Old 06-19-2016, 06:30 PM   #76
tinydb84
tinydb84's Avatar
Re: Bagged 65 c10. AKA the periwinkle pile
Originally Posted by Johnny_Lamebridge View Post
I'd like to try some. Care to share some basic info? Filler wire size, amperage etc. Thanks in advance.
I run about 45amps. 1/16'' tungsten. 2% as well. 0.045 filler rod. I tack every body line, high crown area, and about 1-2'' in between.
I weld one section at a time and stop as soon as the gap starts to close up and overlap. I then stop, planish, and let it cool.
Just to give you an idea:
This hasnt even been body worked. Just a quick hit with a die grinder and da sander:
(Btw not trying to derail your thread. I also stole your idea for the bed floor)
David
Instagram: myfabguy
Old 06-19-2016, 07:49 PM   #77
greengrenade
Nice work tiny, i forgot to mention that in my previous comment, doing small sections letting it cool and then hammer/dollying that area out is the way to go for sure
greengrenade is offline   Reply With Quote
Old 06-20-2016, 04:44 PM   #78
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Thanks for the info tinydb84 & greengrenade. I'll give it a try...
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 07-07-2016, 01:57 PM   #79
greengrenade
Made some bed side support rods out of round stock
Got the hatch door buttoned up too. Plasma cut a slot in the top bracket and have a drilled tab coming up through held down with lynch pins
Old 07-16-2016, 01:32 AM   #80
greengrenade
Got the frame primed last weekend
And painted the frame, 4 links and panhard bar tonight
Old 07-24-2016, 09:44 PM   #81
greengrenade
Got the links painted and the rear suspension re assembled
Old 07-24-2016, 09:46 PM   #82
greengrenade
We got the shocks painted and re installed, the tank bracket painted, the vu4 bracket painted and installed a few bulkheads today. Pics to come of that. Also decided to paint the air tanks gloss white, and painted the straps that hold them blue to match the truck. Should have a nice pop to it against all the black but not be overpowering
Old 07-25-2016, 01:57 AM   #83
62stepside longbox
62stepside longbox's Avatar
Looking great! Keep up the good work
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 07-25-2016, 03:40 AM   #84
tinydb84
tinydb84's Avatar
Looks good!
David
Instagram: myfabguy
Old 07-31-2016, 11:28 PM   #85
greengrenade
Heres a pic of the air tank painted and straps color matched. The second tank needs to be stripped and re sprayed due to humidity issues we had with the paint, but you get the idea
Got the front of the truck and underside of the cab and frame stripped down. I had to do a "kick up" in the frame rail for the steer shaft carrier bearing coming off the steering rack. The pancaked crossmember raised the shaft location enough that the angle was too tight. I boxed it off and smoothed it out so itd look as factory as possible. Also welded on the shock mounts for good
Got the front crossmember painted up
Frame and firewall cleaned off and masked up
Fresh coat of black
Got my multi tiered, jerry rigged paint hangers to paint the porterbilt hinges and bag plates haha
Old 08-01-2016, 12:30 AM   #86
gringoloco
A guy with a truck
gringoloco's Avatar
Nice work, and lots of it. Hard sometimes to understand all of the time/effort that is captured in just a few pics. Keep at it!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-01-2016, 12:35 AM   #87
greengrenade
Thanks bud. Its a boat load of work. I got well over 300 hrs of strictly metal fabrication in it and lost track towards the end so who knows really. Plus the time me and the owner have put into painting, cleaning, mock up etc etc. I appreciate it
Old 08-01-2016, 02:57 AM   #88
tinydb84
tinydb84's Avatar
Looks good man.
David
Instagram: myfabguy
Old 08-04-2016, 12:44 AM   #89
greengrenade
Is there any way we can utilize the original steering column shaft and fit a u joint to it ? Or will he have to buy a whole new shaft?
Old 08-12-2016, 03:34 AM   #90
greengrenade
Front end is painted and together finally. Also finally got the tanks installed so we got a good look at how the rear is going to look. Well for the most part
Old 08-12-2016, 03:36 AM   #91
greengrenade
Does anyone have any recommendations on the steering column shaft ? Can i grind it flat to accept a d shaft style u joint, should the owner buy a new shaft. Any links lf other info ? Id greatly appreciate it
Old 08-12-2016, 03:43 AM   #92
greengrenade
My buddy rob also got some wicked shots of the truck. I wanted some shots of all the chassis work that went into this truck. I have a ton of time into all the fab. Hes shot some pics of other cars ive had and always does a fantastic job. Heres just a few shots....
Also you may notice in the pic that we got the cpp power brake master/booster setup installed that my buddy bought
Old 08-14-2016, 01:10 PM   #93
62stepside longbox
Looking good, sure some cool pictures there
Old 08-14-2016, 04:35 PM   #94
greengrenade
Got some more work done. Air lines are officially run, both front and rear
Heres a pic of the air tank/compressor bracket removed from the frame. I designed and built this so the whole package would come up and out with just 4 bolts on top of the rails
Got some of the tank fittings knocked out, compressor lines and water traps sealed up for good
My buddy and his dad knocked out the rear brake lines as well, all the way back to the master cylinder
My buddy is running a gmc grill on the truck, he found a fairly clean chrome one. Chrome had some tarnish and pitting on it
I used some quick-glo chrome cleaner that my dad found after seeing it on jay lenos garage. This stuff is amazing. Heres the grille after one quick pass with the cleaner
Heres a few pics of the gmc letters and the headlight bezel after a quick 30 second rub with this stuff. The headlight bezel cleaned up great, it didnt remove the heavy pit obviously but the whole ring had yellow/brown rust residue and as you can see it removed it with ease on the half that was done
This stuff also has a wax/sealant in it to help prevent moisture from getting back into the affected areas. It works great
Old 08-14-2016, 11:36 PM   #95
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Awesome pics. Really diggin your build.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 08-15-2016, 12:07 AM   #96
gringoloco
A guy with a truck
gringoloco's Avatar
Good progress. You just cost me $10 in quick-glo, haha!
-Chris
Old 08-15-2016, 02:37 AM   #97
greengrenade
Thanks chizzler, and trust me gringo its worth every penny. I used it alot on my 62 belair, my 54 fore i have now has a lot of parts that need a rub with it. Its good stuff haha
Old 08-15-2016, 12:49 PM   #98
thepartsguy
thepartsguy's Avatar
Im in
63 C10
65 Chevy Custom Cab w/ Big Back Window
66 C30
72 skylark w/ 454
65 K10
May the bridges I burn light the way....
thepartsguy is offline   Reply With Quote
Old 08-15-2016, 04:31 PM   #99
namloc
namloc's Avatar
Lot's of time into the project and all come's together in the end.Very cool truck.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 08-15-2016, 06:25 PM   #100
greengrenade
Thanks guys. Hey do any of you know what we can do for the ster shaft ? Is there a shorter replacement shaft that we can get or can we get the stock one machined down to fit a d style u joint
