Old 01-31-2017, 03:49 PM   #76
Sweetc10
Re: Ford Windstar E-Fan Wiring Question
hopefully you guys can help me little more. i got the jegs dual fan relay with threaded in temp sensor. do i just wire up on fan off both relays or to both fans. then when it hits the temp both fans come on?
Sweetc10 is offline   Reply With Quote
Old 01-31-2017, 04:02 PM   #77
gmachinz
The Windstar fans are each dual speed- you'll need to power both fans on low from one relay, then both on high off the second relay-however, keep in mind you can't power low speed while high speed is activated-it'll burn out the fan windings. Most "generic" aftermarket fan relay kits are not intended to be ran on anything other than a simple single speed fan. And those Jegs relays better be STOUT if you plan to use anything OEM for an electric fan.
gmachinz is offline   Reply With Quote
Old 01-31-2017, 04:32 PM   #78
Sweetc10
the relay kit i got is Part Number: 555-10570 from jegs. would i be better off going with the cheeroke fan?
Old 01-31-2017, 06:41 PM   #79
gmachinz
That relay kit isn't designed for a dual speed/dual fan setup. As for the Cherokee fan I have no comment because I don't use those fans-however being a chrysler OEM fan those too would be a dual speed fan.
Old 01-31-2017, 09:07 PM   #80
Sweetc10
any suggestions of fan to use with that relay kit?
Old 01-31-2017, 09:13 PM   #81
72MARIO
72MARIO's Avatar
I have used the jeep 2001 ish grand Cherokee fan in factory shroud. Its a 2 wire hook up so I doubt its a 2 speed fan. 1 ground 1 power wire
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-04-2019, 12:59 PM   #82
MDPotter
MDPotter's Avatar
Reviving this thread as a couple of us are in the midst of this wiring.
dayj1-your pictures from post #49 seem to be broken, can you repost the bottom two?
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
