Old 06-30-2016, 07:25 PM   #76
buffydores
buffydores's Avatar
Re: 1978 Russet Metallic 4x4
Originally Posted by 1978 Cheyenne Big 10 View Post
Hello!
Where were you able to locate the dark saddle color for the door panels to match the other door components and the dash too!?
You have an awesome truck!!
Thanks. I gave the truck back to my Dad today. He was really excited. The door panels are not saddle color. It's GM's mandarin orange. It's kinda a orange saddle. The matching vinyls are more orange, but the panel is definitely not saddle. There's a company in California called Just Dashes that will take the door panels and dash , sand the oxidized plastic out and then rewrap in color matched hard vinyl. It's really nice stuff, but super expensive.
Old 06-30-2016, 07:28 PM   #77
buffydores
buffydores's Avatar
Here's the finished wheels with the chrome trim ring:
The new stickers on the winch:
Trim rings are awesome:
Old 06-30-2016, 07:33 PM   #78
buffydores
buffydores's Avatar
I just received the 4X4 center caps for the rear. We're installing the rear spacers tomorrow. We're replacing the defective clock and the bad gas gauge sending unit next week when parts arrive.
Old 06-30-2016, 09:23 PM   #79
RANDY COX
RANDY COX's Avatar
Looking good I bet your Dad was excited with Joy...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 06-30-2016, 11:57 PM   #80
Dc42d76
Those wheels really tied everything together! They look great !Great job Cameron !
Dc42d76 is offline   Reply With Quote
Old 07-01-2016, 09:20 AM   #81
68Timber
I know the pieces fit
68Timber's Avatar
They look better as 16's, I'd be tempted to run them without trim rings. Great choice.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-01-2016, 10:16 AM   #82
buffydores
buffydores's Avatar
The trim rings make them pop. I drove a few days without them. Trim rings are definitely better.
Old 07-01-2016, 11:41 AM   #83
buffydores
buffydores's Avatar
Thanks Donny
Old 07-01-2016, 03:38 PM   #84
buffydores
buffydores's Avatar
Here we go. New spare tire on custom 16" spare. I went 245/75R16 to give it a good clean fit:
All the wheel stuff lined out perfectly:
Old 07-01-2016, 07:07 PM   #85
phillipm
That looks killer. nice job!
Old 07-03-2016, 10:19 PM   #86
buffydores
buffydores's Avatar
Last couple of items. The steering pump whines when it gets warm. Waiting on the new NOS quartz clock.
Any suggestions on the steering pump?
Old 07-08-2016, 12:16 AM   #87
Fishermen0105
Love the seats, where did you come up with the material? I'm restoring a '79 and would like to come up with a way to do the blue plaid. Great restoration, hope mine looks half as good when I'm done.
Fishermen0105 is offline   Reply With Quote
Old 07-08-2016, 06:16 AM   #88
buffydores
buffydores's Avatar
SMS out of Oregon has the materials stock piled.
Old 07-08-2016, 09:03 AM   #89
68Timber
68Timber's Avatar
Is the PS pump new?
John
74 Honda Z50 build
Old 07-08-2016, 09:19 PM   #90
buffydores
buffydores's Avatar
Is the PS pump new?
Newish.
These trucks make everything else look blah. Here it is today at a charity skeet shoot. There's something so right about driving around with a couple of shotguns and boxes of shells in this thing. 'Murica!!!
I've spent the past two days replacing the clock, instrument backing plate, speedometer, circuit board, clear plastic bezel, dash bulbs, speedometer cable and speedo gears to get the speedo running true. I had my little GPS app measuring the difference between actual speed and speedo speed. It was fun.
Old 07-08-2016, 10:35 PM   #91
tommys72
tommys72's Avatar
Beautiful! Very nice work
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 07-09-2016, 06:03 PM   #92
buffydores
buffydores's Avatar
Both blinkers stopped working. Any ideas?
Old 07-09-2016, 06:39 PM   #93
bhc41051
bhc41051's Avatar
could be your flasher.
bhc41051 is offline   Reply With Quote
Old 07-09-2016, 08:01 PM   #94
buffydores
buffydores's Avatar
Left one is fine. Right one is not. The actual blinkers with fine. It's just the dash bulb that's not blinking. I just replaced the bulb, so that wouldn't be the first guess.
Old 07-09-2016, 08:12 PM   #95
buffydores
buffydores's Avatar
I think it's a ground. It was dimmer than the right one before and after I replaced the bulb. Where did this thing ground out. I just replaced the circuit board, so the problem isn't there. Where did it ground?
Old 07-10-2016, 08:25 AM   #96
buffydores
buffydores's Avatar
I'm thinking it's the bulb holder. Everything else grounds to the same place, so it's either the bulb or holder. I'll look at it in a couple of days.
Old 07-10-2016, 03:43 PM   #97
Willowrun
Willowrun's Avatar
Do you mind sharing part number(s) for the replacement speedo cable you used?
Old 07-10-2016, 11:45 PM   #98
buffydores
buffydores's Avatar
Just hollered down to O'Reillys for a delivery to our shop. We buy a lot from them.
Figured out the light. The bulb was a dud and the bulb plug had some corrosion or something that was dimming the bulb. I cleaned the bulb plug with soap and water, then vinegar, then soap and water, then water, then dry. Then I replaced the bulb. Now the light is just as bright as the left one.
The driver side mirror won't stay put at highway speeds. Gonna fix that next. I think the rubber grommet does more holding than it first appears.
Adding dielectric grease to the serpentine belt has addressed most of the whining sounds up front. Needed new header bolts and nuts. Got those on. Pretty much there.
I like driving things for awhile to work out the bugs. I took my two boys to a local car show yesterday and showed the Blazer. That was super cool.
Old 07-12-2016, 08:38 AM   #99
buffydores
buffydores's Avatar
Dad commented on the slop in the steering column, so I ordered the Borgeson steering shaft with u-joints on each end.
http://www.borgeson.com/xcart/produc...&cat=34&page=1
The steering box is new, the ball joints are new and I have a frame brace installed, so there's no reason I shouldn't upgrade the shaft to something new.
It will probably be the first part of next week when I get a chance to install it.
Old 07-15-2016, 03:26 PM   #100
aggie91
I'm just glad to be here!
aggie91's Avatar
Outstanding work on the Blazer! Hopefully since I'm in the same part of Texas, I can see it some day in the future.
Where did you get the rubber you cut for the floor mats?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
