momentary pause in the build until I figure out what I'm going to do about the engine.
I found a guy a little past Siler City that will build the TH350 for $450 so I'll drop that off next week.
I've seriously been contemplating putting a 5.3L engine into the truck and I need to come to a decision if I want to reseal the 305 and drive it while I wait or just save the money for the 5.3l swap.
I ordered some LED bulbs for the gauge cluster that should be here tomorrow. I need to get a new circuit board for the back of the cluster because it is shot. Those go for about $80 and for $70 more I could get a tach cluster to put in.
Glad to see you back and well Jon.
Austin
Old 02-05-2014, 11:39 AM   #98
1963c-10
1963c-10's Avatar
I say save the $$$ and upgrade to a tach cluster. That will also replace the circuit board at the same time.
Old 02-05-2014, 01:33 PM   #99
TheBlueBomber
I might as well. I've been wanting a tach cluster for a while now and have been hawking all the local yards might as well pay a little more and know it works /looks good.
Austin
Old 02-08-2014, 07:10 PM   #100
TheBlueBomber
Decision has been made. LS it is!!!! Have a lot of planning and thinking to do as to how exactly I want to do this.
Basically, 5.3/4l80e/np241.
5.3 stock bottom end with LS6 top end plus or minus 2 turbos... Most likely plus!
Stock transmission and a stock tcase. I don't know about Axles just yet and if I want to keep the 12 bolt or not.
The truck has to be as stock looking as possible so I'll keep the gas tank underneath.
This quickly turned from a "kind of built fun daily driver" to a full out twin turbod LS powered square body.
End goal is 600hp. Without blowing up. Some say stock bottom end won't work. I'm going to make it work. And not blow up right away lol.
Austin
