Old 03-06-2015, 08:38 PM   #76
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 52 GMC Build
That will look sweet! May rub the paint a bit.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-07-2015, 01:47 PM   #77
DieselRat
Re: My 52 GMC Build
Sweet build. Saw you post in my thread so had to come check it out. Yours will run circles around my little 5cyl diesel haha!
54 GMC OM617 diesel swap
http://67-72chevytrucks.com/vboard/s...d.php?t=588827
87 Chevy Crew Cab Cummins
http://67-72chevytrucks.com/vboard/s...d.php?t=711157
DieselRat is offline   Reply With Quote
Old 03-10-2015, 08:48 AM   #78
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Last night I finally got the box side trimmed up for tire clearance. Then got it temporarily screwed to the truck. The white chalk line is where the outside of the fender is going to be.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-10-2015, 09:43 AM   #79
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I picked up a goodie for my Dana 70 rear end, now I'll lay 4 lines of rubber when I do a burnout. But also help hook up when I want to go.
1951 MG TD
Old 03-10-2015, 02:58 PM   #80
kevinr1970
Re: My 52 GMC Build
Love the look of those fenders, makes it look like it is moving fast, while it standing still!
Originally Posted by lower50's View Post
Been a while had to do some house and daily driver repairs.
Got my box sides bent up. Started trimming for wheel clearance.
Chopped 3" off the bottom of the fender to get it to the height I'm going with.
It's all just clamped now I had to see what it would look like.
The rear is being bolted to my battery boxes and brackets off the frame for the front.
Attachment 1373569
Attachment 1373570
Attachment 1373571
Attachment 1373572
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 03-13-2015, 08:14 AM   #81
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks Kevin1970. It's turning out just the way I envisioned it.
1951 MG TD
Old 03-13-2015, 08:18 AM   #82
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Well I think your only about a 6Hr drive from me. You have a very nice truck
1951 MG TD
Old 03-23-2015, 03:31 PM   #83
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I know it's been a while. I got the box all together and on. Got all the bolt holes for fenders, which was not easy with the truck being so low and no hoist.
This is the front of box side support I made had one of the fender bolts go through it.
Had to cut some of the front of box to clear frame and wires. There will be a bracket to hold front to frame.
Also got the box top tubes welded on turned out very nice.
1951 MG TD
Old 03-23-2015, 03:41 PM   #84
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Time to clean shop out, ready to make running boards. So we pulled the truck out and WOW does it look good. This is the first time EVER I have seen the whole truck. There is no better feeling than seeing what you have built all in one piece out in the sun. Now I really cant wait to finish this and drive it!
1951 MG TD
Old 03-23-2015, 08:42 PM   #85
Dieselwrencher
Re: My 52 GMC Build
Hell yes! That looks sweet man! What do you have planned for the front wheels?
Ryan
Old 03-23-2015, 09:26 PM   #86
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I'm thinking of running the 16" rims that are on it for a while. I'm not putting spacers because I want to keep all that weight under the bearings. Going to get 245 or 255/60/16 tires before I drive it. There is 235/60/16 on it now.
1951 MG TD
Old 03-23-2015, 10:27 PM   #87
oossuuu754
oossuuu754's Avatar
Re: My 52 GMC Build
Loving this build. Never thought I would see a dually and think hot rod, but you are nailing it.
---Shawn
Cecil-1953 5 window build thread
Skymangs..Chris of Old Sarge customs had a shop fire and was severly injured. To help with the medical bills and expenses a fund has been set up here....http://gofundme.com/c49h5mjx8 More details are here...http://67-72chevytrucks.com/vboard/s...=1#post7253189
oossuuu754 is offline   Reply With Quote
Old 03-23-2015, 10:49 PM   #88
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks oossuuu754. I'm happy its all coming together
1951 MG TD
Old 03-24-2015, 12:03 AM   #89
SSABMUD
SSABMUD's Avatar
Re: My 52 GMC Build
This is a pretty cool idea. 7.3 was a good engine. I used to own a company that built custom diesel trucks. Mostly the 6.4 but the old 7.3's have a huge following. We could get them up to 350hp. More could be had but it all boiled down to how much money the owner wanted to spend.
Wade
SSABMUD is offline   Reply With Quote
Old 03-24-2015, 03:22 PM   #90
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Wow SSABMUD That's a crazy twin turbo set up!! I'm hoping for 300 hp and 500 lb. Diesel Doctor is close to where I live. They said with my setup I should be able to but we will see.
1951 MG TD
Old 03-24-2015, 03:27 PM   #91
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got one of my running board frames made today. I used 1.25" tube
1951 MG TD
Old 03-26-2015, 06:17 PM   #92
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got the running boards finished and welded on. The truck will sit on them when it's all the way down. The frame is 3.5" off the ground, I came straight down from under the frame then out from there. I used 5/16" sst flat head bolts to hold the 3/16" aluminum checker on.
1951 MG TD
Old 03-26-2015, 06:18 PM   #93
lower50's
lower50's's Avatar
Re: My 52 GMC Build
1951 MG TD
Old 03-26-2015, 08:05 PM   #94
SSABMUD
SSABMUD's Avatar
Re: My 52 GMC Build
On the second dyno run it made 1076hp with a broken header. If you want to see some videos my ex business partner made of it on YouTube, just search (TheDrsmoke) and it is called the farm truck. It was a custom 2wd (I said to get 4wd) short box we built for racing. Could not hook it up on the track so we made a street truck. Punch it on the highway at 60 and it would go sideways. Ah the good old days.
Wade
Old 03-26-2015, 08:16 PM   #95
Dieselwrencher
Re: My 52 GMC Build
The running board looks great!
Ryan
Old 03-26-2015, 08:50 PM   #96
SSABMUD
SSABMUD's Avatar
Re: My 52 GMC Build
She is looking real good. What will be ride height? Going to be a bear to get a floor jack under. Mine is tough but not as tough as yours.
Wade
Old 04-07-2015, 12:43 AM   #97
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
nice work and vision, dunno how I missed your build. I always wanted to do a diesel build. bags, dually and diesel, you got all the right stuff.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-07-2015, 01:50 AM   #98
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks Dieselwrencher
1951 MG TD
Old 04-07-2015, 01:53 AM   #99
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks SSABMUD At 120psi on the front bags I get about 4" and at 150psi I get 5.5" running board height.
1951 MG TD
Old 04-07-2015, 01:54 AM   #100
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks 99
1951 MG TD
bagged, build, diesel, gmc, hot rod
