Old 06-25-2015, 09:45 AM   #76
oldman3
oldman3's Avatar
Re: My 54 3100 pickup build
All I can say is WOW, fab work is over the top. Looking forward to your next update...Jim
oldman3 is offline   Reply With Quote
Old 06-25-2015, 10:37 AM   #77
Chevy-49
Chevy-49's Avatar
Great pictures, nice mod's
Over here we have only 24 hours to spend in a day.....
My build thread: 1949 AD truck 'Chevy-49'
Chevy-49 is offline   Reply With Quote
Old 06-25-2015, 10:40 AM   #78
Advanced Design
Advanced Design's Avatar
Very impressive fabrication!
Advanced Design is offline   Reply With Quote
Old 06-25-2015, 11:01 AM   #79
SPEEDYS GARAGE
SPEEDYS GARAGE's Avatar
Haha, thanks mate, id like to say our coffee is stronger down under, the truth is its been on going for two years now, only now I have decided to kick it in the guts. Before it ends up on the shelf like my other projects. Also no wife, no kids = free time.
"There are two types of people in this world: those who like Chevy pickups, and those who don't."
SPEEDYS GARAGE is offline   Reply With Quote
Old 06-25-2015, 11:03 AM   #80
SPEEDYS GARAGE
Thank you, hitting things with a hammer is my favourite form of exercise
Old 06-25-2015, 12:28 PM   #81
ptc
ptc's Avatar
Originally Posted by SPEEDYS GARAGE View Post
Thank you for your kind words. Like most of us, I have a go, stuff it up, keep going till I get it right and then I show the pics .
Makes me look like I know what Im doing :-)
Hahaha.... yea its always good to look at a guys 'scrap pile' .... "testing parts" is always the most costliest part of a build! .... really nice work there, looks great for all the hours put into it.
Thanks for the write up!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 06-25-2015, 12:53 PM   #82
slammed57
slammed57's Avatar
nice work on the frame
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 06-26-2015, 04:53 PM   #83
reaper71
reaper71's Avatar
Killer Build looking forward to more progress updates..
Mark...
reaper71 is offline   Reply With Quote
Old 06-27-2015, 10:53 PM   #84
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Great work! Keep the updates coming please!
ChuckDriver is offline   Reply With Quote
Old 07-01-2015, 05:25 AM   #85
SPEEDYS GARAGE
Here is a good shot of the dash steel work. Ie.. No ashtray, RHD swap.
Old 07-01-2015, 05:33 AM   #86
SPEEDYS GARAGE
Here is the rear leaf spring hanger , has a hole to drain water, came out pretty good I think.
Old 07-01-2015, 05:36 AM   #87
SPEEDYS GARAGE
Here is the back lower view, captive nut for the main bolt,
Old 07-01-2015, 05:39 AM   #88
SPEEDYS GARAGE
Test fit time
Old 07-01-2015, 07:56 AM   #89
SPEEDYS GARAGE
Here it is all mounted. Got the rear curb weight of the truck, took off 220 pound for the 9". Minus 150 for rims and tires, that left about 616 lbs or 308 lbs per spring.. (140kg) so i layed a spring out on the ground, loaded 100kg of old batterys on the spring and measured the change in height. Stood on the spring as well, and measured that. Set the spring height based on the loaded weight guestimate and voila. Your impressed by my mathmatical ineptitude right? Redneck calculator rocks.
Old 07-01-2015, 08:06 AM   #90
SPEEDYS GARAGE
ALRIGHT, after a day of stuffing about on the truck (instead of working) I finally got her off the frame table, so happy to see it at ground level. Luvin the ride height. Although I cant get the wheel in or out with the fender on. But damn it looks good
Old 07-01-2015, 08:11 AM   #91
SPEEDYS GARAGE
So I guess its about 6 inch drop on the rear, and 5 inch in the front. Floor board is 5.7" off the deck.
Old 07-01-2015, 08:14 AM   #92
SPEEDYS GARAGE
Better do some paying work for a few days, back soon.
Old 07-01-2015, 08:24 AM   #93
FarmerSid
FarmerSid's Avatar
Ride height is perfect!
"Although I cant get the wheel in or out with the fender on. But damn it looks good"
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 07-01-2015, 08:46 AM   #94
oldman3
oldman3's Avatar
Looks great, run flat tires and your good to go...Jim
Old 07-01-2015, 12:01 PM   #95
Advanced Design
Looks really good and I like the "redneck" math. It proved the concept. Nice work.
Old 07-01-2015, 12:18 PM   #96
ChuckDriver
Nice, stance looks great!
Old 07-01-2015, 06:21 PM   #97
SPEEDYS GARAGE
@ChuckDriver @Advanced Design @FarmerSid @oldman3
Thanks guys, pleased you like my ride.
Old 07-11-2015, 07:39 PM   #98
SPEEDYS GARAGE
Time for a little motor TLC, this is my late 2004 GTO LS1 DBW 50,000 mls. Getting a good degrease, pressure wash, acid treatment, etc. masking up for painting in satin black high temp .
Old 07-11-2015, 07:46 PM   #99
SPEEDYS GARAGE
After about half a day prep and masking all the bolt heads for a professional looking job, it came out great. As with all bare alloy that has been subjected to weather and oil, its never going to be like new, but the more effort you put in now the longer it will keep its appearance. I know it will turn to crap later, but its my shop truck, so much to do, gotta keep moving forward.
Old 07-11-2015, 07:53 PM   #100
SPEEDYS GARAGE
Next job was to drop the front sump out and fit a rear sump from a hummer, turns out that f@cker is really deep and hangs a little low, so later I will swap it for a Camaro one. But here it is painted and mounted anyway.
The dip stick no longer feeds through the pan, and there is a hole in the block just forward of the starter, you can knock the plug out with a punch, there is no step or shoulder, just tap straight thru.
Note.... If you use the Hummer sump, the lower bell housing to sump bolt hole on the right will be out. So no bolt going in that. And dont forget to seal the 4 corners on the pan gasket where the seams are on the block. Or they will leak
1/2 ton, 1954 chevy, 3100
