Old 11-26-2015, 02:04 PM   #76
mikentosh
mikentosh's Avatar
Re: Project Two - '74 Sierra Grande
Originally Posted by 91short View Post
The truck looks great, but what I really want to know is how does it drive and handle?
Hahaha, that is the most important part. Ride quality is very, very nice...car like. We only had time to do a quick tape measure alignment before getting on the road so its far from dialed in, but what I can say is that we've already taken some corners at speeds I would reserve for my M3 with no problems. Its easily able to outdrive the bench seat and lap belts
I'm going to try and get a proper alignment and corner balance done at the race shop next week. We also need to swap to a smaller bore master cylinder, and put a restrictor into the steering pump as its over boosting the rack. After all that's done then I would love to take this around a road course and see what it can do.
mikentosh is offline   Reply With Quote
Old 11-26-2015, 02:16 PM   #77
mikentosh
mikentosh's Avatar
In true Roadkill fashion, we finished the build at 3am on Friday morning and did a couple of test runs around the neighborhood. After determining everything was tight we hit the road for 750 miles to Scottsdale!!!
The truck ran great, and we had no problems keeping up 80-100mph along I-5 south. Even at 120mph this thing is still solid...makes me wonder at what speed the aerodynamics will cause issues. Another nice benefit is we pulled down 18.2mpg with our aggressive freeway driving.
It was so nice to finally have one of the projects out on display at Goodguys. I had a great time talking with everybody stopping by. We even thought about taking this out on the autocross course, but Saturday was only for the pro class.
The only issues we've encountered so far is a squealing fan belt, which was solved by shimming the belt tensioner, and a leaking power steering line which appears to be from a torn o-ring. I'm going to live with the leak until I get back to San Jose and we can go over the steering lines in more detail.
We also found that the brake pedal is super stiff, and talking with Wilwood at the show we determined that I had put in the 1" bore master cylinder when it really needs a 7/8". Hope to switch that up when I get back to San Jose as well.
Old 11-27-2015, 01:19 AM   #78
83 Silverado
83 Silverado's Avatar
Love the old sheet metal on a modern chassis and drive train. But I'd like to know if you needed a mid shift kit to run that trans, or is the motor set forward in the frame?
83 Silverado is offline   Reply With Quote
Old 11-27-2015, 01:24 AM   #79
mikentosh
mikentosh's Avatar
The motor is set way back in the frame actually. It would qualify for front, mid engine status as cylinder 1 is way back from the front axle centerline
We used a shifter adapter that I got off eBay designed for the TR6060. It replaces the long rear linkage used by the Camaro and sits on top of the trans instead.
Old 11-27-2015, 02:13 AM   #80
MTCK
MTCK's Avatar
Wow didn't see that coming. Great progress. Love your builds, I just with they would progress a little more quickly
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 11-28-2015, 01:18 PM   #81
91short
You've got a phenomenal truck, that chassis and suspension is something I can only dream about at the moment. To me it would be done, but I know you're going to finish the body and paint, can't wait to see how it turns out.
91short is offline   Reply With Quote
Old 11-28-2015, 01:56 PM   #82
mikentosh
mikentosh's Avatar
Thanks! It really does drive amazingly well. It pretty much makes you forget you are in a pickup. The 500 miles back to San Jose last night was one of the best drives I've had, and this thing is a monster in LA traffic 😊
Yeah I'm going to do full paint and body. I'm too attached to this thing to leave it as is. This looks like it was somebody's special order truck from new and I couldn't find a lot of evidence of it used for a trade, so I think it deserves a factory correct respray rather than a working truck patina look.
We are actually not going to use any of the body panels besides the cab so I'm thinking about finding another cab and transplanting all the existing panels onto the old chassis. I have a clean '74 VIN tag and title I can put against it too so it can be somebody else's patina project hahaha.
Old 11-28-2015, 04:58 PM   #83
91short
If that happens I may be interested in it, I don't live too far from you either. Keep up the good work, we like seeing the updates.
Old 03-10-2016, 11:43 PM   #84
91short
Anything new with this truck?
