Old 01-01-2015, 03:28 AM   #76
yahoos
yahoos's Avatar
Re: !964 Biscayne. Birdie Sue.
Originally Posted by nlped View Post
I'm watching man. Your ride is friggin cool
Appreciate it buddy!
yeah buddy
yahoos is offline   Reply With Quote
Old 01-01-2015, 09:06 AM   #77
flashed
Im still watching too ,like the blanket idea over the speakers too.
flashed is offline   Reply With Quote
Old 01-01-2015, 10:19 AM   #78
Advanced Design
Advanced Design's Avatar
I like the idea too. Creative and looks good!
Advanced Design is offline   Reply With Quote
Old 01-01-2015, 12:32 PM   #79
yahoos
yahoos's Avatar
Thanks guys. Going to go over today and get some more done here in a few!
yeah buddy
Old 01-02-2015, 10:59 PM   #80
yahoos
yahoos's Avatar
Made some progress today.
Finally mounted my cover. Bought some hinges and flipped them around backwards where they were all the way open then mounted them
Then the board was barely hitting the tank and the valve so I had to build a lip to raise it up
At this point I locked my keys in the trunk slowing me down some. Got them out tho!
Wrapping the cover
Installed
The back door panels were falling apart at the bottom and the PO had taped them. I had a few scraps and decided to fix them up some. I only have enough to do the back to doors unfortunately
I used so foam board, blanket, and good tape to do this.
Not the best but better then tape and for free I will take.
I also removed the radiator since I have a new one on the way. I also started installing some mech gauges in the glove box. I just got some more parts in today so more progress tomorrow. Im pooped and ready for a beer!
yeah buddy
Old 01-03-2015, 01:02 AM   #81
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
You are doing such a awesome job I love the way its turning out!!
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 01-03-2015, 06:21 PM   #82
duallyjams
duallyjams's Avatar
got the blanket all you need now is the picnic basket
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-03-2015, 11:37 PM   #83
yahoos
yahoos's Avatar
compressors mounted.
plumbed into the tank
mech gauges in the glove box. Temp mount for now.
new yoke.
new radiator installed
Ran and hooked up the power glide cooler lines and they worked good. A few bends and they went right in
I did have some set backs. I need the transmission tail shaft 3/4 in lower so I need to rework/redo the crossmember woohoo.
On a plus side I cranked her up tonight and I barely even touched the key and she fired right up.
yeah buddy
Old 01-03-2015, 11:45 PM   #84
nlped
nlped's Avatar
Looks great man!
If I can offer some advice though... Don't run that flex fan, problems waiting to happen. Good old fashion clutch fan is the way to go.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 01-04-2015, 12:11 AM   #85
yahoos
yahoos's Avatar
Looks great man!
Ya I know the PO put that on there. I dont like them. That being said I had one on my 4.3 luv that came with the motor and no shroud but a good aluminum radiator and that thing could barely hit 180 on a hot day. I agree tho. And it looks tacky.
yeah buddy
Old 01-04-2015, 10:36 AM   #86
Advanced Design
Nice work on those cooler lines!
Old 01-05-2015, 12:35 AM   #87
Mello Mel
African-American Shaolin Monk
great job..... always look forward to seeing your posts.
Mello Mel is offline   Reply With Quote
Old 01-08-2015, 12:49 PM   #88
yahoos
yahoos's Avatar
Over the past few days ive been getting abunch of small stuff addressed but here is some of the things thats been going on with Birdie Sue.
I went to measure tfor having the drive shaft shortened and realized the tail shaft was too high. Thanks to my crossmember I made. OOPS. About 3/4in too high. I took the factory one and sectioned it back and then drilled a hole for the mount. Next I had to cut the front at about 45s to clear the pan. Its tacked up and works like I need next I will brace it and what not.
Last night I finished putting vavles in and checking for leaks. Im going to turn the other 2 release valves upside down as well. Im not to worried about what it looks like under here as in I want function. I dont care which way the valves face really as long as I get the lines going where they need to go and no leaks. Thats what the cover is for is to hide it!
I didnt see any bubbles after fixing a couple issues and checking for leaks so we will see.
I bought this off ebay to mount my radio under the seat. Its solid and was cheap. Beat building something.
I have to say Im impressed with how it sounds it sounds badass! And my fav part is the radio and all 6 speakers are hidden. I took my driveshaft to have it shortened and the rear be able to telescope.
