03-24-2016, 11:59 AM | #76 |
Re: 1969 C-10 CST Build
a few more
03-24-2016, 12:00 PM | #77 |
Keep it clean wiring harness
new headlight relays, thanks to some of you for the suggestion. |
03-24-2016, 12:01 PM | #78 |
and some more
03-24-2016, 12:02 PM | #79 |
my little helper, Addison.
i decided to go this route for a headliner for speakers and for the gauge pod. It is advertised as a radio place, not gauge pod, but .... |
03-24-2016, 12:03 PM | #80 |
and some more....
03-24-2016, 12:04 PM | #81 |
lets try that again
03-24-2016, 12:06 PM | #82 |
more...
03-24-2016, 12:07 PM | #83 |
inner fenders on
new alluminum radiator AC and my negative battery cable disconnect |
03-24-2016, 12:08 PM | #84 |
last of them for a while..
09-05-2016, 09:28 PM | #85 |
Updated with completed pics for the most part. Few details to work out still, but overall its a driver now!!
09-05-2016, 09:29 PM | #86 |
more pics.
The bed is made from Black Locust that does glow under black lights. |
09-05-2016, 11:20 PM | #87 |
Great looking truck!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
09-06-2016, 12:00 PM | #88 |
Thank you swamp rat!!
09-06-2016, 12:15 PM | #89 |
I love the gauges!!
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
09-07-2016, 03:55 PM | #90 |
very nice!
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
09-08-2016, 10:34 AM | #91 |
Your exhaust is similar to something I thought of years ago. Running the pipe out of the header and under the frame, BUT you could run the tail pipe straight out the back. You can calculate how far the rear coils springs will compress completely and route your pipe accordingly.
Of course if you have 18" wide tires, this deal may not work. Mounting the muffler body vertically can help also. I told a friend about my idea. He built such a system on his 66 C-10, it worked nicely. |
01-04-2017, 01:57 AM | #92 |
So i ran the truck for a short amount of time, about 100 miles and i just did not like what i had completely. What i did not like is that it would get hot quickly. so it needs better electric fan with a shroud. Then it had a wierd vibration and noise. i was nervous about what i had done with rear end, so i decided it was time to rebuilt it completely, so i will get the gears and posi i wanted. The motor just would not run very good, so i traced it the heads that were 305 heads with very small ports making the compression over 10:5 to 1. It sucked, so now new aluminum heads with 72cc chambers and a new intake. Along with that, well lets install a full MSD ignition. and last is conversion to floor shifter from column so a new column is installed from CPP.
01-04-2017, 01:58 AM | #93 |
more pics
01-04-2017, 02:00 AM | #94 |
few more
01-04-2017, 02:01 AM | #95 |
more
01-04-2017, 02:07 AM | #96 |
unfortunately i have yet to start or run it with the new upgrades. I recently got word that i need surgery for neck discs that are degenerative to the point of causing numbness in my left hand and pain that is crazy, so Dec. 27th i had a double disc fusion, so im down and out for a couple months.
But i do have a couple other things i need to do. I need to change out the stock power brake booster and disc and drum prop. valve with disc all around. Then i am looking at building a custom center console that i will then mount a new floor shift onto. I think i want to install a B&M Pro Stick. I used one on my 1966 Chevelle and loved it. I have been playing around with FITech also, just thinking.... |
01-06-2019, 07:41 AM | #97 |
Well its been a while since i updated my progress... alot has changed..
6 lug to 5 lug conversion |
01-06-2019, 07:42 AM | #98 |
Wilwood addition...
01-06-2019, 07:44 AM | #99 |
Autometer Phantom Gauge conversion
01-06-2019, 07:45 AM | #100 |
New rims and Tires...
