Old 04-16-2014, 11:15 PM   #76
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Project "Schrum" 1959 Gmc 100
I "will" run the Pertronix Kit, well send me a couple?
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 04-16-2014, 11:27 PM   #77
lowrodderchev
lowrodderchev's Avatar
LOL I was asking because I have a HEI set up off a newer six sitting there if you need it its yours just pay the shipping
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 04-16-2014, 11:31 PM   #78
Kim57
Kim57's Avatar
That's a cool air cleaner.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-16-2014, 11:52 PM   #79
SCHRUMGMC
SCHRUMGMC's Avatar
The Original one got tossed by by Grandfather I believe due to major issues, I'm not really sure the situation but I got this one
1971 GMC Sierra
1959 GMC 100
Old 04-17-2014, 12:27 AM   #80
lowrodderchev
I've got the pretronix kit on my fleetline for about 9 years now works great
Old 04-17-2014, 09:45 AM   #81
Katrina/10
Katrina/10's Avatar
Did you try to fit the air cleaner on the carb? If the air cleaner and distributor came off a Chevrolet engine they may not fit a GMC.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 04-17-2014, 11:15 AM   #82
SCHRUMGMC
SCHRUMGMC's Avatar
From what I have seen, they will interchange. It fits
1971 GMC Sierra
1959 GMC 100
Old 04-17-2014, 08:32 PM   #83
SCHRUMGMC
SCHRUMGMC's Avatar
Put the Original Air Breather on
The truck wants to crank but won't
I've put new Spark plugs in
New Coil
New wires
Could the coil be hooked up wrong? Because I've done it before
I'll try tomorrow
Took out the indicator bulbs to replace with new ones to see if they'll work
1971 GMC Sierra
1959 GMC 100
Old 04-17-2014, 09:10 PM   #84
coralhead
coralhead's Avatar
New Coil
New wires
I'll try tomorrow
Did you put fuel in it?
coralhead is offline   Reply With Quote
Old 04-17-2014, 09:16 PM   #85
SCHRUMGMC
SCHRUMGMC's Avatar
Yes I put fuel in it Coral, please no smart responses
I might as well get a new Tail light wiring, because its been spliced etc.. shorts out on the right side and left side works, but looks bad.
Bought another Distributor to replace the one in mine, it came out of a 235 engine. Trying to get it cleaned up..
1971 GMC Sierra
1959 GMC 100
Old 04-17-2014, 09:43 PM   #86
coralhead
coralhead's Avatar
So was there much rust in the fuel tank? Did you get it installed or are you still using the plastic tank? Just asking for us so we know the fuel supply situation.
Old 04-17-2014, 10:00 PM   #87
SCHRUMGMC
SCHRUMGMC's Avatar
Using the Plastic gas tank until the Metal one is cleaned etc
Its getting Gas, I am sure its getting air...Pretty sure it isn't getting Spark. I'll figure it out tomorrow morning
1971 GMC Sierra
1959 GMC 100
Old 04-17-2014, 11:13 PM   #88
SCHRUMGMC
SCHRUMGMC's Avatar
I bought my Air breather/Distributor from "Firetoys" '59 Apache.
Tomorrow I will soak the Distributor in Carb cleaner and paint it Gloss black..
Once I fiddle with the wiring, and get it started. I will see about buying some flexible fuel line to run down the cab to the hard line. The trucks progress it moving slowly but It'll get there
Check the ignition coil primary coil resistance by connecting an ohmmeter between the positive (Black wire) and negative (Green wire) terminals on the coil. The resistance should be 0.4 to 0.6 ohms.
1971 GMC Sierra
1959 GMC 100
Old 04-18-2014, 11:35 AM   #89
SCHRUMGMC
SCHRUMGMC's Avatar
Okay woke up this morning, switched the wires and it cranked right up
Major fuel leaks around the the new inline fuel filter.. I push the choke in and it dies, I am thinking the Timing and tuning is way off. I get my paycheck today so Im going to buy better(smaller) hose for the fuel lines.
1971 GMC Sierra
1959 GMC 100
Old 04-18-2014, 12:10 PM   #90
lowrodderchev
true dedication when you wake up early and start working on your truck and when you cant wait for payday to buy new parts
Old 04-18-2014, 12:12 PM   #91
SCHRUMGMC
SCHRUMGMC's Avatar
Fuel went everywhere when I cranked it up. I wish someone was closer to help me out
I have tuned it a little. I just need to let my local mechanic have a look at it and see if he can get it running better..Because its starting to really really piss me off
1971 GMC Sierra
1959 GMC 100
Old 04-18-2014, 02:26 PM   #92
lowrodderchev
dam no kidding if I was there id back u up ive torn my 6 apart numerous times ive got like 5 back up motors set aside to LOL my buddy taught me to listen to the motor and go from there
Old 04-18-2014, 03:51 PM   #93
SCHRUMGMC
SCHRUMGMC's Avatar
Well all I know is, I'm pulling it to a Local mechanic and letting them solve all of the issues..Pissed off to the damn max
Got my paycheck
Headed to O'Reillys to buy smaller hose and some light bulbs
1971 GMC Sierra
1959 GMC 100
Old 04-18-2014, 04:04 PM   #94
lowrodderchev
have you purchased the pertronix kit yet? if not I would save some money and buy the kit and try it again. I had so much trouble with points every old car I had was moved to electronic ignition
Old 04-18-2014, 04:14 PM   #95
SCHRUMGMC
SCHRUMGMC's Avatar
I don't have the money at the moment to get it. I am short a couple Twenties to get it.
Im just going to back away from it..It is always something with this truck
1971 GMC Sierra
1959 GMC 100
Old 04-18-2014, 08:10 PM   #96
Kim57
Kim57's Avatar
Don't get to discouraged.
You got it to start and that's 90% of it right there. Getting it running smoothly shouldn't be that bad now.
Kim
My build thread
Old 04-19-2014, 11:15 AM   #97
SCHRUMGMC
SCHRUMGMC's Avatar
You can isolate the circuit by running a jump from the positive battery terminal directly to the hot side of the coil (side that does not go to the distributor). Starter circuit will turn it over to get started. If it runs fine and does not quit start looking for loose bad wires. If still dies then in the coil/distributor - Orrie's wise words
Well it is raining today so I am not going to be able to work on the truck. I am planning to buy a smaller fuel hose to put on the Hard lines to stop the leaks... When I fix that, I am going to try to get it running to pull over to my mechanic(across the street) Hopefully he can fix all of the issues
1971 GMC Sierra
1959 GMC 100
Old 04-25-2014, 05:17 PM   #98
SCHRUMGMC
SCHRUMGMC's Avatar
https://www.youtube.com/watch?v=r6J1...ature=youtu.be
Oil Reads 30
Temp Gauge, well its running over the line a hair? could it be because of the new Temp sending unit?
It runs but I can literally adjust the timing while its running..I need to get a rachet to it and tighten it down real good
1971 GMC Sierra
1959 GMC 100
Old 04-25-2014, 07:27 PM   #99
_Ogre
_Ogre's Avatar
if it fits, why not take lowrodderchev up on this?
i had mid 80s 250 hei in my chevyII 194 for years
anyone know if the distributors interchange into the 235?
shop air compressor timer
Old 04-25-2014, 07:33 PM   #100
lowrodderchev
I used the distributor on my 235 my dad did the same thing back in the days no problem just have to use a different hold down clamp
