Old 08-30-2014, 05:19 PM   #76
silverbear
silverbear's Avatar
Re: 88 silverado suburban
Your Burb is looking pretty sweet.
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
Old 08-31-2014, 07:06 AM   #77
jott_06
Camaro Club
jott_06's Avatar
Thanks. Since I left the 2wd rear hangers in it, the rear sits about 2 inches lower than the front. Not sure if i want to put a bigger block in the rear or add a leaf. Probably wont worry about it for right now. I'm tired of spending money on little things and it sits like alot of old blazers I see anyway.
jott_06 is offline   Reply With Quote
Old 09-04-2014, 07:44 PM   #78
jott_06
Camaro Club
jott_06's Avatar
got a couple old driveshafts tonight and dropped them off to be made into a one peice driveshaft for the rear of the suburban.
Old 09-10-2014, 06:31 AM   #79
jott_06
Camaro Club
jott_06's Avatar
Got a call from my driveshaft guy saying he didnt want to make a one piece shaft as long as I needed for the suburban so i ran my original 2 piece shaft to him and he is shorting the front half of the shaft and changing the yoke on each end to accept 1/2 ton U joints.
Old 09-10-2014, 06:33 AM   #80
jott_06
Camaro Club
jott_06's Avatar
Has anyone had problems with there fuel guage after converting from TBI to carb? When i turn the key on my fuel gauge goes past full but i know I have less than half a tank.
Old 09-10-2014, 09:14 AM   #81
carboncrew
carboncrew's Avatar
Hmm...I wonder why he didn't want to? It can't be that much longer than a regular cab long bed. Heck, I had one made for my crew. Burb is looking good.
________________
My very own build
My tailgating ambulance
carboncrew is offline   Reply With Quote
Old 09-10-2014, 05:59 PM   #82
jott_06
Camaro Club
jott_06's Avatar
well he said he could make one but it would be expensive because he would have to use larger diameter tubing. I was trying to keep it cheap by having my old short bed shaft re-tubed with a piece of tube from an old car shaft.
Old 09-12-2014, 10:16 PM   #83
jott_06
Camaro Club
jott_06's Avatar
picked up my driveshaft today so progress tomorrow.
Old 09-19-2014, 06:48 AM   #84
jott_06
Camaro Club
jott_06's Avatar
somewhere along the line i seem to have lost my brake lights. Used a test light to check for power to the switch on the pedal but there is nothing. The fuse is good and there is power to the fuse. I read somewhere that it could be related to the turn signal switch on the column. Anyone had this issue before? I did have the column out when i swapped pedals but everything else seems to work. Even the turn signals still work.
Old 09-20-2014, 12:31 PM   #85
jott_06
Camaro Club
jott_06's Avatar
Got the suburban finished enough to take home today. I barely made it though. My driveshaft guy thought he needed to add a second slip joint ahead of the carrier bearing and it let the bearing come out of the rubber.
Old 09-24-2014, 08:55 PM   #86
jott_06
Camaro Club
jott_06's Avatar
pulled the front half of the shaft out and welded the slip joint at the front of the shaft solid so the bearing couldnt walk out of the rubber mount again. I've put probably 5 miles on it so far and no problems. Did have to replace the carrier bearing though.
Here you can see the slip joint he added on the left and the factory one on the right. I'm not sure what he thought was going to hold the bearing in place with a slip joint on each side of it.
Old 09-24-2014, 08:58 PM   #87
jott_06
Camaro Club
jott_06's Avatar
And finally a picture of it back at home. Even though it still needs some work its a blast to drive. I get alot of looks.
I think it needs a little more lift in the rear but it doesnt bother me to bad
Old 09-24-2014, 08:59 PM   #88
jott_06
Camaro Club
jott_06's Avatar
And just for reference, here is what it was
Old 09-24-2014, 09:15 PM   #89
silverbear
silverbear's Avatar
Good job. I look forward to the mods and upgrades you may add to this as you put a few miles on it and you figure out what works well and what didn't turn out as you planned.
1996 GMC Yukon GT
Old 09-24-2014, 09:46 PM   #90
MTCK
MTCK's Avatar
Nice work. Not sure what your driveshaft guy was thinking...
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 09-26-2014, 06:26 AM   #91
jott_06
Camaro Club
jott_06's Avatar
Washed the burb yesterday so I decided to take a pic when i came out of the grocery store but my camera didnt seem to like the light.
Old 09-26-2014, 10:39 AM   #92
NastyBuzzard
NastyBuzzard's Avatar
Very nice job!!
I just picked up a 87 C20 crew cab that has been converted to a short bed. Then converted from 8 lug to 5 lug and dropped.
Now I want to convert it back to 8 lug but 4wd!! May have to just settle for 6 lug 1/2 ton though. Definitly want it 4wd though..
Any advice before I proceed on this adventure?
NastyBuzzard is offline   Reply With Quote
Old 09-26-2014, 11:57 PM   #93
jott_06
Camaro Club
jott_06's Avatar
buy a donor. It really helped me to have the donor truck for all of the hangers, shackles, axles, etc... And plan on it taking longer than expected. lol. Although my suburban was only down for less than 2 months i thought I would have it done much faster. Life gets in the way sometimes though and there were a few weeks that I hardly touched it
Old 09-28-2014, 08:09 AM   #94
jott_06
Camaro Club
jott_06's Avatar
Went on a long country drive last night to try to see if there is anything that needs worked out before I take this on any out of town trips. I did find one thing. As I was topping a hill in second gear i started to get a noise from the transmission. I was close to the house of friend of my wifes so i pulled in there. I must have lost alot of gear oil when i had everything apart. I put a quart in it that i had with me and drove back home. The noise seemed to have went away so hopefully nothing got hurt.
Old 09-28-2014, 11:38 AM   #95
MTCK
MTCK's Avatar
Nice job! You got that thing put together quickly.
-Marcus
Project Plow Truck
Old 09-29-2014, 01:01 AM   #96
COS399
COS399's Avatar
Just in time for hunting season and winter. Good Job!
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 09-29-2014, 08:59 AM   #97
NastyBuzzard
I have a 87 GMC V1500 4x4 single cab long bed I am doing a LS swap in so I can use it for measurements. I have picked up a bunch of 4x4 parts here and there already...
It is going to be a slow process b/c my ls swap is taking full priority.
I also have a 01 Z71 full roller frame I could put this body on and have IFS
Old 10-09-2014, 09:54 PM   #98
jott_06
Camaro Club
jott_06's Avatar
Looks like I will be daily driving the suburban for a while. My boss gave me the day off yesterday for my birthday and while i was inside the house enjoying my day off a tree fell on my Dodge.
Old 10-09-2014, 10:53 PM   #99
y5mgisi
Second Chance Program
y5mgisi's Avatar
Dang! That sucks!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-18-2014, 02:59 PM   #100
jott_06
Camaro Club
jott_06's Avatar
Scored a one piece drive shaft with a slip joint from my local family owned junk yard. Found it in their storage trailer and its the correct length but has bigger U- joints so i'm gonna need some conversion joints. Best of all it was $25. Does anyone know what conversion joint i need to go from 1/2 ton to 3/4 ton?
