Old 11-19-2015, 08:24 AM   #76
enigma
Re: Project Old fishing truck
Excellent job amazing of the talent that people have.
enigma is offline   Reply With Quote
Old 11-28-2015, 10:01 AM   #77
ckcp
thanks i appreciate it
ckcp is offline   Reply With Quote
Old 11-28-2015, 10:02 AM   #78
ckcp
I made some good progress on the truck and just ave a few things left and it will be on the market i am really happy with my faux patina/some of it is real but enjoy let me know what you think of it (i know the doors and cab should be red oxide primer i just liked the way the black looked on the blue) how i achieved what i did is i sanded the blue with 1000 then i sprayed black single stage at a real low pressure (8psi) with the fan pattern on the gun turned all the way down and gave it pour overlap then buffed it out with a super cutting compound until i kind of liked what i saw then stepped it up to #1 cutting compound then #2 with the #2 pad then #3 with the #3 pad i guess i could have taken better pictures i did not realize they where so bad and blurry
Old 11-28-2015, 11:46 AM   #79
rusty76
rusty76's Avatar
Truck looks great.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 11-28-2015, 05:16 PM   #80
ckcp
Originally Posted by rusty76 View Post
Truck looks great.
thanks man
Old 11-28-2015, 11:00 PM   #81
CURSED GEARS
Pretty cool!That baby is low!
CURSED GEARS is offline   Reply With Quote
Old 11-30-2015, 10:13 AM   #82
ckcp
thank you
Old 11-30-2015, 10:25 AM   #83
ckcp
small progress
Old 12-04-2015, 04:06 AM   #84
jadedbird
jadedbird's Avatar
love the build. what steering wheel is that
jadedbird is offline   Reply With Quote
Old 12-07-2015, 03:04 PM   #85
ckcp
Thanks and it is a 1962 Pontiac tempest
Old 12-07-2015, 05:14 PM   #86
USSkoval
Do you plan on only driving this on nice flat, smooth roads and only taking slow turns (to avoid body roll)? You basically have a ladder bar rear suspension, but the bars are mounted outboard and made of square tube with no torsional flex. As it is now, the axle can only travel freely if both sides are moving up/down the same amount, and anything other than that causes bind.
Maybe the long bars can let you get away with it, if there's little suspension travel. But it's still a lot of stress on those u-bolts.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 12-11-2015, 09:18 PM   #87
ckcp
the only reason i went this route on this build is to keep cost down. i know its not the best setup of choice but thought i would try it i have already been lectured on it on another forum and if it don't work i can add some upper linked and redo the rear of the lower links thanks for the concern but for me right now every dollar matters. i have played with the air ride and do have some movement but yes i wont really know until i take it for a drive.
Old 12-11-2015, 09:22 PM   #88
ckcp
more small progress was made bed side moldings started working on the bed floor side marker lights and mounted the heater delete and washer bottle
Old 12-12-2015, 08:59 PM   #89
USSkoval
I can certainly understand the cost issue, it will be interesting to see how well it holds up. However it would be a good idea to keep an eye on u-bolt torque, as well as checking for any cracks where the the u-bolt tabs are welded to the square tube.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
Old 12-12-2015, 09:13 PM   #90
ckcp
yes i will be keeping a close watch on everything as long as i have the truck for
Old 12-13-2015, 09:04 PM   #91
ckcp
more small progress today drilled lots of holes still need two more strips that are the right length then i will paint the wood to a patina white
Old 01-25-2016, 01:10 PM   #92
ckcp
And after a year and almost one month it is done and on the market. Here are some of my favorite shots from the 130 that i took that day enjoy.
Old 10-13-2016, 09:47 AM   #93
Haterdave
Looks good.
You.got any better pics of those hood hinges you built? Or just a basic rundown of how they work so I can build em lol and not spend 400on pb ones
Haterdave is offline   Reply With Quote
Old 10-13-2016, 09:20 PM   #94
swamp rat
swamp rat's Avatar
Job well done!!!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-26-2017, 08:12 AM   #95
Spblack
Spblack's Avatar
do you have any photos of your bed floor hinges? looks awesome.
1959 Chevy Apache (sold)
1958 Fleetside Current
My builds:
http://67-72chevytrucks.com/vboard/s...d.php?t=606412
http://67-72chevytrucks.com/vboard/s...=1#post7560906
Spblack is offline   Reply With Quote
Old 07-26-2017, 12:28 PM   #96
Devil Pup
Devil Pup's Avatar
Turned out awesome!
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388
Devil Pup is offline   Reply With Quote
Old 05-31-2018, 02:14 PM   #97
SeanDub
Awesome build man, thanks for sharing.
SeanDub is offline   Reply With Quote
Old 05-31-2018, 11:57 PM   #98
cornerstone
cornerstone's Avatar
Striking photos bud! love the paint too, lots of hard work paid off
cornerstone is offline   Reply With Quote
