11-25-2015, 01:18 PM | #76 |
Re: My 83' Crew Cab Dually project
There's nothing like a lack of materials to spoil plans to get **** done. Steel supplier can't get the rest of my material until next week now. Kinda puts a damper on my plans for the 5 day weekend.
11-25-2015, 09:38 PM | #77 |
Okay, I've got a question about the Z. I'm seeing where most guys are not just raising the front, but also moving it forward 1" to "center the wheels in the fender." Is a new driveline in order after doing this, or am I missing something? I don't appear to have any slip shafts. I'm also wondering, does the carrier bearing need to be moved the same distance upward?
11-25-2015, 11:48 PM | #78 |
Squarebody guy
Your slip may be at the carrier bearing and needing to extend would depend on how much useable slip you have when you cycle everything during mock up. Moving the carrier bearing will put it back into optimal alignment but compromises can be made and usually are in a build like ours. Most put it where it fits first and worry about angles second.
I'm far from an expert in that field but there are plenty of resources online I usually find thru google. The 4x4 forums are usually helpful as they push the driveline angles to the extreme.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress |
11-26-2015, 12:22 AM | #79 |
I'm dealing w/the driveline angle stuff now. Even w/my drop, I have a vibration. I have my pinion set @ zero but the working angle between the 2 shafts is excessive.
You'll definitely need to move the carrier bearing up if doing a Z. Mine is just a notched x-member w/the motor in the stock location.
11-26-2015, 01:32 AM | #80 |
Squarebody guy
You wouldn't want zero degrees. In a perfect world you would have the trans output aimed downward 3* and the carrier bearing positioned inline between the trans output and pinion but angled with the the front of the carrier up 3*, making the 'output' of the carrier pointing down 3*. Then the pinion up 3* to cancel out the angles. This makes the trans, carrier and pinion parallel angles.
The hardest part is getting the carrier inline between the trans output and the pinion but having the angles cancel is more important.
11-26-2015, 02:02 AM | #81 | |
11-26-2015, 02:39 AM | #82 | |
I can already see that I'll have to do some work on the trans hump. I hope to be able to make use of the high hump that's in the donor burb. The carrier has to move up anyhow...even without a Z. It hangs a good 2" below the (new) frame. |
11-26-2015, 02:47 AM | #83 |
I moved forward on the one side that I had material for. Got it all burned in and cut the lower frame off.
The remaining stock frame looks like Swiss cheese. I'll have to put some time in welding the holes up. |
11-26-2015, 08:51 AM | #84 |
Member of the longbed union.
Frame is looking good. I was gonna do 4x2 for my frame, but I'm really starting to think about doing 4x3 instead.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
11-26-2015, 09:41 AM | #85 | |
Squarebody guy
4x3 makes for a nice, easy weld joint along the top of the tube.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress Last edited by Ghostwhite; 11-26-2015 at 09:47 AM. |
11-26-2015, 10:09 PM | #86 |
Yep, what Ghostwhite said. Plus, our trucks are a long span (11' 1" on mine), and the additional size should help to curb the flex. I'd have actually gone taller if I could have fit it. My stock frame varies in width from 2 1/4" - 3" (a product of poor quality control in the factory it seems), so the 3" wide cleans all of that up.
11-26-2015, 10:20 PM | #87 |
I hear ya about the 4x3, I already have 40' of 4x2.
11-27-2015, 12:52 AM | #88 |
Can any of you guys point me to some more info on Z'ing the frame? I've seen straight Z's and the inch forward Z's. My wheels appear to be centered in the fender already. The forum search function doesn't like just "Z" as a search and most everything I bring up doesn't touch on what I need to know; is the inch forward really needed?
11-27-2015, 02:00 AM | #89 |
Try "Z'd" "Z'ing"
I did 1 inch forward. The wheels looked more centered. I wouldn't have cleared the firewall of I didnt.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
11-27-2015, 02:56 AM | #90 | |
Squarebody guy
The best search utility for me to use google's site specific searches. Enter "site:67-72chevytrucks.com" without quotes before your search terms and it will search only this site. It is not perfect and will not order the results by date but I use it for searching forums every day. Here is an example -> site:67-72chevytrucks.com frame z
11-28-2015, 11:55 PM | #91 |
Thanks guys. I think I've got enough knowledge to do the Z correctly now. 😉
Since I'm still without material, I decided to move into the next logical step and did some tear down today. Front clip is off and engine/trans are out. Now I need to figure out how I'm going to get these cleaned with it being 10* outside... |
12-05-2015, 10:22 PM | #92 |
Finally got the rest of my material. I finished putting the driver's side rail in and tied in the remaining (very little) part of the original frame. Now I'm measuring and getting ready to do the Z. I was able to get the slip on the driveshaft to break free, so I'm moving the Z an inch forward.
12-06-2015, 02:01 AM | #93 |
Post measurements if you can
12-06-2015, 02:28 AM | #94 |
12-06-2015, 04:18 PM | #95 |
Here's the (updated) Z measurements. Guessing that's what you're looking for? |
12-06-2015, 08:13 PM | #96 |
Finished for today. I got the Z in place and started on the bracing and tying into the front part of the frame. I can't decide at this point if I'm going to put another piece of tube under the one that's in place or if I'll just trim and plate the underside before I do the fishplates. I've been staring at it for too long, so it's time to quit and ponder for a while...
Anyway, here's what I got done today. |
12-12-2015, 09:14 PM | #97 |
Made some filler plates and started finishing off the Z.
Still need to do some cleanup and make a small sliver of a filler for the top of the frame where it goes from 3" to 2". I plan to grind it all down and smooth it when I'm done. |
12-12-2015, 10:22 PM | #98 |
Yes sir. Those are what I was looking for. Truck is looking good.
12-12-2015, 11:39 PM | #99 |
Nice clean work!!
12-13-2015, 11:43 PM | #100 |
Thanks guys...
I finished up the filler plates today and smoothed all of the welds. The whole thing was incredibly time consuming...did I mention how much I loathe grinding? There's some kind of shmutz on the 3/16" plate that I got from Pacific; it was a drop from their plasma table, so something must have gotten on it...whatever it is, it doesn't grind for sh!t. I may have to hit it with the sand blaster before I paint it...
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192 Instagram: lofab77 |
