03-07-2014, 07:57 AM | #76 |
Re: Converting to Power Steering 68 c10 6cyl
Yes, 1 13/16
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
03-16-2014, 10:27 PM | #77 |
Well I finally have the 2 groove pulley on, no I need to finish hooking up the alternator, then add belts make sure it all lines up. Then I can work on the gear.
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
03-18-2014, 01:13 AM | #78 |
This is what it looks like. I still need to adjust the alternator. Can youu tell me what belt your using for the crank-water pump-alternator and ps pump pulley? Thanks
03-18-2014, 07:50 AM | #79 |
Its looking good! The belts I'm using are: Alternator = 15375 and Power steering = 15495. Keep in mind, the belt size will change depending on the pulley sizes. Both my PS and WP pulleys measure 5 1/2".
03-18-2014, 09:17 PM | #80 |
Well it seems like everything is lining up, I just need to get a longer belt for the ps pulley. 15495 is a little short..
03-18-2014, 09:27 PM | #81 |
I'm wondering what the metal ring is on the rag joint. I'll post a picture on what im talking about. Also getting ready to take off manual steering box, first need to separate the rag joint.
Is there anything special I need to do to disassemble the rag joint from the steering column? I have been spraying kroil penitrating oil on all bolts, to help loosen them up.
03-18-2014, 09:29 PM | #82 | |
03-18-2014, 09:51 PM | #83 |
I think what you are referring to is a ground.
Regarding separation of the rag joint, you shouldn't need anything special. Are you planning on replacing or reusing? The rag joint on the PS box I got was in good shape, so all I did was remove my manual gear and install the new one.
03-18-2014, 10:05 PM | #84 | |
03-18-2014, 10:12 PM | #85 |
I was thinking at the same time removal of the box and rag joint, I might also try and move the steering wheel in a couple of inches. Since I have everthing disconnected.
Do you have pictures of the V you notched into the bumper bracket? I appreciate all your help. It has made a big difference. I have gone back and started reading all the different posts. Now wfter the fact it is startibg to make since. Lol.
03-19-2014, 08:11 AM | #86 |
Here's a pic looking up at it. I didn't want to trim away more than was needed, so I took off a little at a time until it fit in place without touching.
03-20-2014, 11:01 PM | #87 |
Thanks for the pic, really makes since now.
03-20-2014, 11:09 PM | #88 | |
I hope this goes quicker then the first section. I'm considering moving the steering column in 2-3".
03-21-2014, 12:35 PM | #89 |
Looks good! I think you've definitely got the hardest part knocked out.
03-21-2014, 02:42 PM | #90 |
Boy that sure was a pain in the a$$ getting that pulley to line up. Like you said, I sure hope the rest is smoother sailing.
03-24-2014, 10:34 AM | #91 | |
I'd like to get it off then modify the fender bracket. and bolt it up. Do you know where I can source a the nut that goes on the end pittman arm and holds of the tie rod? The one that came off the manual box goes on and then it stops, I didn't want to mess up the threads. I might try using a wrench to tighten it up to see if it works or not. Also on the ps gear my manual only had 3 bolts holding it on, do I need to have 4 bolts for the ps gear? It would make since to have all 4 bolted down.
03-24-2014, 11:16 AM | #92 | |
I'm not sure if you can buy just the nut. I can't imagine the threads being different, but I'm not sure. I'd spend a few minutes cleaning up the threads....a thread file can work wonders if they are messed up a little. Of course, you should get a new nut if you use a new one pitman arm. I'm sure I have one or two laying around if you really end up needing one. I would definitely recommend using 4 good grade 8 bolts to mount the steering box.
03-24-2014, 11:43 AM | #93 | |
03-24-2014, 12:00 PM | #94 |
Don't forget that you can go to one of the parts stores and borrow tools such as pitman arm pullers and pickle forks
03-25-2014, 12:05 AM | #95 | |
STRANGE THING happened my steering wheel makes a grinding noise when I spin it around. What do you think caused this? Could my steering wheel bearing possibly be out?
03-25-2014, 07:31 AM | #96 |
I don't know what to tell you about the steering wheel.
03-26-2014, 10:32 AM | #97 | |
If you had to adjust the column did you have to drill out those plastic pins in the shaft? And if so are the free floating now? I will have to remove my steering wheel and look at whats binding up in there, wether its the horn contacts or the blinkers. Worst case it is the bearing.
03-26-2014, 10:41 AM | #98 |
I did not have to modify my steering column in any way, the box bolted right up. A lot of people do shorten the steering column by removing the plastic pins and telescoping the column, but I chose to leave mine alone. I think the plastic pins were there as a safety mechanism to allow the column to shorten in the event of a front impact.
03-26-2014, 11:48 AM | #99 | |
03-26-2014, 12:23 PM | #100 |
I picked up a good used power steering gear that had a rag joint on it, so that part of the swap was as easy
