02-24-2015, 10:07 PM | #76 |
Re: 1961 Crew Max
Awesome thread. Not sure how you guys pull things like this off. Looks like you have it handled though.
Will be following this one.
Are you a collector? If so come check out Collectorsunleashed.com Doesnt matter what it is we have a spot to show it off. http://www.collectorsunleashed.com/# |
02-24-2015, 10:20 PM | #77 |
Re: 1961 Crew Max
Subscribed!
1965 C10 LWB SBW, 292, SM420 1963 Chevy II SS 1951 Chevy Business Coupe Gasser 1949 Willys Overland |
02-24-2015, 10:52 PM | #78 |
Re: 1961 Crew Max
Is that an original willys that you sold? Trucks are lookin pretty sharp. Should be a cool ride when it's done
My names Tye. No Chevy right now |
02-24-2015, 10:55 PM | #79 |
SAVING ONE TRUCK AT A TIME
Re: 1961 Crew Max
I wish. 36 ford 5 window coupe.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
02-25-2015, 12:09 AM | #80 |
1961 crewcab
Re: 1961 Crew Max
wow! lots of work! but its coming along.
something I noticed on mine: the rear of the front door gets super close to the rear door hinge when you open it. at one point I had the rear door gap opened up too far ( with a porta power) and it pushed the hinge far enough forward that the front door wouldn't open... it was quite a process to get the pillar in the right spot so that the inner rear of the rear door wouldn't hit the jamb when closing, and the rear of the front door would clear the hinges, and still maintain a decent gap between the 2 doors.... lmk if you need measurements of any of this stuff.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
02-25-2015, 12:35 AM | #81 |
Re: 1961 Crew Max
Chizzler, you are getting a good solid start on the floor! The donor vehicle looks pretty solid.
02-25-2015, 01:23 AM | #82 |
Re: 1961 Crew Max
Ah. Couldn't see much on this little phone. I almost bought a 39 a while back for a rat rod project but didn't get it. Anyway good luck on the build. I'm lookin at a 65 Chevy stepside after I finish my crew cab
03-02-2015, 11:12 PM | #83 |
Re: 1961 Crew Max
Quick update. New floor pans are in. Old rockers are cut out and getting ready to put doors back on. New cab mounts are mocked up but not fully welded. Also purchased a lb rolling chassie to be stretched. Also put the duramax wheels on because the other wheels had three different size tires. Thanks CHIZZLER.
03-02-2015, 11:33 PM | #84 |
Re: 1961 Crew Max
Can someone help with moving this thread to the projects section. Thanks
03-03-2015, 06:30 AM | #85 |
Re: 1961 Crew Max
She has been moved for ya. Nice work on the pans and all.
03-03-2015, 09:30 AM | #86 |
Re: 1961 Crew Max
Nice work on the floors Chizzler. Where did the panels come from?
03-03-2015, 10:25 AM | #87 |
Re: 1961 Crew Max
Sheet metal all came from top banana.
03-03-2015, 09:16 PM | #88 |
6>8 Plugless........
Re: 1961 Crew Max
Nice job on the floor/support replacement. It sure looks nice.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-04-2015, 12:16 AM | #89 |
Re: 1961 Crew Max
Great looking project. Looks like it's too late to suggest using the newer frame/running gear with the firewall and floor mated to the upper parts of the cab and dash from the 61
Matt 43 |
03-04-2015, 12:33 AM | #90 |
Re: 1961 Crew Max
That would have been to easy. Plus it will be 2wd and the d-max frame is huge.
03-07-2015, 10:47 PM | #91 |
Re: 1961 Crew Max
Some progress updates. Passenger side rocker replacement went pretty good. Lots of fitting,trimming to make everything fit. Front door was short 3/8" compared to back door. Ground down bottom edge of rear door to make rockers fit for now. Will probably end up replacing bottoms of all doors to make them line up. Also bottom of front pillar replacement pieces do not come with welded nuts for mounting cab supports. Had to weld on backing plates with nuts.
03-07-2015, 10:52 PM | #92 |
Re: 1961 Crew Max
A few more pics.
03-07-2015, 11:06 PM | #93 |
Re: 1961 Crew Max
Nice repair work Chizzler. Looks warm outside there too. Nice.
03-07-2015, 11:09 PM | #94 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: 1961 Crew Max
Wow! Lookin awesome!
That is a lot of rocker to line-up! The gaps look good so far!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
03-07-2015, 11:16 PM | #95 |
1961 crewcab
Re: 1961 Crew Max
lookin nice! do you have pics of what you did for the center of the inner rocker?
03-08-2015, 09:07 AM | #96 |
Re: 1961 Crew Max
Center section of the inside rocker is not in. Im going to try and add a cab mount at each b-pillar. I did the bottom repair the same as you did with the intent of using the welded on nuts to align a new cab mount. waiting on parts.
03-08-2015, 06:39 PM | #97 |
1961 crewcab
Re: 1961 Crew Max
I was thinking of doing the same thing... add a little more strength to the pillar.
03-10-2015, 03:44 PM | #98 |
1961 crewcab
Re: 1961 Crew Max
did yours have a front seat in it when you got it?
I am trying to figure out what it was backed with. mine has screw holes around the perimeter and the screws , but nothing else... I am wondering if it was the same material as the headliner, or a metal panel...? in this old pic it is hard to tell... also did yours have a rear seat, and did it appear to just be a front with solid supports like mine has? I am checking the seats for fit, and the seats seem real close together... (last photo is the only pic I have of this style with the seats in it)
03-10-2015, 09:52 PM | #99 |
Re: 1961 Crew Max
My seats look like the bottom 3 pics you posted. My front seat still has some screws on the back side but nothing else. Rear seat appears to be a front seat with a sold base.
03-11-2015, 02:03 AM | #100 |
1961 crewcab
Re: 1961 Crew Max
thanks, I'll have to do more research and try to figure out what was on the back of the front.
