Old 07-30-2014, 01:26 PM   #76
Hendo
Re: Project "Blackbeard" 69 C-10
Getting the truck clear coated. The bed is done and the body is getting the paint blended in areas and cleared. Will be done tomorrow!
Hendo is offline   Reply With Quote
Old 07-30-2014, 02:33 PM   #77
Hardesty454
Hardesty454's Avatar
Stud...
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 07-31-2014, 06:54 PM   #78
Hendo
It looks so good with the clear coat on it! Pics almost don't do it justice. I Started bleeding brakes today also. I have several leaks because I did not flare my ends properly. Now I have to go back and fix my F@#k ups. Frustrating but that is the way it goes when your learning.
Old 07-31-2014, 07:01 PM   #79
nlped
nlped's Avatar
That does look fantastic. I made those brake line errors and quit trying to make my own and started buying complete kits from inlinetube.com for what I think is a very reasonable price and a heck of a lot less of a headache.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-31-2014, 08:21 PM   #80
Hendo
Thanks. Ya Im a try and fix it on saturday. If I can't get it right I will go that route. Thanks for the tip.
Old 07-31-2014, 11:30 PM   #81
mcbassin
Still Learning
mcbassin's Avatar
Excellent progress, the clear looks great. Keep the pictures coming.
mcbassin is offline   Reply With Quote
Old 08-04-2014, 01:16 PM   #82
Nola67
Looking good... are thos .the escalade.transport wheels?
67 small window swb
98 bagged s10 (orig owner)
99 z71
01 swb
Nola67 is offline   Reply With Quote
Old 08-06-2014, 12:56 PM   #83
Hendo
Yes I believe they are.
Old 08-06-2014, 08:21 PM   #84
hanly2
Sick truck buddy. I love all the work you did.
hanly2 is offline   Reply With Quote
Old 09-02-2014, 09:28 AM   #85
Hendo
I have been able to work on the truck only a couple times a week over the last few weeks. I have the wiring harness in and about 90% installed. I am itching to get the Dakota Digital gauge cluster for the upgrade. They are just so damn expensive! I was able to snap a few shots. I always forget to take photos.
Old 09-07-2014, 07:34 PM   #86
Hendo
I fired the truck today after several months of being down. Fired right up with a few little leaks here and there that were easily fixed with some tightening. The bed will go back on after a brake bleed. I decided to get the Dakota Digital dash and boy am I glad I did.. I did however have to get a new bezel too. Ill put picks up when complete. My sound deadening and carpet should arrive monday or tuesday. Should be driving soon.
Old 09-07-2014, 07:48 PM   #87
nlped
nlped's Avatar
Bad A$$. I love it!
Carter
Old 09-16-2014, 07:31 PM   #88
Hendo
Got the bed on and started the sound deadening process. I forgot to take a picture of the new dash gauges and bezel.
Old 09-16-2014, 08:10 PM   #89
Xeen
Xeen's Avatar
This is one of those double take trucks, you glance at it then a second later you are like what the... and look again and you are like that is badass!
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-25-2014, 04:00 PM   #90
808_67C10
808_67C10's Avatar
Still one of my favorite trucks on here! Keep the pics coming!
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 09-25-2014, 07:20 PM   #91
Hendo
What a whirlwind last 3 days it has been working on this truck. I had an electrical issue with the headlights and blinkers. I could not figure it out for the longest time. Brand new Painless wiring harness. I thought it was the dimmer switch, so I went out and bought a new one. That wasn't it. I chased all wires inside and out plus grounds. Everything was in the right place and grounded. Finally I found the problem. It was a factory error from Painless with the harness. They had 2 wires switched in the wrong slots! Fixed that and everything worked perfect. I wonder if that is a common problem with them? I was also able to finish the sound deadening and instal the carpet. My bed was 1/4" too high installed, so I had to cut and weld the mounts. That was a pain in the ass! Bed is perfect now. You can see that it was high in the above pics. I will get some updated pics soon. The Dakota dash is all installed too. If you have the extra money to plink down on one of these, they are worth it. Easy to install and look nice.
Old 09-25-2014, 07:22 PM   #92
Hendo
Thanks for the compliment. I will get some more pics soon. It is almost drivable.
Old 09-26-2014, 12:29 PM   #93
cheyennesr
cheyennesr's Avatar
Talking Re: Project "Blackbeard" 69 C-10
What does it look like with lights on at nite ? what color? Looks awsome keep up the great work.
cheyennesr is offline   Reply With Quote
Old 09-29-2014, 09:57 AM   #94
Hendo
I was able to spend a few hours on the truck yesterday. I managed to get the seat put in and I had to notch the upper a-arm and steering shaft due to contact when aired out. It was causing a leak in the power steering. I need to take the truck over and get the mufflers and exhaust put on. Should be drivable after that. After that it will be a few odds and ends that need to be done such as: rear wheel tubs cut down and installed, custom console built, radio and speakers, and a vintage air installed some time before next summer.
Old 10-31-2014, 08:50 AM   #95
kyuss
Amazing looking truck! Have enjoyed reading all the updates and especially checking out the pictures.
kyuss is offline   Reply With Quote
Old 10-31-2014, 07:54 PM   #96
Hendo
Thanks for the compliments. I haven't been able to work on the truck for a while. I need a new carb and exhaust put on then I can drive it.
Old 12-05-2014, 08:34 PM   #97
Hendo
So it has been a while since I have posted. There is a reason for that. I hadn't done sh#t to the truck for a couple months. I needed a break and had some other stuff I needed to take care of. Today I blew off some of the dust and got to work on some things. The truck needed a new carburetor so I picked up a new "Quick Fuel"carb and put it on. The old scripts covers are cool looking but kinda a pain in the ass so I ditched them for some Billet Specialties tall script covers. It will be an easier process when I change my oil now. I also got rid of the old throttle linkage and put in a new heim joint one that looks slick. I also had to run a vacuum line to the transmission today. I just need to fire it up and bring it in for a exhaust job and it will be drivable.
Old 12-06-2014, 12:06 AM   #98
preacher anthony
Everything looks great! Should you decide to sell the air cleaner and the white valve covers, let me know. I'm going the opposite way, white truck w/ black roof. Thanks
preacher anthony is offline   Reply With Quote
Old 12-06-2014, 11:58 AM   #99
knomadd
knomadd's Avatar
Nice engine... looks similar to mine. I guess that's why I like it
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 12-16-2014, 09:14 PM   #100
Hendo
Truck is driving and registered through the DMV. I was able to take it to the gas pump today and top her off. I am however having a brake booster problem. I don't think my motor produces enough vacuum to operate it. I will hopefully figure that out tomorrow. All I need now is an alignment, radio and speakers, and finish the rear wheel wells.
