07-18-2016, 10:25 AM | #76 |
A day late and $1 short...
Re: New Daily Driver
According to Classic industries they are different, thanks anyway!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
07-18-2016, 07:03 PM | #77 |
I bought the whole truck kit from Right Stuff Detailing. However, since I'm using a hydroboost system with a wilwood master and adjustable proportioning valve, I used the wilwood lines from the master to the prop valve. I also straightened and re-bent the pre-bent stuff from the prop valve down to the frame. Either way, I did not cut and reflare any of it.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
07-18-2016, 08:26 PM | #78 | |
07-23-2016, 05:36 PM | #79 |
The two barrel carb on this old beater just wasn't cuttin' it. I've been collecting parts for the last month or so to swap in a 4 barrel. I just finished up the swap and took it for a ride, what a difference! I thought I might be using too much carb for the little 307 but the 600cfm Edelbrock seems to work just fine. I searched for a used 500cfm unit but they are pretty scarce. I didn't paint anything, I really wish I had an old air cleaner, the chrome one sticks out like a sore thumb, but I had to have one so it'll have to do. Maybe I'll paint it flat black...
Not really a big deal but here are a few pics. Last time it will look like this... stock. Oh the madness has begun! Starting to come together. only fifteen more trips to the parts store! Just few things to button up, plug wires, vacuum plugs, and build a new throttle arm. All done, the damn thermostat housing and oil fill tube stick out like a sore thumb. I'd buy more shiny stuff but I'm not sure if we're going to stay with a gen I small block. And we do, I'd rather it look more stock-ish like STP67-72s Lola does under the hood. Anyway, with just a couple miles on the new induction set up I'm pleased, the real test will come with the first 18 mile trip to work.
07-23-2016, 08:05 PM | #80 |
My first vehicle was a 70 Malibu with a 307. I ran a Holley 600 the whole time.
07-24-2016, 09:00 PM | #81 |
Put a few miles on her today with the first long run tonight, 18 miles to work. The new carburetor really does make a difference, no stuttering or stammering while at cruise rpm, just smooth running.
I picked up a TH-350 today. I'll have it rebuilt soon, still need to collect up some supporting parts like a auto steering column and torque converter.
07-31-2016, 12:26 PM | #82 |
Anyone replace a complete dash? Wondering how difficult it is...
07-31-2016, 01:36 PM | #83 |
It unbolts on the sides but there are a bunch of spot welds along the lower windshield lip.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
07-31-2016, 01:53 PM | #84 | |
My dash has a bad repair in the radio area. I have a complete dash hanging in the shed but I'm wondering which repair is easier, the complete dash or the center area I can buy for DeWayne at Nsane Hot Rodz. Either way I'll have to have it painted. The boy wants the ability to listen to FM so I'll need to fix this so I can install one of the retro style radios.
07-31-2016, 02:28 PM | #85 |
If you have a complete dash and don't mind cutting it up, then you can cut it like my picture, plus cut between the ovals under the dash pad and graft that into your existing dash. The glove box door, instrument bezel, and dash pad end up hiding most of your welds if they don't come out perfect and you don't have to pull the windshield out. Something to think about anyway.
07-31-2016, 09:10 PM | #86 |
To me, ^^THIS^^ would be the way to do it. Seems like a whole lot less work and potential for warping/damage of other panels.
08-06-2016, 11:06 PM | #87 |
I went to the parts store to pickup a valve cover breather and a new thermostat housing gasket... Walked out with new chrome Edelbrock valve covers, valve cover gaskets, Edelbrock breather, and a thermostat housing gasket. $20 turned in to $75! The worst part is that while they aren't all warped and nasty like to old ones, the engine and engine compartment are so nasty the new ones just blend right in.
Before and after...
08-07-2016, 09:28 PM | #88 |
Nice improvement over the others. Lookin' good.
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
08-07-2016, 11:11 PM | #89 |
Someday I'd like to have some factory Chevrolet script valve covers modified for PCV by n2billet or Delmo and some sort of factory style air cleaner. That would be very cool.
09-15-2016, 05:08 AM | #90 |
Put some LEDs in it...
09-15-2016, 10:10 AM | #91 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-19-2016, 09:55 AM | #92 |
I'm just glad to be here!
Very nice truck. Doing this way should help keep costs under control.
Love the green too!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
09-23-2016, 05:44 PM | #93 |
Got the TH-350 back from the transmission shop today. Bought a used auto column, just need to disassemble and paint it, that should be an experience. Also have a Boyd Welding ready to go in, just waiting for Hart_Rod to get back from vacation so he can help with custom side fill.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 09-23-2016 at 05:56 PM. |
09-23-2016, 09:23 PM | #94 |
Nice parts! Why the 350 instead of OD trans?
09-24-2016, 11:51 AM | #95 |
Much cheaper to build. Not going to be road tripping in this truck so no need to spend the money.
09-24-2016, 06:31 PM | #96 |
Great to see you at work on another truck. The small steps look good.
Dwight |
09-26-2016, 06:12 PM | #97 |
6>8 Plugless........
Nice work on the truck, and the trans looks nice. Send Rob up here and have him do my side fill too would ya?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
09-27-2016, 01:05 AM | #98 |
Very sanitary build love it!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
09-27-2016, 04:12 PM | #99 |
The steering column fiasco IS a lot of fun. Just don't force anything. It all fits together....
09-27-2016, 04:56 PM | #100 |
Good looking truck. Think about hard lining the fuel line from the pump to carb. these trucks burn down all the time for that reason and you have a good looking one. Hate to see it go up in flames.
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
