Old 03-22-2015, 01:46 AM   #76
swamp rat
swamp rat's Avatar
Re: 1968 Gmc ground up restoration
The under dash lights almost look like a marine application.
Here's an old for sale thread that has what i believe are the original style under dash light at least for the blazer, thought if nothing else you may want to see what they look like.
http://67-72chevytrucks.com/vboard/s...=vanity+lights
Your making nice progress!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-22-2015, 01:01 PM   #77
tim's68gmc
tim's68gmc's Avatar
Nice lights never seen those ones before
vehicle's I own 1968 gmc 3/4 ton camper special
1972 gmc jimmy
1972 Chevrolet nova
1947 ford 1.5 ton dully
1997 f-350 1 ton
2007 Chrysler 300 with hemi
tim's68gmc is offline   Reply With Quote
Old 03-22-2015, 01:05 PM   #78
tim's68gmc
tim's68gmc's Avatar
We got some grinding and welding done yesterday, Lots of little holes to fill and a few larger ones.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-22-2015, 01:07 PM   #79
tim's68gmc
tim's68gmc's Avatar
More grinding and welding photo's.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-22-2015, 01:11 PM   #80
tim's68gmc
tim's68gmc's Avatar
Made a fillers for the aftermarket a/c holes. More grinding till the air compressor busted the inter cooler tube.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-25-2015, 05:10 PM   #81
sboris
sboris's Avatar
Hell of a job so far. You guys are really getting after it! Looks like a good score on the cab, Wish I could have started with one that nice. Neat project to do with your son, that's great.
Ps, nice jimmy!
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 03-27-2015, 12:25 PM   #82
tim's68gmc
tim's68gmc's Avatar
Ps, nice jimmy!
thanks its a big project but we are moving along pretty good.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-27-2015, 01:51 PM   #83
justin4260
justin4260's Avatar
awesome build thread man. love how many pictures you post. making it look easy
justin4260 is offline   Reply With Quote
Old 03-29-2015, 11:48 AM   #84
tim's68gmc
tim's68gmc's Avatar
Didn't get a lot done Saturday on the truck. Did do some welding on the center hump trying to fill in the messy torched cut hole that was put in for a manual transmission. I did put some new headlights on my farm truck with 260,000 miles the headlights were shot.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-07-2015, 11:50 PM   #85
tim's68gmc
tim's68gmc's Avatar
We were in spokane this last week and came across this killer truck.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-07-2015, 11:54 PM   #86
tim's68gmc
tim's68gmc's Avatar
Picture 1 a couple holes that looked like a bullet blasted thru, now welded smooth.
Pictures 2-5 old holes from after market a/c plugged and welded.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-08-2015, 12:00 AM   #87
tim's68gmc
tim's68gmc's Avatar
Today took a break from working the cab and started to repair the driver's side fender.
Picture 1 bondo filled rust
picture 2 pile of rust after removing skin.
picture 3 -5 sub frame had some rot so made a replacement for the rusted pice all ready to weld in.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-08-2015, 12:20 AM   #88
Bowtiguy
Bowtiguy's Avatar
I'm guessing bullet holes from road hunting with the safety off...
Bowtiguy is offline   Reply With Quote
Old 04-08-2015, 12:41 PM   #89
swamp rat
swamp rat's Avatar
You do know he has a build thread here right? Trucks name is Drill Sargent.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-09-2015, 08:43 AM   #90
tim's68gmc
tim's68gmc's Avatar
Yes that is were i seen the truck at his shop.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-13-2015, 06:11 PM   #91
tim's68gmc
tim's68gmc's Avatar
Photo # 1- 2 welded in the structure patch
Photo # 3 - 4 made the patch for the outer skin
Photo # 5 fit check the new patch looks like this will work.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-13-2015, 06:16 PM   #92
tim's68gmc
tim's68gmc's Avatar
Bryce is doing the grinding and I get to do the welding. Nothing better learning how to weld by grinding a lot of welds. Patch is all welded in and ready to go.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-13-2015, 06:20 PM   #93
tim's68gmc
tim's68gmc's Avatar
We also did a little bit on the cab Bryce welded up some more of the little holes around the back window. We also took out the front windshield.
Anyone got a good way to remove all the sticky tar/glue from around the frame??
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-14-2015, 08:16 PM   #94
tim's68gmc
tim's68gmc's Avatar
Bryce and I messed around a bit and decided to air out the inner cowling and this is what we got out, a lot more than i expected.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-14-2015, 08:23 PM   #95
tim's68gmc
tim's68gmc's Avatar
After cleaning out the inner cowling I noticed the passenger side lower door hinge mount only had 1 nut showing photo 1.
Decided to cut into the lower part of the hinge post to find out the nut assembly spun out of the mount. With a little help with the punch and hammer we got it back into the mount and all is good.
While the hinge post was cut open we sprayed rust encapsulate into the opening. now we have the cut out prepped and ready to weld up.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-15-2015, 03:46 AM   #96
swamp rat
swamp rat's Avatar
Nice fix! Must be nice having a helper in the build too.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-21-2015, 11:27 PM   #97
tim's68gmc
tim's68gmc's Avatar
Got a few more pieces primed with epoxy primmer then primed with high build primer.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-21-2015, 11:30 PM   #98
tim's68gmc
tim's68gmc's Avatar
New photo of the chassis with rails temp attached and radiator core support temp. attached. Starting to look more like a truck
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-22-2015, 06:48 PM   #99
tim's68gmc
tim's68gmc's Avatar
Got some sand blasting done on the cab today.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-24-2015, 09:34 AM   #100
zellway
zellway's Avatar
making good progress. always cool to see a GMC getting a little love.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