Old 03-11-2016, 05:06 PM   #85
mikentosh
mikentosh's Avatar
Old 03-11-2016, 05:10 PM   #86
OutlawDrifter
i know you've got all the money tied up in suspension and wheels/tires...
but that thing would look killer with some white car rally's and chrome highway patrol caps.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 03-11-2016, 05:15 PM   #87
mikentosh
mikentosh's Avatar
We were finding some fuel starvation issues when the side saddle tank was under 1/2 full. Even with the '87 baffled tank it didn't seem to be enough to keep things fed under full throttle, so we switched over to the final tank setup from the Cannonball project.
Tank is a custom rear-mount 20 gallon stainless unit built by Rick's Tanks in El Paso. This uses a VaporWorx setup which combines baffles with multiple pickups to keep the pump fed. The pump itself is a 5th-gen Camaro ZL1 module, and its being controlled by a PressureWorx PWM setup to keep the pump from being overworked. For venting of the tank and rear diff, we are using the very cool II Much billet vents which are mounted in the back corner of the bed.
Old 03-11-2016, 05:18 PM   #88
mikentosh
mikentosh's Avatar
Since we were switching the tank out, I decided we might as well swap over to the bed for Cannonball at the same time. This one has the cool bridge cover.
Old 03-11-2016, 05:25 PM   #89
mikentosh
mikentosh's Avatar
Since the truck was already starting to look primer patchwork color, I figured we might as well swap over to the front end from Cannonball too...
In the background is the rest of original "Project Two", which is slowly going back together as we morph this into Cannonball.
Here's a nice shot of the aluminum core support that Wes put together for this project. The main radiator is an Afco unit for a '70 Trans-Am, and the oil and trans coolers are Setrab units.
Old 03-11-2016, 05:39 PM   #90
mikentosh
mikentosh's Avatar
Well...since we already have the front doghouse off...we could pull the motor too 😃
Yeah, that's pretty much exactly how it went down too...at 2pm this thought came out, 6pm we had the MAST motor at the shop, and 8pm the old motor was out.
Old 03-11-2016, 05:44 PM   #91
mikentosh
mikentosh's Avatar
So the funny thing is that as we are morphing this truck into the Cannonball project, we are putting Project Two back together in its original form (on original chassis). I think when original Project Two is back together we'll probably play around with wheel selection a bit.
Its all confusing to everybody I try and explain the projects to...
At some point I will split this back into the two different build threads again.
Old 03-11-2016, 06:34 PM   #92
Drizzle
Drizzle is offline   Reply With Quote
Old 03-11-2016, 07:29 PM   #93
Blessed66
Blessed66's Avatar
I just gotta tell you, these two trucks blow me away everytime I look at the attention to detail and custom work. Simply amazing.
Current Projects:
1984 GMC, LWB Fleetside, 305/350 - Currently Doing TBI Conversion
1966 GMC, SWB Stepside, 350/200-4R - Currently waiting patiently.
Blessed66 is offline   Reply With Quote
Old 03-11-2016, 08:57 PM   #94
91short
I'd love a ride in your truck, it's my favorite on here, love seeing the updates.
Old 03-11-2016, 09:09 PM   #95
tinydb84
tinydb84's Avatar
You going to drop that LS3 into that S10 next???
David
Instagram: myfabguy
Old 03-11-2016, 11:20 PM   #96
mikentosh
mikentosh's Avatar
Haha no, we have decided the LS3 belongs to Project Two so we've found another TR6060 trans to bolt up to it and will drop that into the original chassis. Nice thing is the cab is already modified for hydraulic clutch and tunnel fits that trans perfectly 😊
Old 03-12-2016, 01:44 AM   #97
tinydb84
tinydb84's Avatar
I really want to see what Wes does with that cage and interior.
How does the new engine feel?
David
Instagram: myfabguy
Old 03-13-2016, 03:08 AM   #98
mikentosh
mikentosh's Avatar
We've been having a heck of a time with the FAST fuel rails leaking, so I haven't really put more than 30 miles on it in the last couple of weeks. Today I did manage to get it out for a couple of hours and it is definitely a lot faster than before...like breaking the rear loose at the top of third gear fast
Wes got a quick video of it rolling down the highway:
Old 03-13-2016, 03:09 AM   #99
mikentosh
mikentosh's Avatar
Oh yeah...also check out page 38 of this month's (April 2016) Street Trucks. I was surprised to see a photo in there
Old 03-14-2016, 10:38 AM   #100
aggie91
I'm just glad to be here!
aggie91's Avatar
Wes needs a new windshield!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
