06-22-2017, 04:25 PM | #76 |
Re: 1971 C-10 Cheyenne
A few more
08-21-2017, 12:10 PM | #77 |
Nick's truck won "best truck" at the Street Car Takeover show over the weekend.
08-21-2017, 05:40 PM | #78 |
Who Changed This?
Nice transformation! Gotta be proud of a trophy, too!
08-21-2017, 07:06 PM | #79 |
Enjoying this build - aside from all the obvious work, I see lots of nice little touches.
I like the look of your radiator. Whose is it? and how do you like fit, finish and function? Looks like a Griffith performance fit? Thanks. |
08-30-2017, 03:59 PM | #80 | |
Thank You. It is a Griffin, when I bought it they were called direct fit but now when I look at my order history at Summit Racing it says performance fit. It is a combo unit with the fans set up for the LS swap so both inlet and outlet are on the passenger side along with a port for the steam vent. I did have to modify the upper mounts by raising them .5". It has been in the for about 4000 miles. As for fit and finish I sent the first one back due to poor fit at the filler neck. I've used Griffin in offroad trail rigs and they are ok. I like Ron Davis radiators better but for this application the Griffin is doing great so far. What I've seen with the Griffin units cracking or splitting is having them mounted to rigid in these trucks as they flex so much the radiator needs to be able to move around. |
12-06-2017, 06:16 PM | #81 | |
12-10-2017, 12:32 PM | #82 |
Yeah, I ended up replacing my Griffin with my original radiator (thank goodness I held on to it). My local radiator shop pressurized the Griffin radiator in a tank of water and it was obvious that the epoxy just doesn't hold up. They cleaned the original radiator for me and its worked great now for months. The dual electric fans and shroud fit right on the original 4 core and keeps the 402 cool even with the a/c running. I guess the original belt driven fan and clutch just wasn't enough to cool the big block after rebuild and boring of .30 over. I would highly recommend using the original radiator over an aluminum when possible.
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
12-11-2017, 10:03 AM | #83 |
Good info here. I plan to use my original. Not a pretty piece, but a functional one.
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579 |
12-11-2017, 12:34 PM | #84 | |
03-22-2018, 11:28 AM | #85 |
Truck has been back in the shop for a few months for another round of upgrades. Porterbuilt hood hinges, new safety harness, roll bar/cage, straighten front frame rails, new transmission, paint touch up, etc. Nick has started to race the truck in some autocross events and it's been to a few more shows including the Autorama World of Wheels in Kansas City where it got 3rd in nostalgia truck.
03-22-2018, 11:30 AM | #86 | |
03-22-2018, 11:39 AM | #87 |
A few more pics
03-22-2018, 11:44 AM | #88 |
I see you have a smaller diameter booster. Did the stock 11" not clear the LS? The reason I ask, I am going to be ordering a new booster in the next week or so. I am going to put an LS in my truck as well. Before I ordered, want to make sure there was no interference.
03-22-2018, 11:44 AM | #89 |
Couple more
03-22-2018, 11:49 AM | #90 | |
03-22-2018, 11:51 AM | #91 |
10-4. I had planned on using stock clam shells with adapter plates. What booster did you buy?
03-22-2018, 11:59 AM | #92 |
03-22-2018, 12:00 PM | #93 |
Thank you. I've got a Wilwood MC that I going to use. I was just curious is it's a dual 8".
03-22-2018, 12:25 PM | #94 |
03-22-2018, 12:25 PM | #95 |
Thanks!
03-22-2018, 09:49 PM | #96 |
Great job on your build with your son.
Back on 03-29-2016, 05:49 AM you posted a picture of the ring to mount a factory fuel module for the 5.3. Did you make this part or purchase it? I have been looking for a way to mount a factory fuel module.
Ike 68 swb fleetside heavily modified TPI engine. Ford AODE automatic (yes Ford!), 12 bolt 4:11 positraction rear axle, 4 wheel disc brakes, wood dash and LED instrumentation, BMW bucket seats, outside stock except for dark red paint. |
03-22-2018, 10:15 PM | #97 | |
I got the mounting ring from www.liquidironindustries.com I don't know if it's shown on their sight so you may have to contact them about it. |
08-28-2018, 11:56 AM | #98 |
Been a while since I updated this.
We took the truck on the Hot Rod Power Tour again this year, 2984 miles total that included a stop on the way home to run Tail Of The Dragon. Also I wrote an article about our trip for 4 Low magazine. The most notable part of the HRPT was blowing up the posi unit which lead to clutch material damaging the bearings, ring/pinion and getting to rebuild it which included a new carrier, R&P, and all new bearings in a parking lot with parts and some tools from summit and a few more tools from harbor freight. The truck is getting new seats and a turbo this Fall/Winter. Last edited by sangell; 08-28-2018 at 12:01 PM. |
08-28-2018, 11:59 AM | #99 |
Few more pics
04-24-2019, 10:22 PM | #100 |
Any update brotha?Awesome father/son build. Curious to see your hydroboost setup. I am starting to accumulate all the final pieces to finish my LS swapped c10. Will most likely end up purchasing a RnD radiatior/fan kit as well.
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's Project "Huckleberry" 68 GMC K1500 1/2 ton L83/6L80e |