Im having jaw surgery later today so I will be down for a few. Later guys
yeah buddy
Old 01-08-2015, 12:54 PM   #89
68basket
Looks great. I love the radio solution. I may look into something similar for mine
68basket is offline   Reply With Quote
Old 01-08-2015, 01:13 PM   #90
flashed
That turned out great ,I used the same radio holder in my BuddyBucket console for my stereo ,looks like the same stereo even and it plays great . Sonic Electronics is where I got mine for cheap ,the holder that is .
Old 01-08-2015, 02:21 PM   #91
tommys72
tommys72's Avatar
looks good! nice work
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 01-08-2015, 08:09 PM   #92
yahoos
yahoos's Avatar
with mounting it as far right as I could and the volume knob being on the right I can easily reaach under there to turn it down.
yeah buddy
Old 01-09-2015, 09:33 PM   #93
JHT67
JHT67's Avatar
Originally Posted by yahoos View Post
I dont think anyone likes my build lol. Ill keep posting though.
Don't you dare even think about not posting. Lots of silent onlookers here, so yea, keep posting. Certain cars keep me coming back to alternate tinkering a and this is one of them, it's not just the rides I also love the threads that make good progress.
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord.........
JHT67 is offline   Reply With Quote
Old 01-09-2015, 11:11 PM   #94
flashed
I agree with the above ,I dont always post on a thread Im viewing or following due to time but Im still in .
Old 01-10-2015, 12:18 PM   #95
yahoos
yahoos's Avatar
Finally got the correct alternator belt I needed. The new valve covers only aloud like an inch of adjustment so finding the perfect ones been fun
driveshaft back from the shop. Had the front shortened and the rear made to telescope. messed up one u joint assembling so have to re tackle that. aloud me to tape and flat black though.
all wires and connectors done. sensors all done and left side airlines installed. Looks like I wasn't paying attention when I put the relays in because they are right in the way where the passenger side lines need to come through,
Ran some of this plastic tubing over my DOT line to protect it.
Getting closer. Weld up the trans crossmember. Install driveshaft. and hook up the 2 airlines and I should be ready to check fluids and go for a little test drive.
yeah buddy
Old 01-10-2015, 09:30 PM   #96
Advanced Design
Great progress! Bummer about the relays being in the way.
Old 01-11-2015, 03:29 AM   #97
yahoos
yahoos's Avatar
Got the drive shaft assembled and installed. Front shaft is shortened. cpp bearing. Rear shaft now telescopes. and all new u joints of course. Shouldnt have any issues here like some people who just bag these cars.
Got all the airlines hooked up and got to lift the car with her own air for the first time! really like the avs 9 switch box. Looks like a couple more compressors and another tank may be in the future.
Started here up and let her warm up. May be a small leak coming from the radiator cant tell yet. Everything else looked good. Backed her up and drove her forward in the shop a handful of times and let her keep warming up. Ran the shifter through the gears and topped off the fluid on the trans. Man does this thing run good. Hit the key and vroom right up. Backed her out of the shop and laid her out outside all under her own power. Big accomplishment. Dont really wanna drive it until its light out.
To do list. Weld and brace trans crossmember. Determine if I have a small leak or if thats just left overs from a huge mess I made first starting the car. I know something on the power steering is leaking. Hook up ps belt and see what part I need to replace on it. I still want a different fan for the car aswell. Thinking I may slap a new water pump on it too.
Getting closer fellas. Tomorrow hopefully I can take her up and down the road and see about adjusting the tv for the 700r4.
yeah buddy
Old 01-11-2015, 08:21 AM   #98
Advanced Design
Congrat's on the start! Looks good!
Old 01-12-2015, 10:08 PM   #99
Mello Mel
looks good...... i plan on putting a 700r4 in mine this spring.....
Old 01-13-2015, 11:18 PM   #100
yahoos
yahoos's Avatar
Made the second trans cross member. Dropped the tail shaft like I needed it to.
Took her for a drive. Everything is good except a little clunking I can hear every now and then and a vibration I could feel at about 70mph. Will figure these out. Im thinking its a driveshaft issue. For all the work done Ill call it a success. cruised it for 30 mins solid and ran great. Nice and cool and good oil pressure.
My buddy Matt who has helped alot with this car
Danielle who has TRIED to help alot hahahahah
yeah buddy
